Go Back   MP3Car.com > Mp3Car Technical > Software & Software Development > Front Ends > Road Runner > RR Skins > RR Released Skins
Old 05-21-2008, 10:57 PM   #2671
super-fly's Avatar
super-fly is on a distinguished road
my library is: main music folder>artist folder>album folder. The album folder then contains the songs as well as the album .jpg. I believe this is correct no?
super-fly is offline   Reply With Quote
Old 05-21-2008, 11:07 PM   #2672
I see dead kittens
Quattro's Avatar
Quattro has a brilliant futureQuattro has a brilliant futureQuattro has a brilliant futureQuattro has a brilliant futureQuattro has a brilliant futureQuattro has a brilliant futureQuattro has a brilliant futureQuattro has a brilliant futureQuattro has a brilliant futureQuattro has a brilliant futureQuattro has a brilliant future
Quote: Originally Posted by Quattro View Post
After some testing, I believe the problem I'm having is skin related. I've been using the Shock skin for a couple of days and did not see anything similar to what I described above. then toaday I used void and I had a song by mario where the tile was correct but the artist and album art was of alica keys. I switched to shock and everything was correct and then I switched back to void and everything was correct then.
LS, any ideas of what might be happening?
Quote: Originally Posted by liquid_smoke View Post
cant say ive seen this before. What version (version date) of RR are you running?
Nevermind, my problem is not related to just your skin. I happened with the shock skin today as well, a few times actually. So, this problem starts to happen after a few days use of the same skin and it fixes if I change the skin to a different one. Maybe RR related, idk.
Installed
Asus A7N8X-VM - AMD Mobile Athlon 2400
512 Ram - 60GB HD - Opus 150w
Lilliput 7" - Rikaline 6010
[00000000000001100010-] 98% Completed
Check Out My Install!!!
Quattro is offline   Reply With Quote
Old 05-22-2008, 11:57 AM   #2673
serveradmnstrtr is an unknown quantity at this point
Audio Controls in GPS Screen
I've read over the thread in the last few days so please bear with me if I've missed it as I've tried using search.
I have my screen set to 800x600 (Monitor won't do 800x480 correctly) and when I enter into iGuidance through RR the audio controls that load are right ontop of my 'Zoom In' button. How can I change the position of the 'AUDIO_CTRL' script to move it down so it is not in the way? I remember it possibly being embedded into the skin but I'm not entirely sure. Any help would be greatly appreciated and as always, amazing skin!
I checked in RRSkinEditor to see if it was in the External_GPS_FS skin but I don't seem to see it there, possibly in some .ini file? Thanks again.
-Server
serveradmnstrtr is offline   Reply With Quote
Old 05-22-2008, 12:12 PM   #2674
Bxsteez will become famous soon enough
This might be something obvious but did you check if you change the external gps skin layout and see if the problem is still there?
Go into options and then gps i believe and u can change the layout of the gps screen.
~The Build Process Begins~
http://www.mp3car.com/vbulletin/newb...you-think.html
~The Build Process Ends~
http://www.mp3car.com/vbulletin/show...completed.html
Bxsteez is offline   Reply With Quote
Old 05-22-2008, 12:24 PM   #2675
Thanks for the reply but it had to do with where the Audio_ctrl script loaded as in x,y coordinate in the FS layout. I managed to track it down in the ExecTBL.ini file and saw that it read '500 280' so I changed it to '500 400' and it was perfect. Next time I'll try digging around some more before I post. Thanks anyway.
-Server
Old 05-22-2008, 08:39 PM   #2676
eric_barcus's Avatar
eric_barcus is an unknown quantity at this point
quick one guys, when on the mixer screen should the EQ presets be saving volume too cause it is on mine is there a way to disable this? where does the eq setting saved?
eric_barcus is offline   Reply With Quote
Old 05-23-2008, 09:54 AM   #2677
MGD
MGD's Avatar
MGD is on a distinguished road
When you click and hold the buttons for presets, it will save all sliders like winamp volume, preamp, wave, aux and all others. You can not disable any of those. When saved, RR creats a file with the name of the presets like BASS.pst and so on.
MGD is offline   Reply With Quote
Old 05-23-2008, 06:21 PM   #2678
Twisty is an unknown quantity at this point
Iguidance Onscreen keys
Hi I have searched and struggled and can't seem to find out how to turn off the native iGuidance buttons.
I have both the LSX menu buttons and the iGuidance buttons on screen at the same time
Can anyone point me in the right direction. In the meantime I'll continue to search
Cheers
Twisty is offline   Reply With Quote
Old 05-23-2008, 07:49 PM   #2679
greatwhite's Avatar
greatwhite is an unknown quantity at this point
Do you mena the iguidance buttons or the void IG buttons?
I don'think you can turn off the IG buttons from within IG.
I got rid of mine when I used IG3 by using reshacker to relace teh image with a 1x1 pixel image. If you just remove it, IG will crash.
I haven't treid it in IG4 yet.
As for the Void buttons, it's run from a script if i recall. If you kill that, you might get rid of the buttons. Not sure though, and make sure you copy any files before you delete or change them.
Good luck.
Leonardo Da Vinci
greatwhite is offline   Reply With Quote
Old 05-23-2008, 07:51 PM   #2680
greatwhite's Avatar
Hi LS,
HAs there been any developement on the day screen option?
I gave up on modifying void a while ago, but am taking another stab at it:
That's about a half hours worth of work. Mostly using "ctr-I" and adjusting the lsxcolors file.........
I have to work on bringing back some orf the contrast and testures of the "dark" void though. Shouldn't be too hard with the original as a template..................
Leonardo Da Vinci
Old 05-23-2008, 09:57 PM   #2681
Raw Wave
treetop777's Avatar
treetop777 is an unknown quantity at this point
Video Browser Cover Art not showing
Found a few references to this problem but no definite answer. When i first go into the video browser, one of the cover arts within the highlighted folder shows up but when i browse inside that folder, the art don't show; all that shows is those arrows.
The jpgs are named like this:
Artist - Song.avi
I tested changing the name to Artist - Song.jpg (without the .avi) but nothing.
I have icons turned-on and running the latest rr. The art shows fine in other skins.
I wander what it is?
treetop777 is offline   Reply With Quote
Old 05-24-2008, 12:09 PM   #2682
Yes i meant the ig buttons, time to investigate reshack
Thanks for the tip!
Cheers
Old 05-25-2008, 01:45 AM   #2683
hari-bhari can only hope to improve
http://www.mp3car.com/vbulletin/soft...reshacker.html
Thanks for the tip!
Cheers
hari-bhari is offline   Reply With Quote
Old 05-25-2008, 02:04 AM   #2684
then were can we find these .pst files? i mean ill do a search on my computer but i figure they have to be editable somehow, we can just leave winamp vol alone, i mean in the winamp application its self the presets are not saving the winamp vol and i think its silly the skin saves them when all your trying to do with eq is change the individual bands not the volume its self
Old 05-25-2008, 02:05 AM   #2685
GREAT JOB GREAT WHITE! id like to see the day skin come to life! id use it! 5*
Quote: Originally Posted by greatwhite View Post
Hi LS,
HD radio skin for LSX void 3 download hugenius79 RR Skins 36 12-26-2008 02:24 PM
LSX Void Error TeamRSX RR Skins 7 12-31-2007 01:52 AM
Lsx Void Error michael2 RR Skins 4 08-15-2007 10:55 PM
StreetDeck for a 1955 Buick aforget DigitalMods (Scripts / API) 9 07-29-2007 02:01 PM
LSX Void FAQ Cali Wiki Discussion Threads 1 07-23-2007 08:00 AM
