03-25-2009, 05:30 PM
#3001
Raw Wave
Quote: Originally Posted by stylz
Im having torubles with the audio player. When I select a song, nothing happens. I cant play anything. I tried the latest version of winamp, and also 5.13. I tried the last stable version of Road Runner and the new Ride Runner. All my paths are correct, any ideas?
Try RRconfig, music tab, page 1, audio file types (lower right), add them.
03-27-2009, 06:38 PM
#3002
Problems with new RideRunner?
I recently updated to the new RideRunner and now have problems with Void 3.301. After install it will work fine for a few days. Then, when I turn on the pc, I get a pop-up message from void asking me if I want to take a guided tour. After I click on the pop-up, all the changeable buttons turn to "Audio." It's happened about 5 times now (after un-installing and re-installing). Here's a break down of my system to better understand my problem.
- 30Gb SSD SATA HD partioned into a 5GB (operating system) and 25Gb (media). The 5Gb partition is non-writeable (unless I disable it) and the 25Gb is writeable.
- The OS is Windows XP with minlogon and EWF. I installed Winamp, RideRunner and iGuidance 4.0 onto the writeable 25Gb partition so I can save where I left off with my music and save my favorite destinations and POIs on iGuidance. They are located at D:\Program Files\ and RR Config is setup to look at this directory for them.
Software/driver setup:
- Winamp 5.13
- RideRunner 3/01/09
- LSX Void 3.301
I'd hate to lose this skin as it is my favorite. But if I can't resolve it, then I have no choice but to scout out a skin that is close to this setup.
Has anyone else ever had issues with all the buttons changing to "Audio"?
Jeeputer Project
- Design <<< 100% >>>
- Construction <<< 99.5% >>>
03-28-2009, 05:04 PM
#3003
OK, I looked into my system a little deeper. I opened winamp locally (without RR) and it turns out that my media library was corrupted. I also had winamp agent installed (forgot to uncheck it when I installed). I Deleted my library (winamp library) and re-installed winamp without winamp agent. Hopefully all goes well.
Griz
Jeeputer Project
03-29-2009, 01:41 PM
#3004
Problem on Installation
Hey everybody.
This question have been posted again but no answers I could find.
Trying to install LSX 3.3 but the installer freazes when reaches 69% trying to install the fonepic.swf.
Any kind of help will be highly appreciated
04-02-2009, 09:36 PM
#3005
update Sirius on main menu's ilist
Is there a line of code I can add to the main menu's playlist (or ilist) to update every minute or so when using Sirius? You can see in the picture that the ilist doesn't reflect the actual artist/song playing on that channel. I highlighted in red the difference. When I go to the Sirius menu, then back to the main menu it will update, but I have to do that every time the song changes.
Jeeputer Project
04-02-2009, 09:56 PM
#3006
Raw Wave
Yep, happens with album art too.
Don't know how to fix. I remmember reading something about creating an invisible playlist in menu.skin but this skin already has a visible one so i don't know..
04-03-2009, 05:04 AM
#3007
Confusion Master
does onsongstart work with XM?
04-03-2009, 06:43 PM
#3008
I thought about looking at the Sirius skin file to see what code is used for that list. It will update according to what artist is playing on what channel.
Jeeputer Project
04-03-2009, 09:39 PM
#3009
I have the same problem as well with the "Audio" buttons. For some reason ALL of my buttons just say "Audio" now. Weird?
04-04-2009, 07:54 PM
#3010
when you installed winamp did you uncheck the winamp agent option? After I had that problem I uninstalled winamp then reinstalled it without winamp agent and I haven't had any problems yet.
Jeeputer Project
04-05-2009, 08:32 AM
#3011
I'll try that and let you know how it goes.
04-08-2009, 07:40 AM
#3012
- Winamp 5.13
- LSX Void 3.301
Same problem here... Not sure what happend it was fine for a month. Than turn it on one day and pow!!! all audio tabs. Sucks because i had it all setup to my liking now i have to remember how it was setup...
Bmo
04-13-2009, 06:38 PM
#3013
Quote: Originally Posted by greatwhite
Hi LS.
would it be possible to have ls 3.0 use videolan as the video player instead of MPC or at least have it as an alternative? Or is that more of a RR thing?
I ask because vlc is freeware, open source and plays just about every media format out there. It's very versatile and I've yet to find something it won't play regardless of format or codec required.
Check it out if you haven't heard of it yet (no I don't work there):
http://www.videolan.org/
Cheers
Is it still impossible to get VLC running in this great skin instead of MPC?
04-14-2009, 12:12 AM
#3014
It's possible and I believe there is a plugin out there, but with the codec mpc can play all formats as well.
04-15-2009, 09:26 PM
#3015
Questions
I had some questions about editing some things on the skin.
1. I was wondering if it's possible to edit this so that it shows both the Artist and the Title, but not also set everything to show that way. (I know there is a ID3 playlist option, but that sets everything to use it) Is there a way to customize this?
2. I was wondering if there is a way to change the format of these numbers - for example have "03 - " instead of "3."?
3. This displays "repeat", "shuffle", and "shuffle". I would like to edit this as well, any way to do that? I'd like to because I'd like it to say "both" or something like that instead of shuffle again (when shuffle and repeat are selected).
4. Wondering once more if this can be changed to MPH? Just a format thing, not a big deal, but was wondering if it could be done?
Thanks for any help
| Thread Tools |
| Display Modes |
Linear Mode
