Go Back   MP3Car.com > Mp3Car Technical > Software & Software Development > Front Ends > Road Runner > RR Skins > RR Released Skins
Old 09-09-2009, 06:46 PM   #3091
Raw Wave
treetop777's Avatar
treetop777 is an unknown quantity at this point
Quote: Originally Posted by djmickyg View Post
I've made something live been wanting to do for a while, make a day skin. it helps aloe with glare
To use it, download the file here http://www.megaupload.com/?d=QL93PZ2Y
then make a copy of the existing LSX folder and rename it to something like "LSX VOID 3.0 Day" then extract the downloaded file into it and overwrite the files. and it should work.
note the skin settings are stored in the skin.ini so if any changes one made in one, this file can be copied over to match the selling in the other
Worked perfect! The only problem is that the button text is gray (not black) and you can barely see it. Easy fix tho.
Thanks for sharing.
Intel D945GCLF2 Dual Core ATOM
Lilliput 7" 629GL 2008 LED Backlight
BU-353 USB GPS Receiver / iGuidance / IGO8 / Garmin
M2-ATX Power Supply
RideRunner Front End / Various Skins
Windows XP SP3
treetop777 is offline   Reply With Quote
Old 09-09-2009, 08:39 PM   #3092
anuchit is an unknown quantity at this point
Thank you very much DJMICKYG
anuchit is offline   Reply With Quote
Old 09-10-2009, 07:41 AM   #3093
djmickyg's Avatar
djmickyg is on a distinguished road
Thanks for sharing.
was it gray in all the colours? I'll have to recheck that, thanks
I've seen a few other little colours issues as well. one being the up and down arrows in the audio skin aren't showing.
and l Just realized how many spelling mistakes l made in that last post.
djmickyg is offline   Reply With Quote
Old 09-10-2009, 04:32 PM   #3094
Raw Wave
treetop777's Avatar
This is what it look like out the box.
M2-ATX Power Supply
Windows XP SP3
Old 09-10-2009, 07:46 PM   #3095
RipplingHurst's Avatar
RipplingHurst will become famous soon enough
Turn on No internalizatoin in the RR config to fix the font issue
But will it display correctly foreign song/video names? Or it will corrupt my playlist when I mod and save them? I tried of course, it solved that problem, I'm just wondering what is that internationalization for in the first place.
Worklog - 07 Infiniti Fx35 Carputer
Worklog – 06 Infiniti M35 Carputer (sold!)
RipplingHurst is offline   Reply With Quote
Old 09-11-2009, 12:42 PM   #3096
djmickyg's Avatar
try changing the theme. i didn't add the colours config file to the main directory so it's still using the defult colours.
Old 09-11-2009, 06:28 PM   #3097
Raw Wave
treetop777's Avatar
Yep, changing the theme worked! Thanks.
M2-ATX Power Supply
Windows XP SP3
Old 09-27-2009, 07:43 AM   #3098
jakal's Avatar
jakal is an unknown quantity at this point
New Video Broswer Skin
Well um after I had to reformat my carputer and installed latest riderunner i noticed my video browser was not working properly anymore. I could not select any tracks in the list properly. I was wondering if anyone had the same problem. So in order for me to fix the problem, i figured out how to modify the audio browser skin to work for my video browser and added a little extra stuff. I can now toggle video shuffle on the skin and search for videos like the audio skin. I'd like to share it but i think i need Liquids permission first. Its amazing what you can figure out using the skin editor. LOL
I also modified my video player skin so that i have a button to switch to my Navi. Only problem I have is that when I am in the Navi screen (I use Garmin with the Garmin OSK skin) and I play a video, it stops after the video has ended and does not continue on to the next one. It only continues to play next video when I go back to the video player. I mostly play music videos in my car rather than mp3s Any help would be greatful.
jakal is offline   Reply With Quote
Old 09-28-2009, 05:21 PM   #3099
Raw Wave
treetop777's Avatar
A shot in the dark: Put "dualmon=true" (no quotes) in rr.ini and see if the videos continue.
M2-ATX Power Supply
Windows XP SP3
Old 09-29-2009, 02:55 AM   #3100
jakal's Avatar
I have dual monitors set to true. If I don't the video will stop playing as soon as i switch to navi. Thanks for trying.
Old 10-10-2009, 03:31 PM   #3101
serveradmnstrtr is an unknown quantity at this point
The "day" skin posted in here is great except for a few little issues that I am having.
I changed the theme to the one I wanted but for some reason there are a few images that arent showing up. Most notable is the 'show selection of track on main screen' the one that has a hover over on the song that is selected... also, in the library browser, the black icons for scrolling the window up and down as well as the pg up/down are missing... i checked the skins directory and all the files are there, they just arent showing up... I have tried different things of the skin but I get the same issue.
Ive been a happy use of LDXVoid for a few years but ever since switching to this skin ive had the problem
serveradmnstrtr is offline   Reply With Quote
Old 10-14-2009, 02:07 PM   #3102
hithere is an unknown quantity at this point
DJ, thanks so much for the day skin, it's a real improvement for me. The only suggestion I have for it (besides admin's, above) would be to make the background color for the main buttons (top row and bottom row) the same as the middle button menus in the individual skins (such as in the sirius skin, the "fav" button), just to increase the contrast for those most important....the middle buttons have a more white backround, while the top/bottom row are a little grey, which decreases the contrast between button background and the black font. Keep the grey in the background graphic, tho, so it looks less like a newspaper overall.
I'd still like to see a way to be rid of the volume up/down controls and speaker graphics on the main skin, but haven't found a way to do it yet. I do volume control and digital processing off-board, and have no need for them, while wishing to use the space for larger album cover graphics and a longer track listing.
I have too much time and too little aggravation in my life, so I built a carPC. ;)
hithere is offline   Reply With Quote
Old 10-23-2009, 05:04 PM   #3103
xanderx is an unknown quantity at this point
Voltage
Hi all
Can somebody help me with lsx void skin to add voltage? In sensore skin I know SFF is for fan speed SFT is for Temp but what is for voltage for speedfan. Ty wery mutch
xanderx is offline   Reply With Quote
Old 10-23-2009, 11:03 PM   #3104
djmickyg's Avatar
I've realized there is a few colour issues with the skin..
i will try and fix them as soon as I can.
Old 10-24-2009, 10:31 AM   #3105
Glad to know it's still being working on.
Throughout my use of the skin I have also found one more quirky thing that may just be a setting. In the old skin, if you go to Menu, all the menu items are listed as plain text and 6-7 fit on the screen. In this skin, it shows one Item for the entire page and i have to scroll down each page for another menu item. Even when clicking 'Change skin' to change to the night skin, it exits RR. Odd
HD radio skin for LSX void 3 download hugenius79 RR Skins 36 12-26-2008 02:24 PM
LSX Void Error TeamRSX RR Skins 7 12-31-2007 01:52 AM
Lsx Void Error michael2 RR Skins 4 08-15-2007 10:55 PM
StreetDeck for a 1955 Buick aforget DigitalMods (Scripts / API) 9 07-29-2007 02:01 PM
LSX Void FAQ Cali Wiki Discussion Threads 1 07-23-2007 08:00 AM
