01-20-2008, 04:55 AM
#2161
SMKFree
Quote: Originally Posted by refuse
This might be a stupid question, but could I use the new skin and the old day skin?
its not recommended to do that since the two skins share the same lstools folder and the 3.x version has significant changes to the content in that folder, so no telling what kind of issues you'll run into doing that.
[media]http://i66.photobucket.com/albums/h272/subywagon/untitled.jpg[/media]
Are there suppose to be arrows to scroll through the music?
Also is there an option to make it not scroll through the whole playlist to the next song when on shuffle and just switch songs like 2.02?
nothing i can do about how it scrolls the playlist to get to the next song on shuffle, its a RR issue.
Your audio player should look like the attached pic.
when i think about it though, i looks like you are using the OLD audio player. Ill have to add some arrows to that screen, eventually though that screen will be retired.
01-20-2008, 05:01 AM
#2162
SMKFree
Quote: Originally Posted by Gurukarma
I'm still having a problem with the presets and playlists... The presets are not working at all and when I exit and re-open roadrunner (so I can see my audio text after hibernating) the audio that plays is from the playlist I was on before the one that was playing when I exited but the text that shows is for the playlist I was on when I exited (the text doesn't match the music).
Any suggestions?
-GK
this is not a issue with the skin or the play list feature, but a problem with RR not resuming the proper music when it restarts. This only seems to happen to some people, not sure what causes it, but there are a few thread about the issue.
The reason the text is correct is because i save that info to a variable in skin.ini as soon as you set the preset. RR tries to save the song info on exit, but sometimes does not have enough time to save it before windows kills the process. This happens when windows shutsdown and kills RR before it can write the resume info. if you exit rr before you shutdown the pc it should fix the problem, but not really a good option in the car.
01-20-2008, 01:29 PM
#2163
Thanks for the help smoke. I don't have the arrows in the new or old audio screen but I like how you can slide the playlist so it doesn't matter to me. I am now running the old day skin on the new LS tools and it seems to be working perfect, if not better.
01-20-2008, 02:21 PM
#2164
When extracting the update do I point it to the the skin folder, the lstools folder, or just the RR folder?
01-20-2008, 03:27 PM
#2165
SMKFree
im glad you have it working ok, but i can almost assure down the road there will be an issue somewhere as there are files not present in the latest lstools that the old skin looks for. But its possible those are features your either not using or dont pertain to your setup.
you point all the 3.x updates to the root of the skin, inside the actual lsxvoid3.0 folder, so you should get a prompt from windows to overwrite files, if you dont you are in the wrong folder.
01-20-2008, 08:16 PM
#2166
Audio button - Please help
Ok so i was able to get the audio button to work, but it will only work when I have the 9/30/07 release of RR installed. When I update RR to 12/6 or 12/14 the audio button doesnt work. I get "Error on InitDX: -2005532452 Automation error"
Please help me!
Quote: Originally Posted by jaw4322
Ok...so after getting everything working on my laptop (read below). i was ready to actually try everything on my car deck. Unfortuanately Im getting a different error when clicking the audio button now.
Error on InitDX: -2005532109 Automation error
I am running windows xp, directx 9.0c, and have ran regsvr32 dx7vb.dll. I have also update all display drivers with no luck. Can any guide me in the right direction? Thanks for the help.
Joe
Guess this was a directx issue.
downloaded dx7vb.dll to c:\windows\system32
then ran regsvr32 dx7vb.dll
Problem resolved!
Audio button
Hello
First off, the skin is awesome. Ive recently pulled by setup out of my car to update from 2.0.
Ive run into a problem through. after installing it everything works but the audio button. After clicking it RR freezes. I have tried it on vista and xp pro. Im running the recommended winamp 2.95. I have uninstalled and reinstalled several times. I Added all the updates. Ive read through this post and there were a couple of posts, but I cant see a fix. If i missed it Im sorry.
This is the error from debug.
1/17/2008 11:20:31 PM: Que Exec: True, menu.skin, "AP01", False
1/17/2008 11:20:31 PM: Executing: AUDIO
1/17/2008 11:20:31 PM: Error on InitDX: 429 ActiveX component can't create object
I would be grateful if someone could point me in the right direction.
Joe
01-20-2008, 10:26 PM
#2167
SMKFree
Please help me!
that error is related to Direct X, nothing i can do will fix that for you.
What you can try and look into is.
Do you have the latest drivers for your video card?
Do you have the dx7vb.dll file and is it registered?
Do you have fastmode=-1 in RR.ini?
Are you using or have installed and 3rd Party (non MS) remote desktop software?
Some system simply have too poor video cards, usually non intel embedded chips and there really isnt anything u can do except upgrade your video card. If you have a itx system this may be a task due to the small size, but i do believe it is possible to install a pci video card on these systems. You can get a older nividia card for 50bucks that will be more than enough for any carputer needs.
01-20-2008, 10:46 PM
#2168
Thanks for the info on this. Does this also affect the Presets? I can switch to preset 2, make a new playlist, then go back to preset one and it is empty, then go back to preset 2 and it is also empty? If I remember correctly the presets are automatic, or am I missing a "set as preset" somewhere?
-GK
2009 Scion XB
Mac Mini Intel Core Solo
RoadRunner w/LSX Void
01-21-2008, 02:06 AM
#2169
SMKFree
-GK
no they are not automatic anymore, that feature is temporarily disabled. You have to specifically set each playlist you want to store.
To store a preset.
Load some music up.
Switch to the preset number you want to save to.
Click and hold the right preset arrow button.
If you want to set the preset with additional options, click and hold the left preset arrow button.
Here you can pick witch slot to save the preset in and also the option to give the preset a custom name.
01-21-2008, 03:11 PM
#2170
Arrow Compass
After update latest rr n lsx 3.25 update arrow compass no longer work any idea how to fix it
thanks
01-21-2008, 06:09 PM
#2171
Hey, this is a great skin, loads better than the one I have now (despite the fact that it's not customized to my car...)
The question I have is about the buttons in the menu system (Audio, navi, XM, sirius, etc.)
Since I'm not going to be using satellite radio, I'd like to change one of those buttons over to something I will be using a lot, which is my engine management software.
I tried opening the skin in the skin editor, but there are a lot of different files and I couldn't really figure out which one was the one with those particular buttons.
Is there another way I can go in and change the buttons or do I have to use the skin editor, and if I have to use the skin editor, what exactly am I looking for?
Btw, before anyone says anything about the APPS menu, this is a program that I use every time I drive the car and I want to have the button where I can get at it easily without having to go through a bunch of menus.
Any help would be great, thanks guys.
01-21-2008, 06:46 PM
#2172
Hello,
I've installed this skin but the button's icon don't display properly(I see only numbers and symbols)..see the pictures below:
What is wrong? I've made a fresh install of win xp sp2, roadrunner 12-23-2007, lsxvoid3.2 +patch 3.2.5
thanks
01-21-2008, 06:58 PM
#2173
You can press and hold any of the buttons and a menu will pop up showing what you can reporgram the button to by simply selecting it. Check to see if the button you want on the front page is there. If I remember "apps" is there...........
Leonardo Da Vinci
01-21-2008, 07:01 PM
#2174
Quote: Originally Posted by Serfio
Hello,
thanks
Looks like you're missing a font. Search this thread for the word "FONT". I believe this has come up before. I think there was also an issue with non-english XP installs that caused similar issues.
The white bar is a flash issue, usually requiring a simple update........
Leonardo Da Vinci
01-21-2008, 07:34 PM
#2175
Awesome, thanks greatwhite.
I also have a question about wifi.. There's an indicator to show it's connected, but is there some kind of wifi connection manager I can use?
| Thread Tools |
| Display Modes |
Linear Mode
