02-18-2009, 03:39 PM
#2971
First off, thanks to Liquid for this sublime yet powerful skin, and all the hard work that went into it.
Second, I need to ask if someone can point me in the right direction: Since I use an offboard processor for audio, I'd like to customize the skin by eliminating the volume/att/opt controls from the main menu in favor of larger album art and maybe even more songs in the visible playlist. Anyone want to start me on the path?
I have too much time and too little aggravation in my life, so I built a carPC. ;)
02-18-2009, 04:24 PM
#2972
640 x 480
Enforcer please help I have a lilliput 8 inch screen that will only display 640x480. all of the skins I try will be off center to the right of the screen. is there any way to center the skin in the middle of the screen?
02-18-2009, 04:28 PM
#2973
Confusion Master
Huh?
Why pick on me?
try editing the general.ini of each skin you want to use.
change
Code:
OriginalWidth=800
OriginalHeight=600
ShowWidth=800
ShowHeight=600
to
Code:
OriginalWidth=800
OriginalHeight=600
ShowWidth=640
ShowHeight=480
02-18-2009, 06:00 PM
#2974
Raw Wave
Shouldn't be too hard. I would use existing graphics like the PICS or GPS2 to build a custom menu.skin.
Off the top of my head, i would start by making a working copy of VOID and then in menu.skin change the header to:
then fire up the skin and see what you see; i'm sure it won't be pretty
From there i would open it in SkinEditor and edit to my taste.
02-18-2009, 10:46 PM
#2975
Quote: Originally Posted by Enforcer
Huh?
Why pick on me?
change
Code:
OriginalWidth=800
OriginalHeight=600
ShowWidth=800
ShowHeight=600
to
Code:
OriginalWidth=800
OriginalHeight=600
ShowWidth=640
ShowHeight=480
Thanks this did the trick
02-19-2009, 12:23 AM
#2976
what do those four images in the top line specify? ive tried messing with them because im trying to shrink down the bottom of skin for the embedded applications by about 10 pixels as the program im using is 800x480 and NOT resizeable. any ideas?
02-19-2009, 12:24 AM
#2977
i have a program embedded in the skin and if ANY transition is enabled, then the program loses focus when using any of the skin's control's such as volume or track changes. basically it flashes away real quick and the skin overrides it, and then the embedded program pops back up on top. this only happens on the third time returning to the embedded application (the first two times it does not flicker). however, if transitions are DISABLED, this does not happen at all. any ideas? i can post a video if you need clarification. thanks!
02-19-2009, 01:40 PM
#2978
Quote: Originally Posted by greatwhite
Another .png for you try!
A littel bit more day visability...................but beginning to loose the "LSX feeling" again.........
I definitely like the white border around the buttons. However, if you select a light colored background, it actually DECREASES the contrast of the text for the playlists, making the song names harder to read. They are still displayed in white and highlighted in red. I wonder if there is any way to change that? I stuck in your LSXcolors.txt file but it just made the speed reading green, which was also harder to read.
02-19-2009, 06:32 PM
#2979
Raw Wave
Those are the graphics the .skin file calls when it loads, they have more to do with the effect when you hover the mouse over a button or the effect you get when you press a button.
They can't adjust size. I have no idea how to do what you're after exept for making a graphic of the right size. Sorry.
02-20-2009, 02:02 PM
#2980
Do any of you have a white bar on the bottom of your LSX void screen below the ATT and OPT buttons?
02-22-2009, 07:42 AM
#2981
Hi there,
I've installed RR and LSX-Skin 3.301 (fresh install) and there are two probs i can't resolve. Maybe it's discussed in this Topic anywhere, but its not easy to find something betweet 200 sites
1st Problem: i can't find any possibility to search for musicfiles. I ever load all my mp3s (about 12000 Files) and want to while playlist playing.
Perhaps i'm only blind, but where is a search-function?
2nd Problem: When i insert a Audio-CD nothing happens, whats wrong there? In Opt-Menu i can' enable Auto-Play and from all the buttons there's no one for audio-CD
Hope anyone can help...
greetings from Bavaria/Germany
02-23-2009, 06:17 AM
#2982
Has anyone modded the skin to work with RRMedia?
02-23-2009, 03:02 PM
#2983
I want that always when i'm on the Mainpage that the Visualisation is on without an extraklick to activate... how can i solve the Problem?
With IDLE funktion the Visu always jumps around an is not between the two volume-buttons
Help please, tried it all the day, nothing worked for me...
02-23-2009, 06:04 PM
#2984
Raw Wave
That's kinda hit and miss, when moving from screen to screen you must turn off the visualization then turn it on again in the destination screen. So for example if moving from the audio player to the menu screen you would have a button (in the audio player) with something like this: B.......MAIN||VISU||VISU
Tha's assuming you have the vis on in the audio player.
02-28-2009, 10:48 PM
#2985
Hey,
Im trying to install this with "Ride Runner" but am having issues, it keeps freezing while installing a phone.swf (or something similar) if I remember rightly, does anyone have any ideas on this one?
Cheers
| Thread Tools |
| Display Modes |
Linear Mode
