Go Back   MP3Car.com > Mp3Car Technical > Software & Software Development > Front Ends > Road Runner > RR Skins > RR Skins No Longer Supported
Closed Thread
Old 05-08-2006, 10:40 AM   #31
Raw Wave
tbird2340's Avatar
tbird2340 is on a distinguished road
Me likey!!! Subscribed...
Wife's Vehicle: 2007 Dodge Nitro
Current Vehicle: 2005 Dodge Ram 1500 Quad Cab
First Vehicle: 2003 Ford Ranger
tbird2340 is offline
Old 05-08-2006, 10:49 AM   #32
Civic03's Avatar
Civic03 is on a distinguished road
LS, I'm having a bit of problem (or lack of understanding) about the FS button. When I click it I get full screen (great) but how do I get back to regular screen? When I click the FS button again nothing happens and when I exit it stays running.
Drove in to work today with Nav on and it's ran great. Great Skin.
PROGRESS 95%[//////////]Complete - Software configurations
Current Task: Just adding on...
Needed:wireless keyboard/mouse
My Carputer Blog
Car System Site
Civic03 is offline
Old 05-08-2006, 12:05 PM   #33
SMKFree
liquid_smoke's Avatar
liquid_smoke is on a distinguished road
make sure you copy the KeyTBL.ini file from the first post.
beer replenishment fund
mp3car live search
liquid_smoke is offline
Old 05-08-2006, 12:18 PM   #34
Civic03's Avatar
Copy it where? I copied it to the root of RR, made the changes in RR.ini and deleted the black entries you mentioned. Did I put the KeyTBL.ini in the wrong place?
My Carputer Blog
Car System Site
Civic03 is offline
Old 05-08-2006, 12:21 PM   #35
b8bboi is on a distinguished road
liquid_smoke, just curious. why do you need KeyTBL.ini for the "exit fullscreen" button to work? I mean can't you just execute an "EXIT" command so it can go back?
b8bboi is offline
Old 05-08-2006, 01:06 PM   #36
SMKFree
when you click the exit fullscreen button, it sends the ALT+L shortcut to RR.
In KeyTBL.ini this is bound to the following command.
"ESC||CLOSEWINDOW;EXIT_FS"
so when executed RR exits the current screen and also closes the EXIT_FS application.
This is done in this manner because if it were the other way around, and somehow the script failed to send the command to RR before it closes itself, you will endup stuck in the gps screen with no other way to get back to RR or windows (short of having a keyboard on hand).
the utility has been around since LS3.0, over 6months ago so i know it works, and i havnt modified the files since they were created. Civic double check your setup.
also, with the addition of the new expandable menu button, it maybe best to roll the exitfs utility into this.
mp3car live search
Old 05-08-2006, 01:12 PM   #37
Oh, I see that you wrote that exitfs util before RR's exec.exe exits.
You can certainly do something like this.
Code:
$RR_Path = RegRead("HKEY_LOCAL_MACHINE\SOFTWARE\RoadRunner\Install", "InstallFolder") If $RR_Path = "" Then $RR_Path = "C:\Program Files\Road Runner\" Run($RR_Path & "exec.exe EXIT")
b8bboi is offline
Old 05-08-2006, 01:34 PM   #38
SMKFree
yeah, its pretty old. I think im going to retire it though and roll it into the other utility, that way you only have one button on screen.
mp3car live search
Old 05-08-2006, 02:02 PM   #39
hoodlum can only hope to improve
How would I cut down the features?
Fm, XM, Sirrus, SAT, Ext Apps, M MODE, SKIN, CAMERA, DRAW, SKIN, WIDGETS, Calender. And how do i get WEATHER to work for toronto? or canada.
hoodlum is offline
Old 05-08-2006, 03:43 PM   #40
SMKFree
Code:
is that reg key on everyones machine or does it only get written there if you used the install ver of RR?
mp3car live search
Old 05-08-2006, 03:47 PM   #41
SMKFree
check the faq post at the begining of this thread.
you do know, if you remove the SKIN button you will not be able to change to another skin unless you run rrconfig.exe
also, fyi
the CAMERA button is broken right now.
mp3car live search
Old 05-08-2006, 03:50 PM   #42
SMKFree
second thought, i dont think im going to do that. Although it would only be one button on the screen, it would turn exiting out of fullscreen mode into a 2click process. So ill prob just change the code and not the position or percieved way it works.
mp3car live search
Old 05-08-2006, 03:52 PM   #43
SMKFree
and to get weather to work, run RRConfig.exe or click the CONFIG button in the skin.
at the very bottom of the list is Weather Settings
mp3car live search
Old 05-08-2006, 04:01 PM   #44
I'm not sure. We can ask guino.
Also, if you want it to be totally transparent, you can send commands directly to RR from AutoIt.
http://www.mp3car.com/vbulletin/road-runner/75040-need-help-sending-rr-sdk-commands-autoit.html
b8bboi is offline
Old 05-08-2006, 04:04 PM   #45
Civic03's Avatar
LS got a reply for my question?
My Carputer Blog
Car System Site
Civic03 is offline
Closed Thread
LSX....void liquid_smoke RR Skins 172 05-06-2006 06:59 PM
LSX Scripts Osiris RR Skins 12 01-14-2006 11:13 PM
QT 4 crossplatform released s003apr Software & Software Development 5 07-02-2005 04:41 PM
Will molding a dash void a lilliput's warranty? mykolJay Fabrication 15 06-29-2004 09:48 PM
Lorty's mp3car plugin 2.4.08 released lorty Software & Software Development 3 01-19-2001 10:47 AM
