Go Back   MP3Car.com > Mp3Car Technical > Software & Software Development > Front Ends > Road Runner > RR Skins > RR Released Skins
Old 04-16-2008, 02:14 PM   #2521
Kimota's Avatar
Kimota is on a distinguished road
G Earth issue
Hello,
I'm having an issue with LSX and Google Earth ver. 4.2.0205.5730. I've tested on 3 different machines and have the same issue note all the PC's have full version of XP sp2 installed. G Earth opens fine but instead of opening to the normal screen where you can see Canada, USA, Mexico etc as seen below
Name:  Google Earth.JPG
It will immediatly turn the globe 180 degree's an fly just off the coast of Hawaii to an altitude of 696ft as seen here. Note this also happens on my CarPC with a working GPS receiver.
Name:  G Earth.JPG
My Install
Kimota is offline   Reply With Quote
Old 04-16-2008, 03:01 PM   #2522
jacksmilzo's Avatar
jacksmilzo is an unknown quantity at this point
this is my problem!!!
help me please!!!!
jacksmilzo is offline   Reply With Quote
Old 04-17-2008, 05:06 PM   #2523
Nickman's Avatar
Nickman is an unknown quantity at this point
Kimota,
That is the default GPS location for Google Earth. From what I know Google Earth is not getting GPS info from RR correctly. Check your com port settings in RR.
Planning (0000000000) 100%
Purchase (0000000000) 100%
Fab/Install (000000000-) 95%
Nickman is offline   Reply With Quote
Old 04-17-2008, 05:13 PM   #2524
Kimota's Avatar
Hi Nickman,
Thanks for the reply I believe the com port is correct as GPS is working fine in iGuidance. I know its a different app but G-Earth works fine in DigitalFX 3.0 even on PC with no GPS receiver, G-Earth will load to the proper screen with USA, Canada, Mexico, etc being visable.
My Install
Old 04-17-2008, 05:20 PM   #2525
Nickman's Avatar
So, can I assume you have Xport working correctly as well?
Old 04-17-2008, 05:20 PM   #2526
brodgar is an unknown quantity at this point
I have the same problem.
--------- Just a thought about the GPS signal. I am using GPSgate to split the signal.
Does Google Earth use the same port as RR or will it need its own port ?
I'll give it a try tomorrow and see if it makes a difference.
brodgar is offline   Reply With Quote
Old 04-17-2008, 05:22 PM   #2527
Nickman's Avatar
I did not set any com port settings for GEarth, so RREarth plugin must get the GPS info from RR.
(edit: What version of GEarth are you running? I have 4.0.2722)
Old 04-17-2008, 05:27 PM   #2528
Oh well that puts paid to that idea.
Back to double checking everything again
EDIT-------- Maybe that could be the problem. I'm using 4.2.0205.5730 with a build date of Nov 13 2007.
I will download the latest one and start again
Old 04-17-2008, 05:46 PM   #2529
Nickman's Avatar
I would actually attempt an older version. I have read 4.0 is less buggy than the latest version. Try oldversion.com
Old 04-17-2008, 05:57 PM   #2530
Hi Nickman,
thanks for the info. I have now downloaded version 4.0.2722 and will give it a go tomorrow.
Old 04-17-2008, 07:10 PM   #2531
Kimota's Avatar
Hi Nickman,
I stand corrected after checking the com port in RR the GPS com port was set to 0(odd iGuidance was still working with GPS) after setting com port to 9 (as listed in device manager) all is well.
P.S When I open G-Earth it immediately flies to current location on GPS. Does yours do the same?
My Install
Old 04-17-2008, 10:46 PM   #2532
hari-bhari can only hope to improve
Quote: Originally Posted by Kimota View Post
Hi Nickman,
you got it. iguidance gps port is set within iguidance and has nothing to do with RR. you have to set RRs port to get GE to work.
as for flying to current location upon startup, thats what it should do. isnt that what you would want....?
hari-bhari is offline   Reply With Quote
Old 04-17-2008, 11:00 PM   #2533
Iceman_jkh is on a distinguished road
Got the latest version working.
For anyone who has had problem with a WHITE SCREEN or missing buttons or all buttons with the same label..... YOU MUST INSTALL THIS VERSION FROM SCRATCH - DO NOT INSTALL OVER THE TOP OF A PREVIOUS VERSION!!!
Delete or completely rename your other version (as a backup).
For me, it installed into /LSX Void 3.0/ (not 3.3 like I was expecting)
How would I place a Next Track label on the Main screen, perhaps under the current song and/or in a slightly faded colour? It would be nice to see whats coming up.
Iceman_jkh is offline   Reply With Quote
Old 04-17-2008, 11:35 PM   #2534
Nickman's Avatar
Thats exactly what mine does. I think it adds some of that WOW factor.
Old 04-17-2008, 11:44 PM   #2535
Nickman's Avatar
Good idea ^ maybe even on the Idle screen.
A file that comes with the skinning utility contains all of the objects you can add. I didn't see a "next track" under "ENUM LABELCODES" in there but you may want to look. Perhaps there is a forum that is more geared towards creating skins.
HD radio skin for LSX void 3 download hugenius79 RR Skins 36 12-26-2008 02:24 PM
LSX Void Error TeamRSX RR Skins 7 12-31-2007 01:52 AM
Lsx Void Error michael2 RR Skins 4 08-15-2007 10:55 PM
StreetDeck for a 1955 Buick aforget DigitalMods (Scripts / API) 9 07-29-2007 02:01 PM
LSX Void FAQ Cali Wiki Discussion Threads 1 07-23-2007 08:00 AM
