Go Back   MP3Car.com > Mp3Car Technical > Software & Software Development > Front Ends > Road Runner > RR Skins > RR Released Skins
Old 12-30-2006, 07:15 PM   #31
marazi's Avatar
marazi is on a distinguished road
Quote: Originally Posted by liquid_smoke View Post
works fine for me under Vista. You may have to turn off uac or give the installer permission to copy files. Not system files are copied or modified etc, on xp or vista.
what errors are you getting when running the installer on vista?
ok... no errors... it starts, but stops at 1%... i did run the installer on my xp box without any probs, so i got the skin workin... love it
marazi is offline   Reply With Quote
Old 12-30-2006, 08:06 PM   #32
djmickyg's Avatar
djmickyg is on a distinguished road
Quote: Originally Posted by Gixxer View Post
Alright, stupid question. How do I get the forecast in areas other than Chicago?
Awesome work by the way!!
"Weather Forecast videos from google inside the weather screens. To change the city from Chicago, edit "LSXCOLORS.txt". At the end of the file you will see a bunch of cities listed. Change the first line in this section to the city you want, only the url should be editied."
read LS's first post!
djmickyg is offline   Reply With Quote
Old 12-30-2006, 08:44 PM   #33
Asskick is on a distinguished road
I just installed this skin on my car, but I couldnt get it to work at first, the menus wouldnt appear correctly (like if the rr.ini was incorrect) after doing some tests, i found out that there was a exe script running on background that hanged (ratecheck.exe) If i manually stopped that exe then it loads the menus as specified by the .ini (default one). For now I renamed ratecheck.exe to ratecheck2.exe and that fixed my probs, but not quite sure what else could be cuasing this. I did a clean install on RR and then the skin install. anyone else experienced that? or it was just me??
(RR running on a stripped down version of XP SP2)
My current project
Jetta 2000 MKIV
SP13000/Xenarc 7"
100GB / 512 RAM / GPS / Wi-Fi
Asskick is offline   Reply With Quote
Old 12-30-2006, 10:57 PM   #34
SMKFree
liquid_smoke's Avatar
liquid_smoke is on a distinguished road
ratecheck is the ratings plugin. Did this only happen once or does it always happen. What happens when you try to run it stand alone.
beer replenishment fund
mp3car live search
liquid_smoke is offline   Reply With Quote
Old 12-30-2006, 10:58 PM   #35
SMKFree
Quote: Originally Posted by Sonicxtacy02 View Post
curious as to how ur rating system works
it works the way you made it
mp3car live search
Old 12-30-2006, 11:02 PM   #36
SMKFree
just incase anyone else is little confused on the weather forcast,
on line 106 of LSXCOLORS.txt is the only line you need to modify.
By default it looks like this
Code:
/DEFINE GOOGLEVIDEOWEATHER "googleplayer.swf?docId=-5156785011415695281&hl=en"
this is for Chicago forcast.
To change it to sunny Miami it would look like this
Code:
/DEFINE GOOGLEVIDEOWEATHER "googleplayer.swf?docId=6890858542239244837&hl=en"
mp3car live search
Old 12-31-2006, 12:09 AM   #37
Always does it... right now it just started doing again, i tried on my desktop pc with same results, if I kill the script from the tray, boom the screen finishes rendering (else I just get stuck with a GUI with no usuable buttons)
and if I try to run it directly from the explorer I just get the icon stuck on the tray bar.
My current project
Jetta 2000 MKIV
SP13000/Xenarc 7"
Old 12-31-2006, 12:23 AM   #38
SMKFree
ive never seen that happen before. Is this the first time you're using this skin or did you use previous versions also? The file in question has been used with this skin for quite a while now.
What type of virus scanner are you using ? I know some of them have issues with autoit scripts.
mp3car live search
Old 12-31-2006, 01:07 AM   #39
djmickyg's Avatar
for some reason all my fonts have gone ITALIC not sure why?
it inst set like this in the lsxcolors.txt and i didnt change anything?
it was like this when i first downloaded
Old 12-31-2006, 04:35 AM   #40
SMKFree
none of the fonts are set to be italic, not sure how that can happen. I see your in Au so my guess is there is prob some localization issues with your version of windows and the fonts the skin uses. Which items on screen are in italic, i can try to narrow it down to which font is causing you problems.
mp3car live search
Old 12-31-2006, 06:23 AM   #41
john1701's Avatar
john1701 is on a distinguished road
not compatible with iGuidance 3.1
CAR:2001 Ford Crown Victoria
PC: Acer EEE 900HA with Vista with CF 2.0.
Memory:1G
Drives:160gig
WI-FI:Cingular
GPS:Garmin
Screen:Xenarc 700TSV
The Florida Meets Thread
john1701 is offline   Reply With Quote
Old 12-31-2006, 11:13 AM   #42
Ive used your previous skins without a prob.. as far as the antivirus no AV is running on my carpc (whysacrifice some cpu cycles for something that wont be used on my car ) But as part of the reinstallation, I deleted my RR folder, redownloaded the RR binary, unzipped to c:\rr and installed your skin there. Heres's a copy of my RR.INI if u want to take a look at it
My current project
Jetta 2000 MKIV
SP13000/Xenarc 7"
Old 12-31-2006, 03:20 PM   #43
jewps is on a distinguished road
I seem to have a weird flash issue with the menu.skin screen. Originally when first loading, there was a white box right above where the play, forward, previous buttons were so I looked into menu.skin to see what it may be.
It seems to be looking for LS.swf. Anyone else having this issue? There's a copy of LS.swf under ALT\. Once copied, it doesn't exactly fit the skin. (attached screenshot)
Also, am I the only person having problems non-english fonts? It worked fine with the old LSX's but no matter what I do, I cannot get RR to format the id3 tags within the playlist and audio browser. What youa see in the screenshot is actually the file name. It seems that RR always append 'yt' before as shown in screenshot 2.
jewps is offline   Reply With Quote
Old 12-31-2006, 04:28 PM   #44
TxAxZxZ's Avatar
TxAxZxZ is on a distinguished road
Great Skin LS!!
I am also having the italicized problem. My entire system changed to italicized fonts including LSVOID 2.0. At first I thought it was something localized with my system until I checked out the forum here and found two others having the same problem. I did a restore to a point prior to installing LSVOID 2 and corrected the problem. I reinstalled VOID and the italicized problem is back.
Also, is the GoogleEarth button working or is that for future use? And what is the VOID button used for?
Thanks again for all your hard work and I hope you celebrate with a alcohol induced happy new year. (I plan to ;op)
Griz
Jeeputer Project
- Design <<< 100% >>>
- Construction <<< 99.5% >>>
TxAxZxZ is offline   Reply With Quote
Old 12-31-2006, 04:55 PM   #45
Gixxer's Avatar
Gixxer is on a distinguished road
^^^ Same here with the italics
Gixxer is offline   Reply With Quote
HD radio skin for LSX void 3 download hugenius79 RR Skins 36 12-26-2008 02:24 PM
LSX Void Error TeamRSX RR Skins 7 12-31-2007 01:52 AM
Lsx Void Error michael2 RR Skins 4 08-15-2007 10:55 PM
StreetDeck for a 1955 Buick aforget DigitalMods (Scripts / API) 9 07-29-2007 02:01 PM
LSX Void FAQ Cali Wiki Discussion Threads 1 07-23-2007 08:00 AM
