Go Back   MP3Car.com > Mp3Car Technical > Software & Software Development > Front Ends > Road Runner > RR Skins > RR Released Skins
Old 04-18-2008, 12:28 PM   #2536
little_devil is an unknown quantity at this point
Hi there, I'm having trouble embeding an application. I'm using lsx void 3.2 and I'm trying to embed my audio advantage control panel. I got it so it opens the program when I click the custom button in road runner but it doesn't embed. Does anyone know why this might be? Thanks
Kyle
little_devil is offline   Reply With Quote
Old 04-19-2008, 09:46 PM   #2537
wywywywy is on a distinguished road
FEATURE REQUEST
Hi LS.
In many of the .skin files, the fonts are hardcoded instead of pointing to the one defined in LSXCOLOR.txt. Is there any chance it can be changed in the next version to point to the one defined in LSXCOLOR.txt? If not, can the hardcoded font be changed to Arial Unicode MS instead?
The reason is, for us Unicode users, non-Latin characters don't display correctly when using Arial (or Arial Black or Arial Narrow). And using Arial Unicode MS would be perfect because it comes with Windows and doesn't affect the current appearance.
Thanks.
wywywywy is offline   Reply With Quote
Old 04-21-2008, 01:18 AM   #2538
pdegameplayer's Avatar
pdegameplayer is an unknown quantity at this point
what do you think i think its pretty cool i still have to get it working but it will add flair to lsx void!
this is on one of the 2 pages that don't have any thing on them
LSX Void 3.3 Gauges Mod
pdegameplayer is offline   Reply With Quote
Old 04-21-2008, 11:25 AM   #2539
TeamRSX's Avatar
TeamRSX is an unknown quantity at this point
I have been using lsx void for a while now, but i notice something when browsing in the video player.
In RR i have the video folder pointing to: c:/videos
This is how i have my directory structure
C:\Videos
|__C:\Videos\Seinfeld
|__C:\Videos\Films
If i select to go into Films folder it works fine and displays all the movies in the film folder, but if i want to go back to the top of the directory (c:\videos) it wont let me, so i can only watch movies in the films folder. I tried using the browse button but keeps me in that folder.
If i restart roadrunner and browse videos it brings me back to c:\videos which it should, but as soon as i click one of the directories it doesn't let me go back.
Is there any way around this?
But, my video still works if i play a video. I am using the build in player and WMC. I am having a problem with the dvd also. When i select DVD i get a blank screen and my player goes into full screen, no sound nothing. If i browse for the dvd it brings me to my video directory (C:\Videos), but there is no opiton to browse drives ie. C:\,D:\,E:\ etc..
So, then i checked in the options to set the Media Paths and made sure all paths were correct as they were, but at the very end of this option where you can define the dvd drive letter, it displayed nothing. When i tried to edit to change to my dvd path letter it did nothing.
Any ideas? I know my codecs works as videos work fine, but looks like the dvd isn't pointing to the dvd drive.
TeamRSX is offline   Reply With Quote
Old 04-22-2008, 12:03 AM   #2540
gagan512 is an unknown quantity at this point
this looks great! can you release it, with LSX's persmission ofcourse, please?
It will make a good addition to the skin.
95 Mustang GT + Mach 460 Audio
Lilliput EBY701 7" TS LCD w/ 4-way arm
BU353 USB GPS
iGuidance 3 + Road Runner + LSX Void2
200W Inverter
Intel Core Duo 1.6GHz T2050, 1GB DDR2, 80GB, DVDRW
gagan512 is offline   Reply With Quote
Old 04-22-2008, 12:46 AM   #2541
Charly is an unknown quantity at this point
Very nice skin the only thing missing is the music controls so you wouldn't have to change it, but very kool indeed.
Charly is offline   Reply With Quote
Old 04-23-2008, 02:48 AM   #2542
SMKFree
liquid_smoke's Avatar
liquid_smoke is on a distinguished road
Quote: Originally Posted by greatwhite View Post
LS:
(hopefully) Small request;
I use cdrskulls joypad 3.1 program for RR. Available here. Basically, it allows you to use a usb joypad to control RR. PLug and play simple, works right out of the box. This is useful in that I have hacked up a joypad and made hard buttons on my dash for RR functions (ie: gps, audio, dvd, fwd, play pause, vol+/-, etc)
But I'm having an issue when calling up the gps screen with joypad. When joypad sends the command to RR to intiate the gps, it loads up just fine in void except there's no script running for the flyout screen. Any idea why this is so or how to fix it? Perhaps joypad 3.1 is sending the command to RR but void goes through the skin commands and brings up the script along with gps?
I'd appreciate it if you'd have a quick look see.
Cheers
which gps app are you running? Im certain the correct command isnt being sent from joypad, but this isnt joypads fault. Void probably has over half a dozen commands that will launch some version of the gps screen.
If your using IG3 or IG4 the command to use is "AP03"
If your using IG2 the command to use is "GPS1"
If your using Mapmonkey the command is "MMGPS"
If your using Freedrive the command is "FREEDRIVE"
Quote: Originally Posted by jacksmilzo View Post
hi, i write from italy
i have a problem with your skin:
i want change resolution to 800x600, i try to change the res in general.ini, but the skin don't change
i had a mistake?
ciao!!!
click the OPT button the on main screen > General Optons> 800x600
i have tyni xp beast edition , but don,t show the option?when i click on opt, show a menu, but without list of option "general, gps ecc ecc
why?
what menu do you see when you click the OPT button? If you see anything that does not this following list, then you have an old version of the skin.
General Options
Media Paths
Music
Video
GPS
Personalize
etc...
If you dont see this list, update the skin to the latest version.
beer replenishment fund
mp3car live search
liquid_smoke is offline   Reply With Quote
Old 04-23-2008, 03:10 AM   #2543
SMKFree
Quote: Originally Posted by wywywywy View Post
FEATURE REQUEST
Hi LS.
Thanks.
humm, ill have to check and see which files may have the fonts still listed. They must be newer files as i remember painfully replacing all the fonts some time ago. Some fonts are required to be what they are specified as in teh .skin file, like the wingding fonts and the special lsxvoid font, these 2 are used for the play arrows and other special characters you see.
Ill do a once over and make sure none all the fonts are doing what they should be.
very cool.
if you get it working, ill add it to the skin as an option.
C:\Videos
|__C:\Videos\Films
ill look into the dvd thing, havnt played a dvd in RR in over a year.
as for being stuck in any folder in the video browser.
Do you see two arrows (up/down) on your Browse button?
Ok, i see the problem. both the up and down arrows have the same command associated with the button.
Grap THIS file and unzip it into the skin, overwrite the old.
mp3car live search
Old 04-23-2008, 05:09 AM   #2544
jacksmilzo's Avatar
jacksmilzo is an unknown quantity at this point
ok!!! the problem of option menu was of RR i have reinstalled!!
I have another problem
don't see a button play but a number
i have a skin version 3.3
jacksmilzo is offline   Reply With Quote
Old 04-23-2008, 06:28 AM   #2545
greatwhite's Avatar
greatwhite is an unknown quantity at this point
That was either a missing font issue or a non-eng version of windows issue. Can't rememebr. It's come up in this thread before. Do a search and it should show up.
Cheers
Leonardo Da Vinci
greatwhite is offline   Reply With Quote
Old 04-23-2008, 08:46 AM   #2546
TeamRSX's Avatar
C:\Videos
|__C:\Videos\Films
Thanks LS.
The dvd problem is resolved. Don't know why it wasn't working, but after i reinstalled roadrunner and the skin it works fine.
In regards to the video browser i do see the (up/down arrows) on the browse button, but i think you are correct in saying they have the same command because they do the same thing.
I will try the fix and am pretty sure it will fix the problem.
cheers
Old 04-23-2008, 09:21 AM   #2547
jacksmilzo's Avatar
ok , i change "non internationalization " in the rr config
bye
Old 04-23-2008, 10:10 AM   #2548
jacksmilzo's Avatar
when i active ILIST che pc is very very very slow....is normal?
I have a epia 8000 (800mhz) + 256mb ram, tiny xp
bye
Old 04-23-2008, 12:04 PM   #2549
BReMFoX's Avatar
BReMFoX is an unknown quantity at this point
Quote: Originally Posted by BReMFoX View Post
What's the latest version of Road Runner? 12/13/07 ??
And i am not getting that options menu you showed me in the picture.
I am getting the old options menu...
Does anyone know how i could solve this problem.
I installed 3.3 and 3.301 over and over again and i still get the old options menu.
I can't turn ilists on.
I even tried to delete the whole skin and reinstalled it.
Same problem again.
Does it have something to do with Road Runner?
And another thing: is there an option to set the speed of the volumebuttons?
I tried to increase the repeat rate of the keyboard, but that didn't do it...
When i try to increase or decrease the volume now, it's going too slow...
| Suzuki Esteem 1.8 GTX | Intel Pentium 4 Carputer | Entertainment On A Higher Level |
BReMFoX is offline   Reply With Quote
Old 04-23-2008, 07:34 PM   #2550
Thanks. I understand about the Wingdings and LSX fonts bit, but they are in places where Unicode characters would never show anyway, so they are okay to stay what/where they are. But if you could replace all the Arial bits, it would be extremely lovely. Cheers.
HD radio skin for LSX void 3 download hugenius79 RR Skins 36 12-26-2008 02:24 PM
LSX Void Error TeamRSX RR Skins 7 12-31-2007 01:52 AM
Lsx Void Error michael2 RR Skins 4 08-15-2007 10:55 PM
StreetDeck for a 1955 Buick aforget DigitalMods (Scripts / API) 9 07-29-2007 02:01 PM
LSX Void FAQ Cali Wiki Discussion Threads 1 07-23-2007 08:00 AM
Content Relevant URLs by vBSEO 3.3.0
"VaultWiki" powered by VaultWiki v2.5.2.
Copyright © 2008 - 2009, Cracked Egg Studios.Ad Management by RedTyger
