Go Back   MP3Car.com > Mp3Car Technical > Software & Software Development > Front Ends > Road Runner > RR Skins > RR Released Skins
Old 06-27-2007, 01:43 AM   #901
SMKFree
liquid_smoke's Avatar
liquid_smoke is on a distinguished road
Quote: Originally Posted by Stray View Post
2) Where do I have to add "GOTOFIRST||SEARCHLIST" to search the playlist from the start?
which screen do u want this on?
beer replenishment fund
mp3car live search
liquid_smoke is offline   Reply With Quote
Old 06-27-2007, 03:20 AM   #902
wywywywy is on a distinguished road
Hi,
Is there any planned support for FreePhone?
Thanks.
wywywywy is offline   Reply With Quote
Old 06-27-2007, 05:58 AM   #903
Stray's Avatar
Stray is on a distinguished road
Quote: Originally Posted by liquid_smoke View Post
this is intended.
In the audio player u can see more detailed info on track time etc, as well as clicking the track time to reverse the count down.
On the main menu, clicking the track time and track number on the far left and far right of the screen will change the visuals, if u have them on.
I havnt given a lot of thought to these two items since i put them there ages ago.
I think the track slider is a better indication as to how much of a track is left since its more visual than numbers and available on every screen.
If youre hellbent on changing it though, it will require the skin editor and tab bit of patience as there is not just one main menu screen, but upwards of 11, and the way its setup is not how standard skins are setup. So for example, if you just edit the menu.skin file in the root of the skin folder, its possible to loose your changes by choosing a different menu layout in the skin options from within the skin.
Not a difficult task, just something to be aware of before you start editing
Ok, thx. And how about:
"Where do I have to add "GOTOFIRST||SEARCHLIST" to search the playlist from the start?"
Stage 1:[||||||||||||||||||||] 100%
Epia M10000, Lilliput 7' TS (modded), Teac DV28-SL, Globalsat BU-303, Maxtor 40GB 7200rpm, 512 MB pc3200, M1-ATX, Kenwood KDC-W6527SE
Stray is offline   Reply With Quote
Old 06-27-2007, 01:47 PM   #904
Niob's Avatar
Niob is an unknown quantity at this point
warning, im like haf fdrunk right now., hahs
i dont know whats wrong wit ur systm, here is what yourscreen shot lshould look like.
either there is som problem wi ur computer , its not showing any of the dingbat fonts.
you can make a simple test ur self on any skin and change a font towingldings and it will not show. weird, i think us shold try to test on a compter with, normal computer.
man idrunkkk
I hawe the werry same issue on my computer. Screen looks the same. Also thested with that font test skin. And all looks the same.
I run XP-SP2 All fonts installed and checked and tested.
I can use webdings fonts (all of them) in notepad or other programs.
Niob is offline   Reply With Quote
Old 06-27-2007, 01:52 PM   #905
Niob's Avatar
And then after looking at the posts again.. i tryed setting my computer from norwegian regional settings to English UK. And then the fonts showed correctly.
So now the question iss.. how to make em work in Norwegian regional settings? So i can hawe my own regional settings (As this apply to a lot of other applications and programs i use in the car).
And yeah.. forgot to tell you how wonderfull your work are. Truly an artist, and a man of knowing what a scin should feel like Thank you. Looking forward to be able to use it fulltime in my car
Old 06-28-2007, 11:26 PM   #906
SMKFree
I think this is more of a RR localization issue, than a skin issue. Im not really sure as there isnt any way for me to test localization as i only have English windows and english fonts. I know RR is supposed to "work" in other languages but im not sure what u have to do configure this.
The fonts in the skin can easily be changed though, so your not stuck with english fonts if u dont want to use them. Find and open the the text file LSXCOLORS.txt found inside the skin folder. The first 2-3 lines are the fonts that the skin uses.
Let me know if that makes any difference or not.
mp3car live search
Old 06-29-2007, 01:32 PM   #907
Niob's Avatar
Ill give it a try. And se if i can get it to function for me with Norwegian regional.
LSXVoid.
For your information:
I do not run a norwegian XP i run English XP. But put the "region" and keyboard layout to Norwegian. So this can be tested on your system by only changing the region. Keybord layout is not needed to be changed. I did this when i had some bigger issues with RR when i installed the norwegian XP version. So there is some issues there. But Englis version runs great with RR. So that whas an easy choise for my car.
Old 06-29-2007, 01:56 PM   #908
Niob's Avatar
Request:
What about implementing FreeFhone to the skin? I hawe PhoCo upp and running. But i prefere to use FreeFhone actually. As it do not need the phone to be awailable when i boot up the PC for it to be detected at a later time. With PhoCo you need to hawe the phone awailable at boot or it wont find it later at all.. sux :P hehe
Love to be able to start the music or video under conversation in phone. Greate for longer cals in the car or when the kids watch video in the back.
Old 06-29-2007, 05:27 PM   #909
Naesstrom is on a distinguished road
LSXVoid.
hi!
Since it was my old posts u was reffering to earlier I just thought I would say something....
Running most skins or plugins in xp with another regional setting then english is really a PITA... I was having problems with Tripmeter plugin earlier and last it was the GatsoHunter plugin... The only solution that works for me every time is just to set the regional setting to english, and I havnt run into any other problems with it even though Im using it with the rest of the computer in swedish... I can still use the swedish special chars and so on without any problems... if u find another solution please post it!
Swedish site for CarPC's
http://www.bilpc.info
Naesstrom is offline   Reply With Quote
Old 06-30-2007, 12:00 PM   #910
Niob's Avatar
ill sure do so "kjære nabo" if i find the solution
Old 06-30-2007, 07:05 PM   #911
Just want to say its Sunday again!
Old 06-30-2007, 07:42 PM   #912
Confusion Master
Enforcer's Avatar
Enforcer has a brilliant futureEnforcer has a brilliant futureEnforcer has a brilliant futureEnforcer has a brilliant futureEnforcer has a brilliant futureEnforcer has a brilliant futureEnforcer has a brilliant futureEnforcer has a brilliant futureEnforcer has a brilliant futureEnforcer has a brilliant futureEnforcer has a brilliant future
Enforcer is offline   Reply With Quote
Old 07-01-2007, 01:01 AM   #913
I see dead kittens
Quattro's Avatar
Quattro has a brilliant futureQuattro has a brilliant futureQuattro has a brilliant futureQuattro has a brilliant futureQuattro has a brilliant futureQuattro has a brilliant futureQuattro has a brilliant futureQuattro has a brilliant futureQuattro has a brilliant futureQuattro has a brilliant futureQuattro has a brilliant future
LS, is it possible we can get a beta today with absolutely no support until you release the complete version?
Please?
Pretty Please?
With a cherry on top!
I've been using other skins that are half complete for over 2 weeks now, I can't wait any longer.
Installed
Asus A7N8X-VM - AMD Mobile Athlon 2400
512 Ram - 60GB HD - Opus 150w
Lilliput 7" - Rikaline 6010
[00000000000001100010-] 98% Completed
Check Out My Install!!!
Quattro is offline   Reply With Quote
Old 07-01-2007, 10:10 AM   #914
djmickyg's Avatar
djmickyg is on a distinguished road
let the man work his magic in peace!
djmickyg is offline   Reply With Quote
Old 07-01-2007, 11:54 AM   #915
greatwhite's Avatar
greatwhite is an unknown quantity at this point
Unghaaaa!
Sundays are unbearable now!!!
Oh well, it's done when it's done.............
Especially since "ether" will be taking all the mans attention once ver 3.0 is done, I'm guessing.
Cheers
BJ
Leonardo Da Vinci
greatwhite is offline   Reply With Quote
HD radio skin for LSX void 3 download hugenius79 RR Skins 36 12-26-2008 02:24 PM
LSX Void Error TeamRSX RR Skins 7 12-31-2007 01:52 AM
Lsx Void Error michael2 RR Skins 4 08-15-2007 10:55 PM
StreetDeck for a 1955 Buick aforget DigitalMods (Scripts / API) 9 07-29-2007 02:01 PM
LSX Void FAQ Cali Wiki Discussion Threads 1 07-23-2007 08:00 AM
