01-21-2009, 10:13 AM
#2956
Quote: Originally Posted by treetop777
DirectX 7 or above.
I've installed the latest redist for directX now (Nov_2008) but it's still the same!
I click on "Turn iList on" in the OPT part, RR restarts but I still can't flick the playlist in neither the player or the library, I just keep selecting songs as usual!
Is there any way I can check if it's on or do it manually?
--edit--
Hmm, I just installed RR and LSX on my laptop using Vista and the iList works great straight away... what else might I have missed since it's not working in the car?
01-21-2009, 06:08 PM
#2957
Raw Wave
look for (or add) usedx=true in rr.ini
01-22-2009, 05:29 AM
#2958
yup, thats already there, and to be sure I also checked that the dx dll mentioned in the thread was in the system32 folder and registered but still no go!
any more suggestions I can try, what is needed for iList to work, might be something missing in my xp install...
01-23-2009, 07:01 AM
#2959
Hi,
I have the LSX V3.3, I have add the iGo8 GPS application, when I start I see this object :
after I close the iGo8 but this object are append in my windows process :
Please help me !!!
01-23-2009, 12:28 PM
#2960
Quote: Originally Posted by riko
Hi,
Please help me !!!
I had the same thing but with navigon, thats just one of the modes to show the navigation if I'm correct... try pressing the arrow in the top right corned of you screens and then go to the options "OPT", select GPS in the first menu and then choose option 2 or 3 instead of the 1st one
01-25-2009, 07:57 PM
#2961
I seem to be experience a weird problem with the skin. It only occurs on the main page, but there is a big white bar underneat the ATT and OPT area. It's almost like it's missing a part of the skin
01-26-2009, 06:42 AM
#2962
Update flash.
01-26-2009, 01:09 PM
#2963
LSX 3.3 and Vista
Hello,
Do you think than LSX run well on Vista .
I think than i have a problem perhaps with the fonts because i have not all buttons but an other character .
Can you help me please ?
01-28-2009, 01:42 PM
#2964
Jesus Freak
Email
I don't know if this has already been covered but i am trying to access email. It shows the gmail login page. I have a yahoo account. Can someone point out where i change that.
Also what are all the email settings in the options and how do you access them.
I appologize if this has already been covered i did search.
Thanks in advance
01-30-2009, 12:12 AM
#2965
Quote: Originally Posted by Rabid_Child
Update flash.
I updated my flash, and the problem still continues
01-30-2009, 12:18 AM
#2966
Confusion Master
Did you update flash in IE?
If not, do so.
02-01-2009, 08:45 PM
#2967
Whenever I use the volume up or down buttons, it mutes the music instead, but the volume slider still gets adjusted percentage wise. This causes me to have to hold down the play button to unmute it.
Is there a ay to fix this problem?
Thanks!
02-01-2009, 09:51 PM
#2968
try mapping the volume control to 'master' instead of 'all' in rrconfig
02-15-2009, 02:12 AM
#2969
How can i make audio CDs autoplayable?
I turned autoplay on from music options but nothing happens when i put a audio Cd in the drive.
One thing i noticed, is that when i go to page 6d in media options i cannot add a cd/dvd drive letter.The edit button does not do anything.Is this the problem with the cd autoplay and how could i fix it?
02-18-2009, 12:08 AM
#2970
Quote: Originally Posted by GTO
Hi,
I've embedded iGO8 into RR but when I touch a button on the GPS screen iGO looses focus and the map stops drawing. In another forum someone said that if I add ||ACTIVATE;iGO8||" to the end of the NEXT PREV lines in the GPS skin file it will sort the problem.
The thing is that I know nothing about skin files or what to look for.
Can anyone help, maybe show me an example of where this text should be added and which one of the GPS skin files the lines are located?
Thanks.
ps
Sorry for adding to the hugeness of this thread.
add the following line under [debug] in the sys_ph.txt file
render_without_focus = 1
voila, problem solved. however i still don't know how to get it to embed like a normal gps app. right now i have it embedded as an external app and every time i hit a button or change volume, the RR skin temporarily overrides the igo window. what's the proper way to embed a gps app?
| Thread Tools |
| Display Modes |
Linear Mode
