Go Back   MP3Car.com > Mp3Car Technical > Software & Software Development > Front Ends > Road Runner > RR Skins > RR Released Skins
Old 03-22-2008, 02:21 AM   #2401
wakisakisokman is an unknown quantity at this point
auto scrolling feature wont work. Help?
For some reason, the auto scrolling feature included in this skin doesnt seem to work right for me on some of my machines. Having installed flash via IE6 and Opera 9.26, the newest version of roadrunner and version 3.0 of this skin, the menus wont scroll except by using the the buttons (see the video for examples of the kinds of scrolling i am refering to). I would guess that this is caused by something in flash where the mouse clicks are registered on press and not on release or something like that, but i havent been able to fix it.
On other computers the skin works flawlessly. All of the machines are running XP Pro SP2 and are running the default options given in the RR config menus (with the exception of the skin selection).
I am 99% sure this is a software issue, but 3 installs of Windows and 17hrs of work later i have no idea what that issue might be. All of the machines are also running .net 3.5
The only real differences are the hardware in the setups.
The ones that work:
- P4 1.8ghz, 512mb RAM
- VIA C7 2.0ghz 1gb RAM
The ones that dont work:
- Core 2 Duo E6800, 4gb RAM
- Pentium M Centrino 2.0 ghz, 2gb RAM
- Intel Celeron 215, 1gbRAM
I have done my best to read through the pages on this thread so if i missed a solution to this problem...sorry there are a lot of pages to read through. Please help. Thanks.
wakisakisokman is offline   Reply With Quote
Old 03-22-2008, 10:50 AM   #2402
Kimota's Avatar
Kimota is on a distinguished road
Hi wakisakisokman,
I believe the feature you are referring to is "iList" by default it's off in the skin. Make sure its on by going to "OPT">General Options">"Turn iList ON". As you stated make certain you are running the most current version of RoadRunner and Flash.
You also may want to look at this post http://www.mp3car.com/vbulletin/1162638-post2102.html
Good luck
My Install
Kimota is offline   Reply With Quote
Old 03-22-2008, 12:26 PM   #2403
I cant believe it was something so simple.
Though it is strange that the feature seemed to be enabled by default in some cases and not enabled in other cases.
Thank you so much.
Old 03-23-2008, 12:04 AM   #2404
Kimota's Avatar
Thank you so much.
Glad that worked for you , simple things are pretty much all I'm good for...
Liquid quick question in another post, you stated that the audio player has a scroll bar. I have Lsx running on 4 PC's (in love with the skin btw) and don't see the scroll bar on any machine. What I do see are "up and down" arrows as seen below. Is this correct or should there also be a scroll bar? Although a scroll bar would be great for navigating long list.
Name:  Audio Player screen.JPG
Thanks again.
My Install
Old 03-23-2008, 03:46 PM   #2405
SMKFree
liquid_smoke's Avatar
liquid_smoke is on a distinguished road
no the up/down arrows are what you should see. There are no bars. Just bad wording on my part.
beer replenishment fund
mp3car live search
liquid_smoke is offline   Reply With Quote
Old 03-23-2008, 07:45 PM   #2406
refuse is on a distinguished road
Hey LS if you ever get a chance do you think you can apply the ilist on off function to the old audio playlist? It seems to be ilist only. Thanks for the update, everything is working perfect.
refuse is offline   Reply With Quote
Old 03-23-2008, 08:00 PM   #2407
SMKFree
ah, i actually forgot there were even two versions of that. No problem.
mp3car live search
Old 03-23-2008, 08:36 PM   #2408
SMKFree
here is a small fix for the ilist toggle on the OLD audio player. If you dont use the old version of the audio player (if u did u would know) then u dont need this.
unzip the file and place the contents here
skins\LSX_VOID_NIGHT\ALT\Audioplayer\OLD
overwrite existing file.
mp3car live search
Old 03-23-2008, 10:38 PM   #2409
Kimota's Avatar
Hello,
Been trying to find the answer to two question
1. What do the "quickmenu" options do? I.E "Quickmenu left", "Quickmenu right", "Quickmenu center"
2. On the main screen the text that displays the current song being played is cut off at the bottom as seen below. Is there a way to adjust this?
Name:  Main screen.JPG
Thanks ^ ^
My Install
Old 03-24-2008, 02:06 AM   #2410
rgarjr's Avatar
rgarjr is an unknown quantity at this point
Is there another link to download this skin? I've been trying to get it but the page just keeps on saying the bandwidth has been exceeded, pita.
My carpc worklog
rgarjr is offline   Reply With Quote
Old 03-24-2008, 02:40 AM   #2411
SMKFree
Quote: Originally Posted by Kimota View Post
Hello,
Attachment 48712
Thanks ^ ^
The quick menu is the menu you see when you click the top left area where the clock is. You can change where you want the menu to pop up at, left, center or right. Same thing when you click the .NET button.
for the other issue.
Did you change the fonts from the default? I dont see any text clipping here on my end. This is how it looks on my end. If you did change the default fonts, you have to take care to not use a font that has a bigger weight than the defaults, or bigger footprint.
It looks like u are using the same font but some elements seem different for some reason. like the text in the middle where it shows 100% for the volume seems really small to me. The text on the main buttons also seems like its not what it should be.
mp3car live search
Old 03-24-2008, 02:51 AM   #2412
SMKFree
the bandwidth is exceeded.
it happens. I think the downloads for the skin this month were around 50GB. And thats just for my skin. I also host a couple other skins from other people on the same server.
There are no mirrors etc. So for now just have to wait it out till April.
mp3car live search
Old 03-24-2008, 04:18 AM   #2413
rgarjr's Avatar
Could it be possible to up it in rapidshare
My carpc worklog
Old 03-24-2008, 06:30 AM   #2414
Iceman_jkh is on a distinguished road
No. See post here
Iceman_jkh is offline   Reply With Quote
Old 03-24-2008, 06:54 AM   #2415
Kimota's Avatar
Hi Liquid,
Thanks for the quick response was going nutz trying to figure out the quick menu dohh..
As far as the text issue I just realized it only happens on my desktop that I use as a media center with the "ShowWidth=1024" and "ShowHeight=768". If I change the setting back to the orginal "OriginalWidth=800" and "OriginalHeight=480" the text looks fine so it's not really an issue as it looks fine in the car .
Thanks again.
My Install
HD radio skin for LSX void 3 download hugenius79 RR Skins 36 12-26-2008 02:24 PM
LSX Void Error TeamRSX RR Skins 7 12-31-2007 01:52 AM
Lsx Void Error michael2 RR Skins 4 08-15-2007 10:55 PM
StreetDeck for a 1955 Buick aforget DigitalMods (Scripts / API) 9 07-29-2007 02:01 PM
LSX Void FAQ Cali Wiki Discussion Threads 1 07-23-2007 08:00 AM
