07-12-2007, 08:13 PM
#931
SMKFree
you will still set the day and night switch time via rr.config but instead of actually switching the skin, it will run a script that will move all the night images into a temp folder and copy all the day images into the skins root dir, along with other time of day specific files.
This of course will only work if the skin is loaded, if you are switching from void to say a different skin it will work normally.
07-12-2007, 09:23 PM
#932
Nice work LS!
I love having the small/big vis on the main screens in the current version.
But if there's something I would like to see added to the big vis option would be 2 small buttons to move forward/backward through the presets.
Currently, changing presets can only be done when using the small vis option and then using the "hidden" buttons for changing presets.
Anyway to incorporate these 2 buttons in the big viz too? This would be extremely handy!
thanks for your great work man, looking forward to 3.0
On a side note, I've worked with software companies in the past and usually "Ver 3.0" is when things really start taking off in a big way. Thats already happened for Void and I'm glad you've made it this far.
Good luck on Ether!
95 Mustang GT + Mach 460 Audio
Lilliput EBY701 7" TS LCD w/ 4-way arm
BU353 USB GPS
iGuidance 3 + Road Runner + LSX Void2
200W Inverter
Intel Core Duo 1.6GHz T2050, 1GB DDR2, 80GB, DVDRW
07-12-2007, 11:35 PM
#933
SMKFree
Quote: Originally Posted by gagan512
Nice work LS!
Good luck on Ether!
Thanks!
If you enable the transparent vis (search for screensaver.ini on the first few post) it will make it so when the vis is enabled you can still click the buttons that are under the visuals, that way you can move through the presets.
07-13-2007, 05:22 AM
#934
Very nice!!! Can't wait!!!
But to be perfectly honest, I prefer the buttons in v2.0?
07-14-2007, 12:22 PM
#935
no you don't (sorry couldn't resist answering the accidental question mark)
(\__/)
(")_(")
I have a Worklog, but I have to take pictures as it's completely out of date now.
07-14-2007, 12:57 PM
#936
Raw Wave
I think he does like them??
07-14-2007, 02:26 PM
#937
Quote: Originally Posted by liquid_smoke
Thanks!
I gotta admit, I've never been able to get the click though vis to work either......even following the instructions at the beginning af the post.
Meh, whatever. It'd be cool, but not nessesary.
LS, is there any point in checking in this sunday?
Cheers
Leonardo Da Vinci
07-14-2007, 04:20 PM
#938
SMKFree
are you using AVS as your visuals or milkdrop? It only works with AVS
07-14-2007, 04:43 PM
#939
AVS.
Leonardo Da Vinci
07-15-2007, 08:57 PM
#940
SMKFree
post your rr.ini and your screensaver.ini and versions of winamp and Road Runner
07-16-2007, 05:38 AM
#941
Winamp 5.13
RR current version
I'll post the rr inin and screensaver ini later.
Cheers
Leonardo Da Vinci
07-16-2007, 08:53 AM
#942
Hello,
I have browsed every pages of this subject, and didn t see any thing about destinator 6. I am trying to embed it. Any tip please?
Thx
07-16-2007, 03:15 PM
#943
You can hold any of the buttons, choose a free one, and change its function.
I do it this way to use D6.
07-16-2007, 03:51 PM
#944
Got it. Thanks
07-16-2007, 10:57 PM
#945
SMKFree
i belive mapmoneky and freedrive are both Destinator based and support is included for both. Just do the above click & hold and choose either mapmonkey or freedrive.
| Thread Tools |
| Display Modes |
Linear Mode
