Go Back   MP3Car.com > Mp3Car Technical > Software & Software Development > Front Ends > Road Runner > RR Skins > RR Released Skins
Old 06-10-2009, 02:41 PM   #3061
crowboy164 is an unknown quantity at this point
And my second stupid question i tried searching this ginormous thread but couldn't find the exact info. I am getting the thin video line when opening the new skin with my background surrounding it. i found it is the +gdi setting, but can't fing which .config or .skin file it's located in. THX!
crowboy164 is offline   Reply With Quote
Old 06-10-2009, 05:04 PM   #3062
RoadRunner Mastermind
guino's Avatar
guino will become famous soon enoughguino will become famous soon enough
Did you use the installer ? the installer/rrconfig should register the files required for GDI+ support for you. If you used the installer, then you probably have missing files in the skin's folder.
Ride Runner RR's Myspace
guino is offline   Reply With Quote
Old 06-10-2009, 07:30 PM   #3063
Hey Guino, was still using a MUCH older version of RR...circa 11-06 because it was all tweaked out perfectly, I realized a bit ago that the options are in the new version of RR....guess it's time to bite the bullet and remove, reinstall and reconfigure....
Old 06-11-2009, 04:03 AM   #3064
Super Moderator
JohnWPB's Avatar
JohnWPB is a jewel in the roughJohnWPB is a jewel in the roughJohnWPB is a jewel in the rough
Quote: Originally Posted by free2befast View Post
DigitalFX 4.0 uses 'iList' which needs Adobe Flash.
Just to clear things up..... the iList feature has absolutely nothing to do with flash. It is GDI based. As long as the gdiplus.dll is registered, and iLists are configured correctly (As blue fixed them in a .zip a few posts back for the LSX skin), the iLists will work.
Front End of Choice: Ride Runner (Is there anything else??? ) & Powered by the DigitalFX 4.0 Skin Available at www.JohnWPB.com
My Fiero Build Thread
JohnWPB is offline   Reply With Quote
Old 06-11-2009, 10:58 AM   #3065
guino's Avatar
Back in 06 there was not even support for GDI+ (added in April 07) -- thus none of the newer skins would work with such an old version.
Old 06-12-2009, 06:33 AM   #3066
Yeah, I've figured out that the game has changed a lot, back to Newb status for me. Thanks!
Old 06-12-2009, 07:36 AM   #3067
PsyBlade is an unknown quantity at this point
Thank you to Blue ZX3 for the quick fix, was bugging me for a while
PsyBlade is offline   Reply With Quote
Old 06-12-2009, 08:16 AM   #3068
efun is an unknown quantity at this point
LSX 3.3 works well a minute ago, but now I got such a screen. I restart RR even windows several times but the problem is still there. Nothing was changed in the skin file.
Here is debug.txt
EDIT: The problem was caused by corrupted SKIN.INI
efun is offline   Reply With Quote
Old 06-14-2009, 06:26 AM   #3069
djmickyg's Avatar
djmickyg is on a distinguished road
did you reinstall RR? the new directory riderunner, seems to mess up LSX. i think some of the auto scripts are looking for the road runnner directory
djmickyg is offline   Reply With Quote
Old 06-14-2009, 09:43 AM   #3070
The root cause is that multiple RR instance access make SKIN.INI was in trouble. In normal case, there is only one RR instance, but sometime two RR instance was created (for example, I click the icon twicely on windows start).
Old 06-15-2009, 02:58 AM   #3071
thebigthn is an unknown quantity at this point
LS, hooray! I just started using RR and your skin. But I couldn't get visualizations working until I read through a million pages in this post.
On your first page in post #2, under you FAQ on how to make the visuals work, can you also add for us noobs to go to RR Config>Music>Page 2>Visualization Plugin>AVS Window(select)
I could not for the life of me get this to work until I read post # 1046 and realized that I had milkdrop enabled.
thebigthn is offline   Reply With Quote
Old 06-16-2009, 06:42 AM   #3072
JoseJag is an unknown quantity at this point
I know this issue had been adressed previously but font file isn't available any longer. can anyone please point in the right direction. The botton label font are in italics and any label with six letters or more extends across the botton. Does anyone have a solution?
JoseJag is offline   Reply With Quote
Old 07-01-2009, 04:17 PM   #3073
victornet is an unknown quantity at this point
Sorry to disturb you guys..
but did i missing something on install ?
(used the .exe installer)
Never used another LSX void version..
victornet is offline   Reply With Quote
Old 07-01-2009, 05:11 PM   #3074
Raw Wave
treetop777's Avatar
treetop777 is an unknown quantity at this point
Yes, the fonts didn't install right. Re-install Void or install the fonts manually.
Intel D945GCLF2 Dual Core ATOM
Lilliput 7" 629GL 2008 LED Backlight
BU-353 USB GPS Receiver / iGuidance / IGO8 / Garmin
M2-ATX Power Supply
RideRunner Front End / Various Skins
Windows XP SP3
treetop777 is offline   Reply With Quote
Old 07-01-2009, 05:45 PM   #3075
Ok.. thanks
HD radio skin for LSX void 3 download hugenius79 RR Skins 36 12-26-2008 02:24 PM
LSX Void Error TeamRSX RR Skins 7 12-31-2007 01:52 AM
Lsx Void Error michael2 RR Skins 4 08-15-2007 10:55 PM
StreetDeck for a 1955 Buick aforget DigitalMods (Scripts / API) 9 07-29-2007 02:01 PM
LSX Void FAQ Cali Wiki Discussion Threads 1 07-23-2007 08:00 AM
Content Relevant URLs by vBSEO 3.3.0
"VaultWiki" powered by VaultWiki v2.5.2.
Copyright © 2008 - 2009, Cracked Egg Studios.Ad Management by RedTyger
