07-20-2007, 12:06 PM
#961
As always, nice work LS. Can't wait to try it out.
07-20-2007, 02:42 PM
#962
I see dead kittens
Quote: Originally Posted by gagan512
wow, this looks great! its a big visual upgrade from before i'd say.
the notezz feature is pretty neat too.
i like the new(er) audio screen with the songs displayed inside a box with scroll bars on the side, however i was hoping that the font size of the song-names could be smaller.
this is the screen i'm talking about:
I'm pretty sure you can change the font size yourself by editing the ini files
Installed
Asus A7N8X-VM - AMD Mobile Athlon 2400
512 Ram - 60GB HD - Opus 150w
Lilliput 7" - Rikaline 6010
[00000000000001100010-] 98% Completed
Check Out My Install!!!
07-20-2007, 02:47 PM
#963
1 thing i would ask for on 3 is to have a Mute button for the sirius... so many times i just want to turn the sound completely off, phone call or what not... with Audios i can pause and its fine.. but with sirius u cant pause it so i have to hold down the VOL button...
07-20-2007, 08:13 PM
#964
SMKFree
ill take a look into that.
07-21-2007, 07:53 AM
#965
a problem
hi! first of all, congratulations for your amazing skin, from the video it looks very nice!
I have a problem, after I install the skin with your installer, I chose the skin from RR; the skin is loaded but I can't see no buttons except FFW, RWD, +vol e -vol, and that are the only buttons that work! Also, the date is displayed very small.
any suggestion?
07-21-2007, 08:08 AM
#966
any suggestion?
Try a remove and reinstall.
Mine installed once where evey button in the skin was "AUDIO". A fresh install fixed all............
LS, I have a request, but it's a large one so I kind of hesitate to ask........................
There's a post earlier on about MS streets and how to incorporate it into your skin. Could you make Streets an option for gps nav as well as iGuidance? I can easily use streets with your skin IAW the post, but I can't get the seamless intergration into the skin as you can (IE: fly out menu, etc).
iGuidance is good, but streets seems to have nicer options, route planning and graphics than iGuidance. Not to mention more up to date maps (IG is new this year but streets 08 is comming very soon......).
Tall order and a lot of work though................
If not, do you mind if I (kind of) reverse engineer/modify/use your scripts, code, skin, etc in an attempt to incorporate streets into the skin a little better?
Cheers
BJ
Leonardo Da Vinci
07-21-2007, 01:38 PM
#967
radio section of the skin
hi, I fixed the prob instyalling the skin in another pc, it seems that winXp on the other one has some problem, even if I reinstall the skin. but I have another question for you, guys, about the radio skin:
1. does this skin support rds from silabs radios? (I own one of theese and it seems that the skin does not support rds)
2. Is there a way to switch radio station with scan and not by sigle frequency? I ask thid because the default skin of RR supports both rds and radio station search.
thank you.
07-22-2007, 03:35 AM
#968
Did version 3 ever get released?
Cheers
A
07-22-2007, 09:43 AM
#969
Cheers
A
Watch the first post, that's where it will be.............
Cheers
Leonardo Da Vinci
07-22-2007, 04:20 PM
#970
SMKFree
Cheers
BJ
streets by default isnt supported because my thoughts about it are pretty much the exact opposite of yours. I think streets sucks for incar use. I have 05 and 07.
With that said it does have its uses and im not against getting it to work with the skin. It should be fairly straight forward to add as an option.
07-22-2007, 04:44 PM
#971
I agree that iguidance is better in some areas. I prefer the graphics and the ability to see the highway exitson the map as I drive.
I find the route planning to be better as well. The interface is poor for incar use, but a litle reshack action fixes most of it. The gudance pane is a pain though.
However, I am using iGuidance 3 right now for the car. I'm hoping 2008 will be more in car freindly (rumours of a 3d option like iGuidance are floating around).
Meh, to each his own............
Having the ability to access both would be the best of both worlds methinks!
Cheers
BJ
Leonardo Da Vinci
07-22-2007, 04:56 PM
#972
Cheers
Ya wasn't it supposed to be like three weeks ago though?
A
07-22-2007, 05:28 PM
#973
A
Patience grasshopper.................
Smoke's doing this "au gratis" (well, except for donations), it's done when it's done.
Cheers
BJ
Leonardo Da Vinci
07-22-2007, 05:30 PM
#974
Realize that. But when someone says something will be done by a certain time then they set expectations.
Being a project manager by trade, that is a big pet peeve.
A
07-22-2007, 05:35 PM
#975
A
Methinks you may be in the wrong place then.............
And I don't remember a release date, just a 'roundabout time estimate......
Cheers
BJ
Leonardo Da Vinci
| Thread Tools |
| Display Modes |
Linear Mode
