05-19-2007, 12:44 AM
#781
something like this
(\__/)
(")_(")
I have a Worklog, but I have to take pictures as it's completely out of date now.
05-19-2007, 08:58 PM
#782
SMKFree
you mean like this
Dont worry about it, in the next release google earth will be fully supported!
05-19-2007, 09:54 PM
#783
yup, that's the stuff, i look forward to rooting around in your code when you get it up.
(\__/)
(")_(")
05-19-2007, 09:57 PM
#784
that google earth looks pretty sweet. I had a hard time getting GE to work in void2, but I didn't try that hard to make it work either. iguidance works fine, so the only real motivation to change is the real pictures instead of drawn maps.
If it's an easy move though, I'll probably do it.
05-20-2007, 02:47 AM
#785
I apologize if this has been addressed before, but I just installed 2.02 and have a small problem with the "Audio" player screen. In the previous version, when it when from Track 1 to Track 2, the track name would highlight with a red bar behind it. It doesnt do that anymore. It'll just stay behind the first track even though it goes through the whole play list..
Any ideas?
05-20-2007, 03:03 AM
#786
looking real good.. cant wait..
What program are people using to cache the GE maps?
there is a few out the now.. but i havent had much luck with any of them
05-20-2007, 03:22 AM
#787
SMKFree
Any ideas?
open RRConfig.exe and make sure "Highlight current playlist song on change" is checked.
05-20-2007, 03:30 AM
#788
SMKFree
dont think of it as a replacement for IG or any other navigation software for that matter. Its more of a companion and further more its mostly for show than anything else. The way i have it setup is to work alongside IG.
Its not super usefull either way as a lot of the features arent accessible when embeded into RR.
To be honest i would rather see google maps more integrated, im not a huge fan of GEarth, but people have been asking for it so its in there.
05-20-2007, 06:51 PM
#789
is there a way to run a program from RR with arguments?
For example if I were to write C# code it would look like this:
System.Diagnostics.Process p = new System.Diagnostics.Process();
p.StartInfo.FileName = @"C:\Documents and Settings\Craig\desktop\WinLIRC\transmit.exe";
p.StartInfo.Arguments = "amplifier power 0";
p.Start();
I want this to run at "LSONSKINSTART", for example:
"LSONSKINSTART","VISU||ratecheck2||RUN;C:\Document s and Settings\Craig\desktop\WinLIRC\transmit.exe amplifer power 0"
I figured you would know if anyone does LS.
Audio - Performance Teknique 5.1 Digital Amp, Kappa Perfect 12" VQ
05-20-2007, 09:37 PM
#790
Duh. I knew it would be something simple. I'll check it out the next time I'm in my car.. Thanks!
05-20-2007, 10:18 PM
#791
Ah, well that's too bad, because I think satellite view is obviously much ebtter than map view if you're in an unfamiliar place. but, whatya gonna do...
Good info, thanks for letting me know.
05-21-2007, 05:45 AM
#792
Confusion Master
p.Start();
From skincommands.txt
Code:
OBS: Anywhere you can run an application you can also specify it's arguments, by using a pipe (|) symbol.
Example: "RUN;C:\WINDOWS\NOTEPAD.EXE|c:\t.txt;NOTEPAD;NOTEPAD"
(The same can be used within the Launch INI files)
05-21-2007, 08:01 PM
#793
Code:
sweet, you the man!
So it would be ....
"RUN;C:\Documents and Settings\Craig\desktop\WinLIRC\transmit.exe|amplif ier power 0"
Is that right??
Thanks!
05-22-2007, 12:22 PM
#794
Confusion Master
Yep
05-22-2007, 07:58 PM
#795
Am I retarded? Where do you download this skin?
http://liquidsmk.net/lsxvoid.htm
that locations gives me nothing but a splash screen.
| Thread Tools |
| Display Modes |
Linear Mode
