LATEST VERSION FOUND HERE
Next update task list:
custom color picker for playlist text
(feature pulled)
new options screen that consolidates and replaces the current "vis opt" and "config" screens, plus more config settings.
(done)
Run RR updater from inside skin
(done)
remove all images with pink transparency and disable clipping for speed increases (in progress)
migrate LSTOOLS inside of the skins folder, clean up unused items, retire old lstools (in progress)
playlist picker screen. (done)
fixed issues with IG3 when entering GPS screen, if you use transitions it now transitions into IG3 smooth as silk.(done)
revised quick menu, its now 2x wide(done)
new_zero config setup, no more add to rr.ini needed this will be done for you (done)
audio player layout changes (done)
updated cdrip screens
(done)
DVSW
(in progress 80%) dayversion
intergrated settings forIGAUTOSW
(done)
more as i think of it...
_________________________________
In this update
9/16/06
README.txt
lsxvoid1.6patch1.exe
the readme file linked above will be new source for what i would normally put in this post.
This file will supercede any other readme either included with the skin or any links below.
It will be updated again sometime this weekend with more indepth start to finish setup instructions for new users.
In this update
9/14/06
100% all new sliders
(done) tweaking
remove battery and signal icons from images, update sliders
(done)
update online indicator
(done)
re evaluate entire top info bar
(done)
fix artrage embed screen (new .skin will be posted before update)
LINK
change layer order of big arrows (photoshop)
(done)
GPSGAS native
(done)
update video player
(done)
change album art/song info on secodary menus to match main menu (removed album art on these screens)
(done)
additional toaster presets
new OSK (maybe)
(done)
update pick command screen to run commands on click hold
(technical issues- no dice)
add additional commands to pick command screens
(in progress 50+ custom commands total)
Ratings intergration
(done) with persistant star indicators on main menu and audio player
Screen Lock intergration
(done)
RR native webplugin
(done) requires latest RR
Milage plugin (done)
new center info display (done)
bigger abc buttons in playlist/bbaa (done)
new album art ( in cd case) (done)
updated bbaa, 2 modes to choose from (done)
fixed bbaa button in playlist editor/ added new button above album art display (done)
reduce number of invisible buttons (done)
new game added
updated GPS screen, added track info (done)
added music nav buttons and time in web browser(done)
restructure LSTOOLS and gps options/script locatons etc(done)
LSTOOLS and the skin is included in the single file.
Fonts are auto installed and .dll (2) files for the above included plugins are registered (milage.dll, screenlock.dll)
LSXVOID1.6 <---------THIS
!!!MAKE SURE YOU DO NOT HAVE "ONSKINSART","" IN YOUR ExecTBL.ini file in the ROOT of RR !!!
whats new.
beta mapmonkey support
beta freedrive support
new redesigned quickmenu, similar to cf style menu (customizable)
***new custom buttons
phoco missed calls indicators removed on non phoco screens (no further phoco work will be done,RRmobile support in a future release)
fileman support from CDRSkull
copytool/ system manager support (
http://www.mp3car.com/vbulletin/rr-plugins/64690-system-manager.html) lsxstyle skin also available (inside lstools)
speedfan support, MBM support dropped.
alternate main menu with bigger visuals (copy menu.skin from LSTOOLS\ALT\main menu big vis)
reload RR button now is an invisible click hold button, located under visuals (turn visuals off first to access) also located on config screen
minimize button relocated to click hold on either of the 2 big arrows on the main menu screen or secondary menu screens
clicking and holding on any return arrow will take you to the main menu
up/down buttons in audio player now page up/down one screen at a time, instead of one track at a time
various fixes and performance tweaks
removed old image files not in use
Other stuff i cant remember right now.
***the new custom buttons are configured by clicking and holding the button you want to change the action for. Then pick a new action from the screen that pops up.
new actions can be added via ExecTBL.ini, be careful editing the actions, one mistake and RR will hang. Thanks goes to
CHUCK for the original idea and also help with intergrateing the feature. Hats off!
custom buttons are available on top and bottom buttons on main menu and secondary menus, audio player. Audio playback buttons on main menu and audio player are not custom. BBAA and PLAYLIST buttons in audio player are also not custom.
As time goes on ill likely add more custom buttons in other areas of the skin as well as additional commands.
Also the clicking the TIME is also a custom button, by default set up for quickmenu, IG3 users may want to change it to IGMENU.
Freedrive and mapmonkey support are also enabled by chooseing one from the command screen>more.
FREEX commands are empty commands that do nothing, just placeholders for new commands to be added.
*IG3 support
ig3 menu access from any screen
updated igcontrol (flyout buttons) for ig3
fullscreen GPS is now 100%fullscreen, speedo removed
fullscreen mode accessed from igcontrol (flyout buttons)
ig3modded .exe file with lsx button theme, street name text color changed from light green to yellow,menu button removed,mute button removed (located in lstools)
IG2 support is simi dropped
IF you run into any issues, try to rename the ExecTBL.ini file in the
root of RR install and see if that helps.
__________________________________________________ ___________________________________
new as of 7/08/06
support for native rr picviewer
radioplayer fixes
new sub menu for NET
basic support for Thunderbird, SKYPE (this will be expanded on in future updates)
IM placeholder
If you allready have the latest fullversion of the skin, just copy the contents of UPDATE X into the skin folder.
The download for the fullskin has also been updated with the latest changes.
whats new:
camera support fixed,
picviewer.net replaced
main menu layout changes
slight graphic changes
dir browser (embeds explorer) work still needed
external dvd fixed
audio player layout changes, alternate version included with LSTOOLS inside ALT folder
various other fixes and additions i cant remember right now.
IGMON skin is updated and the link is below in the 2nd post, read install.txt for instructions
all pervious setup reqirements are still valid, if you are downloading this skin for the first time make sure you get the fonts below and please read this whole post and the next 2 below.
KEYTBL <----- this file is NO LONGER needed (prob still good idea to keep it around though
you will also need to remove any blank commands in the existing ExecTBL.ini file found in the root of your RR dir.
example.
inside ExecTBL.ini in root of RR (NOT THE ONE IN THE SKIN FOLDER!!)
you will find something that looks like this
"ONSKINSTART",""
"ONSONGSTART",""
all of these commands are blank and do not do anything, but they conflict with the ExecTBL.ini file found in the skin folder if they have the same command. So justremove that section or any section that is blank (2 quotes at end).
