Go Back   MP3Car.com > Mp3Car Technical > Software & Software Development > Front Ends > Road Runner > RR Skins > RR Released Skins
Old 05-18-2008, 08:04 AM   #2641
jacksmilzo's Avatar
jacksmilzo is an unknown quantity at this point
my problem:
when run a gps soft(sygic), run a IGcontrol in task bar
if a run gps 10 time run 10 igcontrol in task bar and my pc it's very slowly
why, when close gps skin not unload igcontrol?
by
jacksmilzo is offline   Reply With Quote
Old 05-18-2008, 07:15 PM   #2642
greatwhite's Avatar
greatwhite is an unknown quantity at this point
LS,
Think I've got a bug.
When I use the drop down menu to minimize RR, the whole screen goes pink except for a custom maximize button (void graphical format). It's as if my entire destop is pink with no icons. Clicking the maximize button returns RR to full screen no problem.
This is with the latest RR and Void.
I noticed prior to installing the newest void, if I used the drop down menu to minimize, there would be a single diagonal line in pink. Never thought much of it as I never used to minimize RR.
If I click the gps portion of the main window, RR minimizes no problem to the audio bar at the bottom of the screen.
This is on my car pc running XP pro.
Any Ideas?
Leonardo Da Vinci
greatwhite is offline   Reply With Quote
Old 05-18-2008, 07:22 PM   #2643
SMKFree
liquid_smoke's Avatar
liquid_smoke is on a distinguished road
Quote: Originally Posted by jacksmilzo View Post
my problem:
by
thats because you are using sygic but you have the skin setup to use iGuidance. The skin only supports IG, Freedrive,& Mapmonkey by default as GPS choices. If you use something else you will have to do some editing for it to work properly. The reason the igcontrol runs multiple times is everytime you click navi it runs it, but u should still only see once instance of it. But since your not running IG something is likely broken somewhere else.
Quote: Originally Posted by greatwhite View Post
LS,
Any Ideas?
turn on clipping in RRConfig.
beer replenishment fund
mp3car live search
liquid_smoke is offline   Reply With Quote
Old 05-18-2008, 10:25 PM   #2644
Bxsteez will become famous soon enough
After trying for hours to get freefone to work i gave up and am trying RRMobile but the problem i run into is that the software starts up once RRMobile starts up. Can someone point me in the direction of the area with the start up procedures? Or give me some sort of advice on getting phone control through either one of these phone control programs
~The Build Process Begins~
http://www.mp3car.com/vbulletin/newb...you-think.html
~The Build Process Ends~
http://www.mp3car.com/vbulletin/show...completed.html
Bxsteez is offline   Reply With Quote
Old 05-18-2008, 10:43 PM   #2645
I see dead kittens
Quattro's Avatar
Quattro has a brilliant futureQuattro has a brilliant futureQuattro has a brilliant futureQuattro has a brilliant futureQuattro has a brilliant futureQuattro has a brilliant futureQuattro has a brilliant futureQuattro has a brilliant futureQuattro has a brilliant futureQuattro has a brilliant futureQuattro has a brilliant future
Quote: Originally Posted by Quattro View Post
I'm having a problem with the tags on my songs. I don't know if this is a issue with the skin or RR itself, can't really tell as this is the only skin I use. But when I first load a playlist all the tags are fine, after a while (I don't know the exact time or how many standby's) the tags will mess up on some songs. It will show a tag of completely different song or only part of the tag will show. There are other times when the album art will be wrong, it will be of a different album that is in the playlist. I've has this problem with previous version of this skin as well, so I can't exactly pin piont where the problems comes from.
Does anyone else have a similar issue with their tags?
After some testing, I believe the problem I'm having is skin related. I've been using the Shock skin for a couple of days and did not see anything similar to what I described above. then toaday I used void and I had a song by mario where the tile was correct but the artist and album art was of alica keys. I switched to shock and everything was correct and then I switched back to void and everything was correct then.
LS, any ideas of what might be happening?
Installed
Asus A7N8X-VM - AMD Mobile Athlon 2400
512 Ram - 60GB HD - Opus 150w
Lilliput 7" - Rikaline 6010
[00000000000001100010-] 98% Completed
Check Out My Install!!!
Quattro is offline   Reply With Quote
Old 05-19-2008, 05:55 AM   #2646
greatwhite's Avatar
thanks. I'll check it out.
cheers
Leonardo Da Vinci
Old 05-19-2008, 02:11 PM   #2647
Jesus Freak
antimatter's Avatar
antimatter is on a distinguished road
Thanks bud. I appriciate your help
Quote: Originally Posted by Ramanator View Post
If I understand you right, Find this Line>>/DEFINE GOOGLEVIDEOWEATHER "googleplayer.swf?docId=5527390467850863231&hl =en" in LSXCOLORS.txt and replace it with (San Francisco)
"googleplayer.swf?docId=5711754632996851703&hl=en"
Hope this helps you out antimatter. In addition, I have mine coded for the Detroit area and it loads weather from last summer. Its most certainly not 80 degrees and sunny here.
antimatter is offline   Reply With Quote
Old 05-19-2008, 02:12 PM   #2648
Jesus Freak
antimatter's Avatar
unfortunately for those looking into the weather forecast videos. They no longer are being updated, so even when u do change it from the default chicago, it will be old data in the video. So this feature will likely be removed or replaced if i can find a good replacement.
Damn!
I would like this feature so if anyone has any input please post
Old 05-19-2008, 03:12 PM   #2649
greatwhite's Avatar
cheers
Hold on.................
The drop down menu is no longer there. I get "notes" when i click on the upper LH corner...........
Problem solved I guess. The menu must be removed in the latest 3.3? I just Dl'd a fresh copy of void the other day, I was running the "old" 3.2 in the car up to today.........
Leonardo Da Vinci
Old 05-19-2008, 05:30 PM   #2650
Ali_2k's Avatar
Ali_2k is on a distinguished road
Hi, first time i tried this skin today, very neatly executed, i tried the older versions through to 3.3, and would be interested to know if you are going to bring back the "finger sliding scrolling" menus in future versions? that was one of the key things that really drew me into it, made the skin much more dynamic than just a point and click system u know.
[edit] also, ive been having trouble with embedding visualisations, i had it working on previous skins but now it just dosn't want to remove that border, did anyone come up with a solid solution? and one last question to LS, when the Vis works, is it intended to sit behind the UI/buttons? if so, how? lol
all the best
ali
Ali_2k is offline   Reply With Quote
Old 05-19-2008, 05:34 PM   #2651
eric_barcus's Avatar
eric_barcus is an unknown quantity at this point
for the finger scrolling it is the ilist feature in the menu go to
-opt
--general options
---then almost ll the way down to turn ilist on
enjoy!
eric_barcus is offline   Reply With Quote
Old 05-19-2008, 05:40 PM   #2652
Ali_2k's Avatar
-opt
--general options
enjoy!
hah.. yeh, just worked that one out... its been a long day :P
cheers tho
on the topic of ilists, can i remove the "static" buttons that are used when ilists are disabled seeing as i wouldn't use em now?
2k
Old 05-19-2008, 06:37 PM   #2653
hari-bhari can only hope to improve
is anyone having problems with the new installer? everytime i try to unpack it on my carpc, it stops at one of several files. usually its vista.pdd but sometimes its one of the background.jpgs or the diskcheck.exe (or is it harddisk.exe) file. i have tried redownloading several times, but with the same results. i tried unpacking the same file on my other pc and it works fine. so i reinstalled xp pro from scratch, ran a chkdisk and tried again with the same result. weird thing is that if i unpack the older void 3.0 it works with no problems. what could be going on, any ideas??
hari-bhari is offline   Reply With Quote
Old 05-19-2008, 10:24 PM   #2654
Nickman's Avatar
Nickman is an unknown quantity at this point
LS -
I don't know if you have seen this, MeHere, program. http://mehere.glenmurphy.com/ . This adds moving GPS traking to GoogleMaps. Its free. I think the ability to track movment on a searchable map is paramount. Since googleearth has given many much grief, I thought this may be a useful addition.
nm
Planning (0000000000) 100%
Purchase (0000000000) 100%
Fab/Install (000000000-) 95%
Nickman is offline   Reply With Quote
Old 05-19-2008, 11:37 PM   #2655
Quick question has anyone got avs to continue running in the background when you switch screens?
HD radio skin for LSX void 3 download hugenius79 RR Skins 36 12-26-2008 02:24 PM
LSX Void Error TeamRSX RR Skins 7 12-31-2007 01:52 AM
Lsx Void Error michael2 RR Skins 4 08-15-2007 10:55 PM
StreetDeck for a 1955 Buick aforget DigitalMods (Scripts / API) 9 07-29-2007 02:01 PM
LSX Void FAQ Cali Wiki Discussion Threads 1 07-23-2007 08:00 AM
