05-25-2008, 06:18 AM
#2686
Quote: Originally Posted by eric_barcus
GREAT JOB GREAT WHITE! id like to see the day skin come to life! id use it! 5*
Thanks.
But the real credit goes to LS for making the skin in the first place.
It's not very easy working from the PNG files, it sure would be alot easier if I had the "unflattened" .psd files.
Then I could just adjust the layers instead of the entire image and the resulting "little problems" with that procedure.
I don't think LS will release those though, I've asked before. Understandable, he's got alot of work into it. I wouldn't want to either............"intellectual property" and whatnot.
Cheers
Leonardo Da Vinci
05-25-2008, 11:13 AM
#2687
then were can we find these .pst files? i mean ill do a search on my computer but i figure they have to be editable somehow, we can just leave winamp vol alone, i mean in the winamp application its self the presets are not saving the winamp vol and i think its silly the skin saves them when all your trying to do with eq is change the individual bands not the volume its self
The *.pst files are created and stored in the RR directory. Here is the content of one file.
0
36
15
20
27
31
34
25
19
16
13
10
50
0
655
655
0
0
You're right, the volume should not be saved when trying to set EQ presets. This function is hard coded in RR.
REQUEST:"GUINO, please make it not save the volume sliders"
Thank you.
05-25-2008, 01:12 PM
#2688
0
36
15
20
27
31
34
25
19
16
13
10
50
0
655
655
0
0
Thank you.
AWESOME i wrote that reply LATE last night so i havent had time to work on it yet (Straight to work this morning) but lunch will almost def be in the car editing the file...
(hr later)
this is what ive learned from playing with the file (couldnt find the bass and treb control)
Code:
130 - winamp VOL 255max
31 - preamp 0 max 31 middle 63 off
31 60 hz
31 170 hz
31 310 hz
31 600 hz
31 1k
31 3k
31 6k
31 12k
31 14k
31 16k
50 MASTER BAL 50 is LEVEL 100 is full RIGH
16461 Master VOL 25%
32846 Wave VOL
0 SW Synth VOL
0 Phone vOL
32846 AUX VOL
0 VIDEO VOL
0 Mic VOL
65692 LINE VOL MAX
32846 CD VOL MID
0 Nothing on mine
0 ditto
Mine is mapped to master
AND when i go into the Volume Contol on my computer and then go into the properties and put a check mark next to EVERY input the inputs on the VOL CTRL corrispond IN ORDER to the numbers above starting with the Master VOL
05-26-2008, 02:43 PM
#2689
BTW i did some testing in the car last night and i removed the number below the 50 that stands for "MASTER BAL 50 is LEVEL 100 is full RIGH" and it makes it so that the EQ changes and the VOL stays the same hope this helps you guys, i removed it from all my eq presets and now i have a true eq
05-26-2008, 08:40 PM
#2690
QUESTION: If I am using the GPS OPT for layout number 3 with iguidance WHICH .skin file do i add the NO GUESTURE information to i was looking for gps3.skin but i only see a gps2 and a gps1 skin file
also if anyone has already got the No guesture information for size and location exmple
let me know
05-26-2008, 09:22 PM
#2691
Did all this along time ago, if you hit the button to store the same info, it will save the old settings again.
05-26-2008, 09:30 PM
#2692
can you clear up your response i mean i know that if you edit the .pst file and take out the vol line like i say, then you go back to save the preset it will over write the file that the way the EQ is set up right now in the RR programming
05-27-2008, 11:53 AM
#2693
hey guys just wanted to clarify that BLUE ZX3 says our EQ issue is not a bug with RR but simply a setting in skin itself look here
EQ ISSUE AND FIX
05-27-2008, 10:06 PM
#2694
Quote: Originally Posted by TeamRSX
I was just testing the radio skin and noticed a few things. Please note i have a HD radio receiver, but its not hooked up yet as i want to get the visual worked out first.
I have HD Radio enabled in RR_Config, but..
When i select HD Enabled from the music option in the main menu i notice the frequency number gets cut off just on the bottom of the number. I have circled in red where its cutting off.
HD Radio Skin:
Other than this looks like everything else is working. Great Job, Best skin out there in my opinion..
Any thoughts..?
FOUND A FIX FOR THIS CAUSE IT WAS BOTHERING ME TOO
open up the Radio_Player.skin
look for this code
Code:
L01,191,154,70,43,#COL1WR#,#COL1WG#,#COL1WB#,24,#FONT1#,"FMAM","CENTER"
L01,470,167,40,27,#COL1WR#,#COL1WG#,#COL1WB#,14,#FONT1#,"BYIND;HDACTIVE;=<<=HD||HDSUB","RIGHT"
L01,280,154,170,43,#COL1WR#,#COL1WG#,#COL1WB#,40,#FONT1#,"FREQUENCE","CENTER"
Change the 24 to a 22 and the 40 to a 38 no more choppy choppy graphic,
BUT got a question for LS where is the height of this area defined? the font size is easy one, but is the X,Y,W,H the size of the box that holds the information?
going to play with that now
05-28-2008, 05:24 AM
#2695
Quote: Originally Posted by greatwhite
Hi LS,
HAs there been any developement on the day screen option?
I gave up on modifying void a while ago, but am taking another stab at it:
*image*
That's about a half hours worth of work. Mostly using "ctr-I" and adjusting the lsxcolors file.........
I have to work on bringing back some orf the contrast and testures of the "dark" void though. Shouldn't be too hard with the original as a template..................
dude that is kick ars i like it so you taking on the day skin?
can you pm it to me or something? if not its cool but maby i could make a cool bg for it or something
05-28-2008, 12:10 PM
#2696
look for this code
Code:
I just used skin editor to move things around a bit and resize.
works fine now...........
Leonardo Da Vinci
05-28-2008, 12:12 PM
#2697
I am, sorta...........
Kind of an off time project.
And no, I won't distibute it unless permission is given by LS first.
Leonardo Da Vinci
05-29-2008, 10:31 AM
#2698
would anyone happen to have one of the earlyer versions of this skins graphics? like the one in the "preview" images included in newer versions, theres some menues i think looked better in older versions and would like to replace them.
this is one of the preview images, note how its not so "button" heavy, looks a bit smoother imo:
so yeh if anyone has an older version, or the psd's/images whatever, lemme know
05-29-2008, 01:59 PM
#2699
lmao i have the first version!
05-29-2008, 02:03 PM
#2700
Anyone figure out how to disable the screen saver?
| Thread Tools |
| Display Modes |
Linear Mode
