01-26-2008, 04:22 AM
#2191
can some 1 help this idiot
i just cant replace current radio skin to HD radio skin pleaseeeeeee help me step by step how to. Thanks alot and yes i've searched
like i said i'm an idiot
01-26-2008, 04:50 AM
#2192
never mind got it thanks any way
01-26-2008, 05:55 AM
#2193
When i open VIDEO i can't see any cover art.
I got a videos folder.
In this folder are the video files and their covers.
For example:
But i can't see the cover art when i want to open a video...
Sorry for bad screen...
When i use the backup video browser, the covers do work!
But i want to try the new video art version.
Is there a solution?
| Suzuki Esteem 1.8 GTX | Intel Pentium 4 Carputer | Entertainment On A Higher Level |
01-26-2008, 11:12 AM
#2194
SMKFree
For example:
open RRConfig and under general setttings check box "Show Iconts"
or
In rr.ini
showicons=true
01-26-2008, 11:15 AM
#2195
SMKFree
Quote: Originally Posted by mnickolson
IS this the proper comand and dose it go in the RR EXECTBL.INI or Skin EXECTBL.INI?
"ONRESUME","reloadskin"
you can use it in either file.
If its in RR exectlb.ini it will execute the command for every skin you load.
"ONSUSPEND","COMMAND"
"ONRESUME","COMMAND"
01-26-2008, 11:16 AM
#2196
SMKFree
Quote: Originally Posted by beuz
To what corresponds this little yellow icon in shape of speaker that appears from time to time on the right of the clock pls?
that icon shows up when IG is giving voice directions or talking.
01-26-2008, 12:30 PM
#2197
HD signal bars
LS i got HD radio up n running but there's no signal indicator how do i fix it ?
01-26-2008, 10:58 PM
#2198
SMKFree
i have no idea
seriously
I dont have hardware for radio or HD radio and i didnt create the HD radio skin. The screen may not even have a signal indicator.
The best i can do is when i get some time, look at the docs and see if there is an signal indicator for HD radio then check the screen to see if there is even one present.
01-27-2008, 01:57 PM
#2199
LS - saw you posting in the Orb plugin - would be a great addition to this wondeful skin.
I wish the author would make it an extension as well.
However - in the meantime what would be the best method to add an "ORB" button to VOID3?
I love your "empty embed any program" buttons but how do I call a skin like the Orb.skin?
Thanks,
Sean
01-27-2008, 04:02 PM
#2200
Quote: Originally Posted by liquid_smoke
i have no idea
seriously
thanks for your quick respond, for now i just replace phoco for HD signal strength
01-28-2008, 11:50 AM
#2201
or
In rr.ini
showicons=true
I was trying this out, and don't see anything about "Show Iconts" or "Show Icons" if that was a typo. So I added to line under [General], and Audio player doesn't work with this line added. Removed it, and everything is working fine again. Any ideas?
01-28-2008, 12:38 PM
#2202
In rr Config on page one lower right side.
Attachment 47712
2004 Sport Trac PC Project.
01-28-2008, 02:38 PM
#2203
Ah, there it is. I had just did the manual change a little after I made the post and it worked. But now it seems as though Winamp is kind of flaky sometimes. It's like when I run RoadRunner, sometimes it won't start Winamp, thus not doing anything in RR when I try to play music. What is the optimum version of Winamp to run if there is any? I am running 5.13, which is the choice for Digital FX, maybe this is my issue?
01-28-2008, 02:45 PM
#2204
5.13 is the ver I use and have also read here were it is the right one to use.
01-28-2008, 03:52 PM
#2205
Well, it looks like doing a reinstall of Winamp has fixed most of my issues. Only thing I have a problem with now is that the Visualization is like "On Top" of everything, and I can't seem to get it to show behind everything. Meaning, I can't click on anything. While the visualization is running.
| Thread Tools |
| Display Modes |
Linear Mode
