06-08-2007, 03:47 AM
#826
Hi,
Anyone got a mirror link please?
The official download keeps giving me CRC errors
Thanks.
06-08-2007, 03:50 AM
#827
Quote: Originally Posted by wywywywy
Hi,
Thanks.
use repair function in winrar. "ALT+R" worked after repair for me
good luck
#828
SMKFree
humm, not this again.
Well its cool the repair works, im not sure what issues may arise from the file being damaged, then repaired.
Ill upload the file again sometime this weekend.
Or i could just upload 3.0, technically its done but not ready yet.
I actually have to do a content review to make sure everything i intended to include is there and all known bugs are fixed. The todo list (posted earlier) is empty. Currently trying to find the source of a lock up that only happens on my carpc.
But other than that i think its ready. Of cource i wont fully know till i go over all my notes and threads here to make sure i didn't miss something i promised i would include/change/fix etc.
debating on using an installer or not, its technically not needed as the structure of the skin has changed and a simple drag and drop will get the skin up and running. All config options are inside the skin, no need to add anything to rr.ini (at least not for the skin to function) but its so much easier when inside the car to just click, next, next, done. Instead of opening explorer and copying , pasting etc. maybe ill write a pretty utility in autoit to copy the skin over, who knows.
I wont be home at all this weekend so there wont be any activity till late sunday.
06-08-2007, 03:54 AM
#829
Yes, version 3.0 please!!!!
06-08-2007, 03:55 AM
#830
Thanks for the tip.
Just downloaded and installed Winrar, on repairing it did find some recoverable errors and then recovered them. I can now extract the archive correctly.
But the installed gets stuck at 0%  Which I guess must mean the executable is still corrupt...
Think I'll wait for 3.0!
EDIT:
By the way, ever considered using the NSIS installer instead? (I.e. the opensource Winamp installer) It is so much simpler.
http://en.wikipedia.org/wiki/NSIS
06-08-2007, 03:56 AM
#831
I found it very usefull to have the installer, it makes it very easy to install even on touch. It also makes it "impossible" to go wrong and it adds to the coolness of this allready way cool skin. think you should keep it but hey it's up to you. Looking forward to trying 3.0 cheers
06-08-2007, 07:25 AM
#832
ooOOOoooOOOooOOOOoo!!!!!!!!!!!!!!!
3.0 is almost here!!!
While an installer is not really nessesary on my test setup on teh desktop, I agree that is nice when dealing with the touchscreen in the car............
:waiting patiently:
Cheers
BJ
Leonardo Da Vinci
06-08-2007, 06:02 PM
#833
i'm using 2.02 right now and THIS SKIN IS AMAZING. i can't wait for 3.0. when do you think you are gonna post it?
06-09-2007, 04:47 AM
#834
i'm grabing videos out of my ipod but media player classic gives me an error and shuts down when try to open another file while the first one is playing. i tried this outside the skin and the same thing happend. Does anyone know why this is?
The only solution i can think of is for the skin to close and re-open MPC upon selection of another video file? i'm pretty sure that's possible i just don't know which file i have to modify.
06-09-2007, 07:06 PM
#835
Sunday's almost here!
I can't stand the suspense!
BJ
Leonardo Da Vinci
06-10-2007, 07:57 PM
#836
I would like this skin to start up with the Iguidance window.
I assume I would use the "onskinstart" command...but beyond that I have no idea where that would go...and what it would say.
Why? Mine still crashes on start up when showing the standard window...but if I quickly start "NAV" then it doesn't crash.
No I can't figure out why, and that is after multiple reinstalls...so for the short term fix (and I use it all the time anyway) I want to start on the Iguidance window.
06-10-2007, 08:08 PM
#837
Where is 3.0!?
A
06-10-2007, 08:28 PM
#838
I did this and it worked for me.
In RR config enter "GPS" as "start command to execute"
It is like the second line on the right when you run RRconfig.exe
Reason: more info
06-10-2007, 09:20 PM
#839
Raw Wave
startcommand=GPS (in rr.ini)
06-10-2007, 10:06 PM
#840
Sunday has come and gone.
No 3.0
Leonardo Da Vinci
| Thread Tools |
| Display Modes |
Linear Mode
