05-08-2007, 07:41 PM
#736
If I may request a feature update, I ran across the weather videos and I was wanting to see if there was anything for around my area and there wasnt anything really, so I checked out accuweather and there was a long list of cities and a few pretty close to me, close enough to work. Anyway to use their videos?
Quote: Originally Posted by menudude
thank you all for your help minus the useless post by sjlucky...
05-08-2007, 07:51 PM
#737
LS, yea I was getting ready to put the old version back on (once I found a copy).
But it seems (so far it hasn't crashed) that RR added (or changed) how it handles the artist/title ID3 display. It has three options and it defaults to rolling...that caused crashes...the rolling and scrolling causes crashes...but so far the scroll itself does not cause a crash.
I assume that is it...I don't have a working copy of the older version of RR to check, but it is a selection at the bottom of the music section of RR config.
05-09-2007, 02:14 AM
#738
SMKFree
scrolling text has been in RR for as far as i can remember.
No text in the skin should scroll though, as it kills your cpu so i dont use it, not sure why u would see anything scrolling even with it set in rr.ini but i may be wrong. Not sure what the default option for this in rr config is but it could just be incompatible with your machine and u never knew it till u did a new install.
Did you use the installer to install RR or did you manually install? I know the installer sets some options that probably shouldn't be set to the values they are, that may be an issue also.
so everything is cool now ?
05-09-2007, 02:36 AM
#739
SMKFree
i believe the videos actually are from accuweather, even the google ones. If you check the google weather site, its prob updated with more cities since i added that feature, you can prob find a city close to you.
LSXCOLORS.txt is the file that you need to edit to change the url of the forcast video, but they must come from google (else you'll have to edit the .skin file and some other stuff to change that).
Go HERE to see a list of all the forcast videos.
The url for the videos looks like this below.
hxxp://video.google.com/googleplayer.swf?docId=-1513940121655637936&hl=en
you only need the part in bold. When you look at the LSXCOLORS.txt file (bottom of file) you will see how it works, just edit the line that starts with
/DEFINE GOOGLEVIDEOWEATHER
to link to the video you want to use.
05-09-2007, 09:00 PM
#740
Nevermind...it wasn't the text scrolling (like you said)
I had to wipe out that RR install, and reinstall the older one.
05-09-2007, 10:08 PM
#741
so, i'm completely confused, i went to the link on the first page so I could try out your skin, and i cant do anything. Is it possible your site is being dumb or just me.
(\__/)
(")_(")
I have a Worklog, but I have to take pictures as it's completely out of date now.
05-10-2007, 06:19 AM
#742
As of this morning it appears to be broke.
You would normally be able to click on the LSX VOID image and get into the site.
05-11-2007, 01:00 AM
#743
SMKFree
not sure whats going on with that, looks like a botched server move. The site was being moved to another sever the past 2 days, so i guess they screwed it up.
looking into it now
05-11-2007, 02:18 AM
#744
SMKFree
05-11-2007, 11:35 AM
#745
Hi
I just get a radioshark FM/AM receptor and it works nicely with LSX, but i cant make the am works on LSX is there the option tochange freq and listen to AM??
Design [000000000-]90%
Parts [000-------]30%
Installation[----------]0%
Integration[000-------]30%
05-11-2007, 12:02 PM
#746
Quote: Originally Posted by symon_say
Hi
Someone already had this issue. It had something to do with a patch. Search this thread to find the cure.
05-11-2007, 02:01 PM
#747
i did but the only answers i get where about sat radio, or to short when i put AM, could someone help me with this.
PS: Thanks.
05-11-2007, 03:23 PM
#748
PS: Thanks.
*Sigh*
Fourth result on the list after one search:
http://www.mp3car.com/vbulletin/road...ml#post1039172
worked for this guy.
Good luck
05-12-2007, 11:55 AM
#749
Quote: Originally Posted by greatwhite
I found that threat but in my LSX i dont even have am/fm button :s, the radioshark works nice, but i cant make it work for what i buy it, to have am.fm
05-12-2007, 04:44 PM
#750
SMKFree
humm, ill look into this, i dont have the hardware for radio and wasnt aware it did AM in RR also, so if a button needs to be added ill add it.
| Thread Tools |
| Display Modes |
Linear Mode
