Go Back   MP3Car.com > Mp3Car Technical > Software & Software Development > Front Ends > Road Runner > RR Skins > RR Released Skins
Old 03-05-2008, 08:52 PM   #2341
I see dead kittens
Quattro's Avatar
Quattro has a brilliant futureQuattro has a brilliant futureQuattro has a brilliant futureQuattro has a brilliant futureQuattro has a brilliant futureQuattro has a brilliant futureQuattro has a brilliant futureQuattro has a brilliant futureQuattro has a brilliant futureQuattro has a brilliant futureQuattro has a brilliant future
LS, I wanted to know if there is way to do this?
The album art turns on by itself as it should, but the art says on until you touch the screen. I wanted it to show the playlist when the song changes and then after 10-15 secs the album art show again.
Possible?
Installed
Asus A7N8X-VM - AMD Mobile Athlon 2400
512 Ram - 60GB HD - Opus 150w
Lilliput 7" - Rikaline 6010
[00000000000001100010-] 98% Completed
Check Out My Install!!!
Quattro is offline   Reply With Quote
Old 03-05-2008, 10:22 PM   #2342
slvrsol's Avatar
slvrsol is an unknown quantity at this point
Possible?
not gonna be easy, but you can load the audio player skin ONSONGSTART
slvrsol is offline   Reply With Quote
Old 03-06-2008, 07:46 PM   #2343
TeamRSX's Avatar
TeamRSX is an unknown quantity at this point
Question
Quote: Originally Posted by TeamRSX View Post
I just downloaded lsxvoid 3.3 and looks and feels great.. Thanks LS.
The only problem i have is when i click on the main options which displays the options menu (General Option, Media Path, Music, Video etc..) just as in a screen shot from a few posts ago i have problems on certain options.
When ever i click on either Music or Video option the window displays, but keeps flickering until i click on the window, but it seems to only happend when i click on either the Music or video option. I have played around with the GPS option and works great.
I also have the path for my music and video set in RR_config and was able to fully use lsxvoid 3.2, so not too sure what the problem is.
Sorry i dont have a screeen shot as i am at my work computer and dont have RR installed.
Not sure whey these 2 options keep flickering, but other than that everything seems ok.
Does this have something to do with flash? I am pretty sure i have flash 9 installed.
I did some testing and even reinstalled void 3.3 and found out the problem with the options menu flickering has to do with turning ilist function on. When the feature is turned off i have no problems asseccing the menus and there is no flickering.
When i turn ilist on it seems the majority of the options flicker until i click the mouse over top of the window.
I noticed the following menu options flickering when ilist is turned on:
Music
Video (actually nothing displays when i click on video even when ilist is on or off)
Phone Settings
ATT Volume Options
Calculator
About
The rest seem to be fine. Any ideas why this would happen when ilist is turned on? I have flash 9 installed. Not sure why its flickering for some and not others.
TeamRSX is offline   Reply With Quote
Old 03-06-2008, 09:28 PM   #2344
OriginalRudeBoy is an unknown quantity at this point
Been Running LSX 3.3 fine for a copule of days now. but today i decided to attach a gps unit to my Carputer and i have to keep restarting road runner abt 4 time before it starts working. if i change the com port for the gps to a port with out a gps unit it loads up first time.
Any Ideas???
OriginalRudeBoy is offline   Reply With Quote
Old 03-07-2008, 12:39 AM   #2345
SMKFree
liquid_smoke's Avatar
liquid_smoke is on a distinguished road
flash has nothing to do with the ilist feature. Actually the there is very, very minimal use of flash in teh skin, some may never see the flash. If i can remember the only items in teh skin that use flash is the flash compass, flash clocks if u choose that layout option, the games and i think thats it. But none of the core stuff is flash.
The ilist rely solely on your ability to run DirectX with your video card. Not sure about any flashing, i have yet to see that with the ilist and i think ive seen about every error or issue with it first hand. But ill definately try to see if there is anything that could cause it.
Quote: Originally Posted by greatwhite View Post
Donation sent.
Wish it could be more, but you know how things are these days..............
My appreciation for your efforts far outstrips the amount donated. Thanks for all your hard work.
So what functionality will it give the carputer user?
Will it allow you to place and receive calls over the 'puter or simply control windows media (like remote desktop) to access contacts, schedule, calender, etc?
Is it a freeware version or a program that needs to be purchased?
I assume it works over bluetooth?
I'm really curious now (as you can probably tell).............
Cheers
First , Thanks for the donation its always appreciated!
In a nutshell, the tool is remote desktop for your windows mobile device. It displays in realtime the display on your screen and u can also control the phone directly from the touchscreen. The display is sizable also and skinable with buttons that mirror physical buttons on your phone. Its not a replacement for freefone or other phone connection apps, just something i think is interesting.
Quote: Originally Posted by bmbr View Post
After a nearly flawless run with the 2.x series, I have had nothing but bad luck with 3.x
Today I saw that 3.3 was released, so I grabbed a copy to upgrade and see if it fixed any of the problems I was having only to encounter an even bigger problem right away: no items in the "OPT" menu.
I installed 3.3 over my 3.2 version, launched RR, and clicked OPT. The page count showed "1/ " (no final #), and the menu was completely empty.
I uninstalled RR and LSXVoid, and then reinstalled both. Same issue.
Any ideas?
EDIT: did a fresh download of the installer again, as well as the latest RR installer.. and this time it worked. Maybe an older RR was breaking it? Either way, doin good now!
yeah it sounds like your issues were an old version of RR installed. Pretty much any skin release from me will most certainly require the absolute latest version of RR.
beer replenishment fund
mp3car live search
liquid_smoke is offline   Reply With Quote
Old 03-07-2008, 12:46 AM   #2346
SMKFree
Possible?
very possible, and actually a good idea. I plan on a very small update this weekend (couple kb) so ill tack that on as well.
Music
Phone Settings
ATT Volume Options
Calculator
About
not a flash issue.
Did you have any issues with ilist prior to this release? Do you see flickers on any other screen that uses ilist like the audio screen?
Any Ideas???
before what starts working? Your gps? Or RR? is it hanging? Taking a long time to load?
I have an idea of what i think it could be, but wouldnt be certain unless you posted your debug.txt file (first turn on debug mode in RR via RRConfig.exe)
Do you have a file named zips.dll or something similar in the root of your RR install? if so delete it.
mp3car live search
Old 03-07-2008, 09:06 AM   #2347
TeamRSX's Avatar
Music
Phone Settings
ATT Volume Options
Calculator
About
Quote: Originally Posted by liquid_smoke View Post
not a flash issue.
LS,
I had no problems with ilist prior to 3.3. I didn't notice the flickering on any other screen, other than the options menu. But what is weird about this is that its not happening on all options menu buttons, just a handful. I will try to see if i have the most current directX installed.
** I actually tried to install void 3.3 on another machine and didn't have the problem with the options menu items flickering when ilist is on. So, looks to be to be an update like directx or something.
Old 03-07-2008, 02:50 PM   #2348
TeamRSX's Avatar
Radio Skin
I was just testing the radio skin and noticed a few things. Please note i have a HD radio receiver, but its not hooked up yet as i want to get the visual worked out first.
I have HD Radio enabled in RR_Config, but..
When i select HD Enabled from the music option in the main menu i notice the frequency number gets cut off just on the bottom of the number. I have circled in red where its cutting off.
HD Radio Skin:
WHen i select FM Enabled from the music option in the main menu i notice there is no band button. Not sure why, but the band button is visable when i select HD Enabled, so not sure if there is something else i have to do. Nothing gets cut off when i select FM enabled, but just no band button.
FM Radio Skin:
Other than this looks like everything else is working. Great Job, Best skin out there in my opinion..
Any thoughts..?
Old 03-07-2008, 03:22 PM   #2349
greatwhite's Avatar
greatwhite is an unknown quantity at this point
HD Radio Skin:
FM Radio Skin:
Any thoughts..?
Just a guess:
HD radio has an FM and AM tuner
Silabs, radioshark, et all, only do FM
So......................the band button would be pointless on an fm only capable unit other than filling in the box with something. I'm guessing it the same situ with the blank half button on the hd skin, just nothing to put in there...........
Leonardo Da Vinci
greatwhite is offline   Reply With Quote
Old 03-07-2008, 03:41 PM   #2350
TeamRSX's Avatar
Just a guess:
Ok, Perfect, i wasn't sure as i dont have the tuner hooked up yet.
I just figured you can get tuners with am/fm which are not HD thats why i was wondering why the band button was not visible.
Since i have a HD tuner i will only be using this skin. But maybe its cutting off becasue there is nothing to put there until i hook up everything like you mentioned, but i was just wondering if anyone else had this problem.
I guess i'll have to wait to see if the hd radio is ok when i hook everything up.
Thanks for the quick response.
Old 03-07-2008, 03:46 PM   #2351
have deleted the file named ziplocator.dll working fine so far will update. soon
Old 03-07-2008, 03:50 PM   #2352
greatwhite's Avatar
Nope, mine cuts it off too. And I have the radio hooked up. It's most likely how the eal estate is alloted in the skin. Probably a font size or something similar somewhere. It's never bothered me enough to go looking for it.
About the only usb radio that offers Am is radioshark (also the HQCT), but it's absolutely worthless on am, I had one of those too.
Trust me, radioshark+AM=useless.
Cheers
Leonardo Da Vinci
Old 03-07-2008, 10:02 PM   #2353
I see dead kittens
Quattro's Avatar
thank you
Installed
Old 03-08-2008, 03:41 AM   #2354
SMKFree
its an easy fix, and will come this weekend.
mp3car live search
Old 03-08-2008, 07:03 AM   #2355
mnickolson is an unknown quantity at this point
This may have been covered somewhere but I call my self looking and did not see it. Is the re a way in the Sirius skin to get it to display the channel logo's?
2004 Sport Trac PC Project.
mnickolson is offline   Reply With Quote
HD radio skin for LSX void 3 download hugenius79 RR Skins 36 12-26-2008 02:24 PM
LSX Void Error TeamRSX RR Skins 7 12-31-2007 01:52 AM
Lsx Void Error michael2 RR Skins 4 08-15-2007 10:55 PM
StreetDeck for a 1955 Buick aforget DigitalMods (Scripts / API) 9 07-29-2007 02:01 PM
LSX Void FAQ Cali Wiki Discussion Threads 1 07-23-2007 08:00 AM
Content Relevant URLs by vBSEO 3.3.0
"VaultWiki" powered by VaultWiki v2.5.2.
Copyright © 2008 - 2009, Cracked Egg Studios.Ad Management by RedTyger
