Go Back   MP3Car.com > Mp3Car Technical > Software & Software Development > Front Ends > Road Runner > RR Skins > RR Skins No Longer Supported
Closed Thread
Old 11-19-2006, 09:31 AM   #526
kbreeden
Quote: Originally Posted by RichP714 View Post
The Code for L should be 076 instead of 108...then it'll work
Enjoy!
Rich
Maybe I didn't do something right, but I changed the 108 to 076 in OSK.skin and it didn't fix it.
kbreeden is offline
Old 11-19-2006, 09:55 AM   #527
kbreeden
Enjoy!
Rich
Oops, I made the change to the skin in my test directory rather than my working directory. Changing to 076 in the OSK skin does in fact fix it. Thanks, Rich. John, I'll let Guino know since I posted it as an RR bug yesterday.
I'm now getting ready to download and install the new version of the skin.
kbreeden is offline
Old 11-19-2006, 11:20 AM   #528
kbreeden
Wow, John, it just keeps getting better. Nice work!
kbreeden is offline
Old 11-19-2006, 01:01 PM   #529
ajamils is an unknown quantity at this point
John,
Just tried the new updates and it looks AMAZING. Thanks for implementing the cover art idea
Quote:
Thanks to Artisen for the large album art idea, instead of the static "Oscilloscope thingy
Its Arsalan.......
04 Accord Coupe Carputer
ajamils is offline
Old 11-19-2006, 08:02 PM   #530
miwise's Avatar
miwise is an unknown quantity at this point
Great work! Like the new interface and id3 info.
Lexus SC400/Factory Amps/Sub
HP/AMD 1.1 Ghz Mobile/Upgrade Imminent
512 RAM-DVD/7" Touchscreen
WinXP-Shelled to Roadrunner for now
Progress:
Software: Still trying to decide
Hardware: 95% done. . .need GPS
Installation: 90% done. . .clean up phase
miwise is offline
Old 11-19-2006, 08:11 PM   #531
miwise's Avatar
How about windvd support? any plans on that?
Progress:
miwise is offline
Old 11-19-2006, 09:17 PM   #532
SteveC is on a distinguished road
Installed this skin and everything is now working including Google Earth, Traffic and IG3 - woohoo!
However I can't get Video to work - as soon as I click Video it opens the skin and then freezes up - none of the buttons work at that point.
It works ok under other skins such as LSX Void
Any ideas?
RV : Samsung Q1 + Kyocera KR1 (EVDO) + GPS<br>
Car: AMD 3000+ Book PC + Lilliput 8" Touch + 13" TFT
Webmaster for the European Ford Scorpio Site
SteveC is offline
Old 11-19-2006, 11:01 PM   #533
miwise's Avatar
Do you use the default Media player classic or other dvd player. If you use something other than MPC, you have to change the menu.skin file to point to the appropriate skin that matches your program that you're using. I'm using mpc right now with no problems (other than the mouse constantly trying to relocate itself to the upper left corner every millisecond thereby negating any action I try to take with the mouse. . .thankfully touchscreen selections are instant).
Progress:
miwise is offline
Old 11-19-2006, 11:48 PM   #534
Legacy is an unknown quantity at this point
the rip cd button is just freezing my comp
PC
AMD 3500+ 2.2Ghz, MSI K9VGM-V Motherboard,
Geil 512MB PC4200 DDR2-RAM, 7" Lilliput Touchscreen, 30GB HD
Audio
300 watt RMS 2 Channel MTX AMP, 500 watt RMS D-Class MTX AMP, 2 Front - 5 1/4" Sony Xplods,
2 Back - 6 1/2" Sony Xplods, 12" MTX Sub
Legacy is offline
Old 11-20-2006, 12:12 AM   #535
I use the default video player (this is for video files and not for DVDs) and it calls video_player.skin which opens up, displays a green -4:3 on the screen and freezes.
Are there any log files anywhere that shows where it freezes?
SteveC is offline
Old 11-20-2006, 02:17 AM   #536
I just changed it to use Windows Media Player as the External video player and it works. However I also tried running mplayerc.exe in Windows and that worked too so I'm just confused it works ok with WMP so I'll leave it alone.
I noticed in the GAS prices skin when running IG3 that there is a button called Show Map that runs a command called gas_0_showlocation but I can't see that this command is defined anywhere and it certainly doesn't actually work.
Is it possible for the zipcode in these apps (Gas, Traffic etc) to be obtained from the Web by using the Long and Lat from the GPS. It would be much neater for the Gas prices and the Traffic to be updated automatically as we drive.
SteveC is offline
Old 11-20-2006, 04:45 AM   #537
Super Moderator
JohnWPB's Avatar
JohnWPB is a jewel in the roughJohnWPB is a jewel in the roughJohnWPB is a jewel in the rough
Qyestions and answers
Quote: Originally Posted by dima237 View Post
Can I request something? Is it possible to modify the Sirius skin so have some sort of sorting by category? Because 200 channels is kind of hard to scroll. Maybe someone can recommend a skin that has this implemented so that I can modify it to look like bluedevil
There is no real way of sorting the list other than by channel number. That is what the Channel Favorites is really for. You can put all the favorites in there, and weed out all the unwanted channels.
Thanks, that did the trick, This has been corrected for the next relesae.
I am not using any external dvd player currently. My DVD's are actually .avi's that I play through the standard "Video" screen. I will look into trying to get this to work though.
Quote: Originally Posted by SteveC View Post
I can't get Video to work - as soon as I click Video it opens the skin and then freezes up - none of the buttons work at that point. It works ok under other skins such as LSX Void Any ideas?
It sounds like there is a video "Cached" and it has been mobed ort something. Try deleting the video.ini file inthe RR Root directory (It will be created again the next time you watch a vdieo)
This is not skin related, check the Road Runners FAQ on the top page of the forums for instructions to get it to work correctly. If after that it still is not working for you, do a search on the forums, as this has been discussed at least 100 times.
Front End of Choice: Ride Runner (Is there anything else??? ) & Powered by the DigitalFX 4.0 Skin Available at www.JohnWPB.com
My Fiero Build Thread
JohnWPB is offline
Old 11-20-2006, 07:18 AM   #538
Super Moderator
JohnWPB's Avatar
New Menu Screen
Ok, I just did not like the menu screens that were in the previous posts, as they did just look too cluttered. I came up with this and want opinions on what you think. The compass in the clock area is a "horizontal compass" meaning it will float left and right to show your direction of travel (Much like a boat or aircraft compass works).
If you do not want the speed and altitude on the top, those can easily be removed by taking out the lines in the menu.skin file.
JohnWPB is offline
Old 11-20-2006, 07:50 AM   #539
kbreeden
Regarding post 538: I like having all that information (speed, compass, altitude, etc.) on one screen. It does seem a little cluttered to me, but I don't see how it can be made uncluttered with all that information. I think it would be ideal if this could be made a fifth click so we could have the option of having logo, clock, speedo, compass or this comprehensive screen appear.
kbreeden is offline
Old 11-20-2006, 09:35 AM   #540
nasa is an unknown quantity at this point
JohnWPB,
Wow... That looks really nice. I can't find anything wrong with it...
Nasa
nasa is offline
Closed Thread
Open Source Skin Editor for RR lbooker Road Runner 66 04-16-2007 02:51 AM
Can you tell I was bored today: Take a look. Sweet05 RR Skins 47 08-17-2006 04:25 AM
new skin 'Blue' CdRsKuLL RR Skins 19 09-25-2005 06:48 PM
Cool Blue skin Rireal ME Archive 11 01-31-2004 07:53 PM
Nissan Blue skin final SpeersSV ME Archive 6 01-06-2004 07:00 PM
