Go Back   MP3Car.com > Mp3Car Technical > Software & Software Development > Front Ends > Road Runner > RR Skins > RR Released Skins
Old 05-26-2007, 09:31 PM   #811
symon_say's Avatar
symon_say is an unknown quantity at this point
i'll take number 2.
Design [000000000-]90%
Parts [000-------]30%
Installation[----------]0%
Integration[000-------]30%
symon_say is offline   Reply With Quote
Old 05-28-2007, 09:00 AM   #812
DodgeCummins's Avatar
DodgeCummins
Quote: Originally Posted by liquid_smoke View Post
Im not sure what could be your issue, nothing in the skin would cause your computer to reboot. I dont think RR adds anything to any of your system folders either. I dont use the installer and normally im running beta versions of RR so all my updates are drag and drop.
Its very odd that running IG would stop your crashing. I cant think of anything related that would cause that.
Have you tried loading a different skin like BMV2?
Any odd info in debug.txt?
The computer doesn't reboot. Windows says RR has done something wrong and is being shut down. The BMV2 skin does not crash. If I start IG immediately after starting RR then it does not crash.
So something is being called up when the main window is open that is causing a crash...
current projects
DodgeCummins is offline   Reply With Quote
Old 06-03-2007, 11:22 PM   #813
Cali's Avatar
Cali is on a distinguished road
it sure is quiet in here....
Cali
02 Corvette Z06
CarPC: 8" Zenarc molded in dash, P3 1Ghz CPU in custom Amp/PC box. RoadRunner, IG3, XM, ODBC (HP Tuners), Cameras
Pics/Videos
Cali is offline   Reply With Quote
Old 06-04-2007, 01:06 AM   #814
SMKFree
liquid_smoke's Avatar
liquid_smoke is on a distinguished road
i thought i heard a puddy cat
beer replenishment fund
mp3car live search
liquid_smoke is offline   Reply With Quote
Old 06-04-2007, 06:51 AM   #815
djmickyg's Avatar
djmickyg is on a distinguished road
Maybe it's the calm before the storm...
djmickyg is offline   Reply With Quote
Old 06-04-2007, 10:53 PM   #816
SMKFree
that would be an accurate description.
mp3car live search
Old 06-05-2007, 10:23 AM   #817
CARLOS_CET's Avatar
CARLOS_CET is on a distinguished road
Bring on the storm!
Car PC Progress
(>>>>>>>>>>>>---) 90%
"Don't speak about it, be about it"
CARLOS_CET is offline   Reply With Quote
Old 06-05-2007, 01:39 PM   #818
rigg419's Avatar
rigg419 is on a distinguished road
So, okay here's a couple of questions (probably good for the FAQ too).
1. In my last carpc, I had gotten iguidance 2 to embed perfectly in lsx void. It would close when I pushed the close button (not just move to the background) and I didn't have the window outline.
However, I can't remember how I did that. I've been trying different methods over the last few weeks to repeat my success but so far I haven't really been able to. iG opens and navigates fine, but I can't seem to get rid of the window border, and it won't actually close when I push the close button
2. Also, the playlist saving feature has never really worked for me. I can create playlists, but every time I try and save it in one of the 5 slots, it saves the name but none of the songs in the list.
Any help on those two would be greatly appreciated.
rigg419 is offline   Reply With Quote
Old 06-06-2007, 02:31 AM   #819
SMKFree
1. when you click close you want IG to close completely, exit?
Do you have ignative=true or fals in RR.ini?
From what it sounds like, it seems IG isnt embeded at all when u run it.
A few things to check.
In RRConfig under GPS
GPS Mode is set to external
GPS Path is C:\Program Files\iNav\iGuidance\iGuidanceUMPC.exe|nowarning
GPS Window Name is iGuidance
In RR.ini
ignative=TRUE
Inside the Skin
Click and hold the NAVI button, choose IG3 or IG2 depending on what ver u have installed.
also make sure you arent using any IG helper/launcher apps (like skinbedder etc) they are not needed anymore.
2. Is your playlist path inside of your music path? (should be if not)
Is the playlist file (m3U) completely empty? Have u checked its contents in notepad. How are u going about trying to reload the saved playlist slots? There are about 3 different ways.
Some extra info on how u have RR setup, install path, rr.ini settings etc would help to trouble shoot.
mp3car live search
Old 06-06-2007, 12:42 PM   #820
rigg419's Avatar
In RR.ini
ignative=TRUE
Inside the Skin
I have all the above set the way you mention, except I don't have the =true set in rr.ini. That's probably important eh? LOL
I don't necessarily want it to close so much as when I leve the nav screen and come back to it later, I want the same screen to pop up. Right now, what happens is a new ig.exe loads every time I hit the IG button, which sucks cause the new instance of iG doesn't talk to the gps receiver, and it's wasting resources.
I am using iGmon or whatever the all in one iG app is. I guess I should uninstall that then, cause it seems that you're saying I don't have to do anything to embed it, it should just work. Am I reading that right?
I have iG version 2.1.3 (or something like that), so mine doesn't say UMPC, it just says iguidance.exe|nowarning, which works fine in the sense that I don't get the warning on startup
EDIT: I added the line ignative=TRUE to my rr.ini, and I changed the gpsname to iGuidance (I don't know if that matters) and now everything works perfect. iG opens without the window border (embedded) and fully closes when I push the close button. Amazing, thanks LS. The GPS was driving me crazy the other day when I drove up to LA.
It's weird how entering those few words of text in the .ini can make such a huge difference
Umm, I don't really know. There are two ways I've tried to save a playlist.
First one is I'll create a playlist on the fly from my library. Maybe an album, maybe a compilation, maybe my whole my music folder. Then, I try to save that playlist by pushing and holding the 1-5 playlist button. I then get the dialogue asking me which slot I want to save it in. No matter which one I pick, it doesn't save. It will save the name of the playlist, but then it will be empty.
The other way I've tried is to go into the playlist "manager" (I'm not sure of the name, maybe it's more of a playlist chooser) from the audio screen. I create a playlist on the fly and try to save it there. It seems to save, but when I go back in and try to load it, it's empty.
My setup is pretty standard. I'm running the latest version of both rr and void, everything was setup and saved to the default location(s). "My Music" is the music folder, I'm using winamp version 5.11, with everything default (except I'm using classic skin instead of modern). If it matters, I use EZsync to keep my music updated, and it's installed to the default C:Ezsync.
Sorry, but how do I know where my playlist path is located. I didn't even know there was a path for it. I guess I assumed the skin was just saving a playlist in winamp. There is a folder in "My Music" called "my playlists" which I don't think I created, but it seems to be empty.
On my lunch, I can go out to my car and check any setting in the rr.ini, but for the most part I can't think of anything I changed in there from the default.
Old 06-07-2007, 04:29 AM   #821
HJC
HJC is an unknown quantity at this point
This is THE BEST skin I've tried so far. Modern, customizable, stable, easily modable...PERFECT! So many features, I'm still learning!
Thanks LiquidSmoke!
HJC is offline   Reply With Quote
Old 06-07-2007, 04:32 AM   #822
Purplxd is on a distinguished road
I can't wait for 3.0 so I can change the backgrounds...
Purplxd is offline   Reply With Quote
Old 06-07-2007, 06:25 PM   #823
gr0b1 is an unknown quantity at this point
Exclamation Rar archive is corrupt
Hi there, your skin looks so great. I have tried downloading it 4 times now, thru ie, firefox and twice thru download managers, the file is corrupt for sure. Hope you can fix this soon, i can t wait to try it. Cheers and thanks for all your time and dedication?
EDIT: Repair file with winrar if corrupt. Shortcut "ALT+R"
gr0b1 is offline   Reply With Quote
Old 06-07-2007, 06:28 PM   #824
dungut is an unknown quantity at this point
i had this problem too. Use the repair function in win RAR, and it will create a new (non-corrupt) rar that will extract properly. This skin is GREAT!
dungut is offline   Reply With Quote
Old 06-07-2007, 06:44 PM   #825
Re about corruption
thanks for such a fast reply. I had just tried reparing and it worked for me too. i came back to post and say it just needs repair but you were just to fast lol.
Problem solved. used repair in winrar
HD radio skin for LSX void 3 download hugenius79 RR Skins 36 12-26-2008 02:24 PM
LSX Void Error TeamRSX RR Skins 7 12-31-2007 01:52 AM
Lsx Void Error michael2 RR Skins 4 08-15-2007 10:55 PM
StreetDeck for a 1955 Buick aforget DigitalMods (Scripts / API) 9 07-29-2007 02:01 PM
LSX Void FAQ Cali Wiki Discussion Threads 1 07-23-2007 08:00 AM
