Go Back   MP3Car.com > Mp3Car Technical > Software & Software Development > Front Ends > Road Runner > RR Skins > RR Skins No Longer Supported
Closed Thread
Old 01-26-2006, 12:00 PM   #46
Confusion Master
Enforcer's Avatar
Enforcer has a brilliant futureEnforcer has a brilliant futureEnforcer has a brilliant futureEnforcer has a brilliant futureEnforcer has a brilliant futureEnforcer has a brilliant futureEnforcer has a brilliant futureEnforcer has a brilliant futureEnforcer has a brilliant futureEnforcer has a brilliant futureEnforcer has a brilliant future
Quote: Originally Posted by aal2000
Great job guys. I have installed the skin and it works great. Just two things do not work properly:
1.- Entertainment screen
DVD label is not clickable. The blue side strip is moved form the DVD label. So if you want to click DVD you have to do it in the bootom part of the screen not in DVD label
2.- Speed
I have installed Freedrive and I do not have the speed value next to speed tag when freedrive is working. Do i have to configure any txt file?
Thanks and keep working
Glad you like it. and thanks for the feedback.
1. sounds you have the first zip I put up. I had put an extra DVD label in by mistake. There should be anoither DVD button which works. However the current version is corrected. link in first post.
2. For the speed in freedrive you have to edit the freedrive sdk.ini file and set
FDSPEED=RoadRunner
you also need
FDSATS=RoadRunner
FDMANFULL=RoadRunner
FDCAMS=RoadRunner
for the number of satellites to appear, and the number of cameras (GPS screens) and the location you are at.
cheers Enforcer
Enforcer is offline
Old 01-26-2006, 08:11 PM   #47
os20k is on a distinguished road
problem with iguidance with idrive skin
Hi, first of all, this skin is the BEST!
However, i have two problems.
One of them is that when i switch to full screen in navigation (using iguidance 2.1 NA), iguidance screen suddenly dissapears and gives me blank full screen with contorls on top and bottom. And then if i switch back to normal mode, it shows iguidance screen as normal.
Fullscreen mode works with other skins but not with this one...
Second problem that i am having is that when i go to web browser, internet explorer pops up in different location (every time different location) meaning that it does not show up in right side of the skin in embbed area as it should be.
How can i fix these problems?
Thanks for replying in advance.
os20k is offline
Old 01-27-2006, 04:34 AM   #48
Confusion Master
Enforcer's Avatar
1. iGuidance - The external GPS was set up with FreeDrive in mind at present, as that's what I use. The normal screen works on the settings in RR Config, so if you have set iGuidance up as your external GPS that screen will work fine. Although the Speed and locations info at the top won't show up.
Now for the full-gps skin the settings are in the skin files so it is coded to look fro freedrive, which is why you are getting a blank screen.
Solution : Open external_gps.skin in notepad, and look for the following line
B,000,450,200,050,"LOAD;gps-full.skin;FreeDrive;c:\program files\FreeDrive\FreeDrive.exe;FreeDrive",""
Replace the red FreeDrive with iGuidance
Replace the Green program path with GPS path you have set in RR config.
Replace the Blue FreeDrive with the GPS Window Name in RR config.
2. Browser - strange, I ran it on my PC, the first time it grabbed the ie window and then let it escape. However everytime after that it managed to grab it perfectly.
Questions,
1. do you have a browser window open and it is trying to grab that or is no browser open and it is starting from fresh?
2. what is your home page set to? (not sure if this makes a difference)
Enforcer is offline
Old 01-27-2006, 06:12 AM   #49
Thanks! GPS fullscreen is working now!
And for the second problem, I guess i wasn't clear explaining the problem at first.
Just like you said, it opens IE then it escapes. And, if i go back to it, it grabs it in a proper location. I guess that was normal then.. my bad..
BTW, Keep up the good work~ LOVE THIS SKIN!
os20k is offline
Old 01-27-2006, 06:23 AM   #50
Confusion Master
Enforcer's Avatar
it shouldn't be 'normal', will look into this a bit more, see if it's just this skin or whether it does it on others as well
should be another version with some more screens and the tweaked on/over buttons as per post 38 later today or over the weekend.
E.
Enforcer is offline
Old 01-28-2006, 08:23 PM   #51
Confusion Master
Enforcer's Avatar
Could you post the changes you made that made it work.
ie, what did you replace this line with?
I'm looking onto a way of avoiding this problem for future versions.
Enforcer is offline
Old 01-29-2006, 08:19 AM   #52
I used the rr skin editor and replaced the freedrive line with this one
"LOAD;gps-full.skin;iGPS;C:\Program Files\iNav\iGuidance\iGuidance.exe;iGuidance"
And also in gps-full.skin, i added object parameter C01.
That's all i did to fix the first problem.
os20k is offline
Old 01-29-2006, 10:36 AM   #53
Confusion Master
Enforcer's Avatar
cheers.
did it need the C01 or will it work without.
I try and avoid them if possible.
Enforcer is offline
Old 01-29-2006, 05:54 PM   #54
yeah.. it needed CO1. And I am also planning to tweak the rest of buttons' setting so i can use them with iGuidance as well some time next week unless someone already has it. ANyone?
os20k is offline
Old 01-29-2006, 06:51 PM   #55
Confusion Master
Enforcer's Avatar
Let know what changes you make, then I can incorporate them in future updates. cheers.
Enforcer is offline
Old 01-29-2006, 06:54 PM   #56
Confusion Master
Enforcer's Avatar
Speaking of which,
****** Updated version available *******.
Download link in first post.
Changes
Button over and down on LHS menu now have a 3D look.
Extra screens
CD Rip
Radio - This is untested as I don't have a radio
MapMonkey
TV - This is untested as I don't have TV or camera (yet)
Mobile Emulator iDrive skin also included.
Please read the Readme file (Especially Map Monkey users)
Enforcer is offline
Old 01-29-2006, 07:05 PM   #57
My Village Called
0l33l's Avatar
0l33l is on a distinguished road
New screenshots?
0l33l is offline
Old 01-29-2006, 07:15 PM   #58
Confusion Master
Enforcer's Avatar
Quote: Originally Posted by 0l33l
New screenshots?
Post 38 for the 3D effect on LHS buttons.
Post 25 for the CD Rip (without the 3D effect, use imagination by looking at post 38)
Radio and TV I don't have so won't look right.
Here's Mobile Emulator with the iDrive skin for it and Thunderbirds
Enforcer is offline
Old 01-29-2006, 07:26 PM   #59
My Village Called
0l33l's Avatar
Nice
0l33l is offline
Old 01-29-2006, 09:40 PM   #60
Tainted Love
Cris's Avatar
Cris is on a distinguished road
Yeah, great job E.!
Cris is offline
Closed Thread
Road Runner Installation Program bry21317 Road Runner 88 01-29-2008 10:22 PM
Road RUnner and Navi Voice cdevelasco PowerVoice 23 07-20-2007 01:40 PM
Road runner Ideas (BIG LIST) sephiroth7 Road Runner 9 04-01-2007 10:50 AM
How do I install Road Runner ? guino RR FAQ 0 03-21-2005 03:16 AM
Road Runner Facts... guino Road Runner 13 02-21-2005 12:16 PM
