04-28-2008, 10:25 PM
#2581
I see dead kittens
Quote: Originally Posted by liquid_smoke
i took a look at your debug file, and it is indeed loading the old version of the options screen.
I also downloaded the 3.301 update and looked in the ExecTBL.ini file and its set up correctly to point to the new options screen.
Have you applied any other updates after the first two links on the first page?
Are you certain you have the latest version of RR. In the options screen (new or old) there is an about screen, go there and tell me the RR version date and also the skin version number you see in the top left and right corners of that screen.
also, post your ExecTBL.ini file that is inside of the skin.
In the mean time, try to re apply the 3.301 update
LS, I just did a reinstall last week and I seem to have the same problem.
I'm pretty sure I haven't changed the ExectTBL.ini and I applied the patch.
I'm gonna try to apply the patch again tomorrow and see if it makes a difference.
Installed
Asus A7N8X-VM - AMD Mobile Athlon 2400
512 Ram - 60GB HD - Opus 150w
Lilliput 7" - Rikaline 6010
[00000000000001100010-] 98% Completed
Check Out My Install!!!
04-29-2008, 03:03 AM
#2582
SMKFree
humm, which main menu layout option are you using? Didnt think of this before, but def could be the issue. Since there are so many main menu layouts, its easy for one of them to have not been updated properly.
Try switching to a different main menu layout and see if the OPT button goes to the correct screen.
04-29-2008, 12:32 PM
#2583
Quote: Originally Posted by wywywywy
Hi,
I use Sygic within LSX without any problems.
First of all you NEED to specify the width and height.
But try to do it in an AutoIt script and compile it all as exe file, and launch the new exe file with RR.
Secondly, I would recommend using one the of "empty" buttons instead of the GPS button in LSX.
HTHs.
Oh... I think I'm one of the last CarPc builders out here that hasn't done anything in AutoIT yet... you don't happed to have a pre-built one that I could use... otherwise I guess I'll just finally have to try it out myself!
04-29-2008, 01:46 PM
#2584
Menu lay-out?
I tried changing the visuals if that is what you mean, but that had no succes.
| Suzuki Esteem 1.8 GTX | Intel Pentium 4 Carputer | Entertainment On A Higher Level |
04-29-2008, 09:54 PM
#2585
I see dead kittens
I didn't change the menu layout, its the stock one that comes up by default when u install the skin. Its the one without the iList playlists.
Installed
05-03-2008, 08:59 PM
#2586
Not with me at the moment, but will get it in the next few days.
(If I don't, please PM to remind me.)
05-06-2008, 05:16 PM
#2587
so when i use SIRIUS after hibernation or exit n restart RR all my songs get deleted... and it just plays the basic FOLDER that i started with...
also resume doesnt work and a few other functions are funny
i take Sirius out... keeps songs, loads fine, resume works... sooo i dunno what or why it would cause that
05-06-2008, 11:47 PM
#2588
I see dead kittens
I'm having a problem with the tags on my songs. I don't know if this is a issue with the skin or RR itself, can't really tell as this is the only skin I use. But when I first load a playlist all the tags are fine, after a while (I don't know the exact time or how many standby's) the tags will mess up on some songs. It will show a tag of completely different song or only part of the tag will show. There are other times when the album art will be wrong, it will be of a different album that is in the playlist. I've has this problem with previous version of this skin as well, so I can't exactly pin piont where the problems comes from.
Does anyone else have a similar issue with their tags?
Installed
05-07-2008, 08:22 AM
#2589
i had a very similar problem and i updated winamp and it went away.. but your problem may be different just a suggestion......
05-07-2008, 10:33 PM
#2590
I see dead kittens
I'm running the recommended version by LS. what version are u running?
Installed
05-07-2008, 11:24 PM
#2591
v2.95 it works great but any version of winamp will work from what i can tell some of the updates work better than others but always make sure you have the classic skin enabled or you get errors...
05-09-2008, 04:27 AM
#2592
i have noticed this error also
Quote: Originally Posted by ckny
Just wanted to let you know that the issue was fixed. It turns out I had a folder in my music directory that started with a "_" for some reason. That was coming up as the first folder in the list and because of it, whenever clicking on one of the search letters in the library, nothing would happen. Once I deleted that folder search works fine. I guess it was throwing off the search.
Anyway, if you could let me know what I could put in my exectbl to always start those visuals that would be great.
Also, any way to set the sirius channel logo into the album art cd cover on the main screen? Sometimes I like to exit the sirius skin back to the main screen and listen there to get the compass, etc, and it would be cool to replace the "no album artist" image with the sirius channel logo. Let me know if there are any edits I can make.
Thanks LS!
I noticed the above bug(letter buttons dont work when folders starting with funny characters are present), it usually wont affect music folder etc, but does affect any folder browsing you need to do(setting paths etc), and there are usually more folders to get through in this case.
i am using the latest RR installer - 8-4-2008, although the 'about' section of the skin tells me im using 14/12/2007.
Will this affect anything?
I also have the blank ilists on resume,
and the broken visu problem (I'm off to search forums for where this issue is at).
05-09-2008, 04:32 AM
#2593
Quote: Originally Posted by pdegameplayer
With Great joy i am pleased to release the gauges mod for LSX VOID 3.3
i have gotten permission form both liquid_smoke and JohnWPB (the creator of the DigitalFX skin) and both have agreed to let me do this so here it is...
MediaFire Download
Rapidshare Download
FileFactory Download
there are 4 files in the zip folder...
1. alt_menu_cont.skin
2. GPSsats.swf
3. GPSCompass.swf
4. GPSspeed.swf
to install this just unzip and place all 4 of the files in the
C:\Program Files\Road Runner\Skins\LSX VOID 3.3 or
C:\Program Files\Road Runner\Skins\LSX VOID 3.0
folders happy Carpcing
only a 180 speedo?
i assume thats in mph :P
any chance you could whip up a 260kph speedo for us metric speed demons?
05-09-2008, 08:12 AM
#2594
Quote: Originally Posted by MunkyWrench
only a 180 speedo?
i dint know flash that well i did not make these gauges the creator of the DigitalFx skin did i just integrated them into lsx void but i will see if he has one...
*EDIT*
my god how fast are you going lets see... 260kph = 161mph why on earth would you ever need to go that fast? also 161 Mph does not exceed the speedometer's potential
besides 180kph is fast enough..... unless you live in japan
05-09-2008, 10:33 AM
#2595
Hello there,
I embeed Sygic mlast week with no prob.
Here is what I got in the GPS Path in RR config:
\Sygic\drive.exe -r800x600 -no-safety
The -r800x600 should solve your resolution problem
The -no-safety should avoid you getting the red safety screen when lauching Sygic.
BeuZ
| Thread Tools |
| Display Modes |
Linear Mode
