11-22-2006, 09:28 PM
#601
John,
Just wanted to say thanks again for the menu screen you made for me a while ago. It works great and the effort you are putting in is very much appreciated
Happy thanksgiving, Peace
Dave
11-22-2006, 09:39 PM
#602
Super Moderator
Q&A & VBRuntime Files
[quote=05MaXSL;967853]Just wanted to say thanks for the awesome sking and give you a glimse of what it looks like in my car;
Wow! I like the clean install! That looks great! The blue seems to work in your car very well! Thanks for sharing the pics!
Quote: Originally Posted by kbreeden
FYI, my menu #1 does not display either the speed or the altitude. Menu #2 displays the speed but not the altitude. I know RR is getting the GPS info because the compass is properly working in both menus and speed is properly working in Menu #2.
Even with a totally fresh install I still can't get the IG auto change to work and the open playlist still flashes on the screen when I load the browser. Since nobody else seems to be having these problems I'll have to keep playing with it. Neither issue is really a big deal to me.
Ok I am a bit puzzled.... where are you seeing the speed and altitude on the menu's? I had started to put them above the clock, and decided against it, as it looked to cluttered. I don't THINK the version I posted had this....
yea, the browser was an oversight on my part. Have a look a couple posts back for a fix till the next release.
I am chatting with LiquidSmoke as I am typing this and he had a good suggestion. Try downloading the latest version of the Microsoft VBRuntime and install that. With the issues you have been having over the past posts, something is definately not right somewhere. This MAY help, but I can't guarantee anything, but its definitely a good idea to try.
Quote: Originally Posted by tyman
John,
Dave
No Prob Dave, and you have a great Thanks Giving as well!
11-22-2006, 10:14 PM
#603
Below the clock on both menus.
I meant the web browser. For some reason the current playlist takes over the screen as the browser is loading.
I'll give that a try.
11-23-2006, 06:16 AM
#604
Love the new ver, it corrected the problem with my show map button. However there are a couple things I have problems with that I thought I would let you know.. Dont know if its just me or what but here goes:
1 when pressing GPS on menu one it loads the gas finder page and has iguidance opened ontop of it.. have to click the back arrow to get the actual iguidance menu back..(Used a single click with mouse, dont know if this has anything to do with something you said about pressing and holding the button down to go right to gas finder)
2 when in iguidance i go to system info and gps stats it shows me as having 0 sats. however if i close RR and open iguidance it shows 3/4 (im in the house)
3 when i go to menu 2 and click gps stats it locks up and have to end task it
I dont know if any of these are cause of my system personally or not but figured I would share.. Thanks for the great skin! love it!
11-23-2006, 09:21 AM
#605
Super Moderator
iGuidance problems
1) This sounds like Road Runner issue, shome how with your setup. I just don't know what. try downloading the VBRuntime linked in the previous post and installing it. I say a system problem as I have check the code against Road Runners syntax, and it is left to Road Runner to handle the button once pressed. Tapping it should take you to GPS, and holding it for one second is the stats.
2) This is a typical GPS problem that can be caused by a couple of things. Open the Blue Devil Help file and go to "How Do I.... / Use more than one GPS device". If this is not the issue, check THIS POST for another possibly remedy
3) There is a 90% change this is being caused by a flash problem. THe system isn't really locking up, it just appears that way. The gauges are done in flash, and the processor is probably pegging out at 100%. To test, go to the GPS Status screen, end task and go to performance and check the processor usage. If it's at 100% you have found the problem. To fix it, check the BLue Devil help file again under "How do I... / Make the gauges work"
Let us know how it goes.
BTW: as today is a national holiday in the United States, I will be charging double for technical support till midnight.
Happy Thanksgiving everyone!
11-23-2006, 09:24 AM
#606
Ahhh ok! Thnx for the reply.. I am going out of town for a couple days for the holiday but will check it as soon as I get back on sat/sun and will let you know.. Thanks! and hope you have a great thanksgiving!
11-23-2006, 11:58 AM
#607
i assume i get half of that double pay today also?
The trip was great to NY i drove the whole way... 7 hours not to bad 4 days before it was 9 hours from school. like the skin a lot better and much more usable.
CarPuter: 900Mhz P3 with 256 MB Mem, 160 Gig HD (Thanks kbreeden), Iguidance 3.0 GPS, Logitech PS2 keyboard, Bluetooth, WIFI.
Powered By Road Runner & DigitalFX Skin and Playlist Conveter
11-23-2006, 01:30 PM
#608
Quick question on the PSD file. Are all the menus included or only the top level menu, because that's the only one I see.
Admittedly I've never used PhotoShop before and will have to figure it out, so maybe I'm doing something wrong but I just can't find any other menus.
Thanks, Z
Carputer progress:
100% [▓▓▓▓▓▓▓▓▓▓▓▓▓▓▓▓▓▓▓▓]
Zotac N630I-D-E M/B w/ Nvidia 7100, Celeron 430 1.8 GHz, Xenarc 700IDT, M2-ATX, RR & DFX 4.0.
11-23-2006, 01:36 PM
#609
Thanks, Z
This is a questions I can actually answer !!
In photoshop there is a layer table. Just click on the checks for the different layers you wish to turn on or off for the different menus. All the menus are in different layers.
2001 PT Cuiser
VoomPC with 1.5Ghz C7
M2 power supply
in dash slim tray dvd drive
DWW-750FM c/w 7" USB touchscreen,AM/FM, 4x45W amp
See my install here
11-23-2006, 01:47 PM
#610
Thanks, morris_the_cat. I had played with the layers a bit but thought I might be missing something.
So it looks like only Menu1 and Menu2 are included in this PSD?
Thanks, Z
Carputer progress:
11-23-2006, 01:52 PM
#611
Super Moderator
Photo Shop questions
Admittedly I've never used PhotoShop before and will have to figure it out, so maybe I'm doing something wrong but I just can't find any other menus. Thanks, Z
In the Menu's psd on the download site, both menu's are in that file (The main menu, and the secondary menu) in Photoshop, in the layers palletee in the bottom right, click the little "Eye looking icon" next to the layers to either make it visible or hidden. By default the 1st menu is displayed when opening the file. To show the 2nd menu, Click the eye icons next to menu 1 text and menu1 icons, to hide them then make the eye appear next to menu2 icons and menu2 text. Hope this makes sense to you
11-23-2006, 02:00 PM
#612
What about the PSDs for all the other skins? Do we have to reconstruct these from the 2 PSD files?
If you get a spare hour (hahahaha) do you fancy doing a BD skin for the TrafficDetails app?
http://www.mp3car.com/vbulletin/rr-plugins/85844-trafficdetails-rss-feed-plugin.html
As a Brit I have to ask, what is "Thanksgiving"?
RV : Samsung Q1 + Kyocera KR1 (EVDO) + GPS<br>
Car: AMD 3000+ Book PC + Lilliput 8" Touch + 13" TFT
Webmaster for the European Ford Scorpio Site
11-23-2006, 07:19 PM
#613
Super Moderator
Traffic Detail skin
http://www.mp3car.com/vbulletin/showthread.php?t=85844
I will look at that and see if I can do something for the BD skin.
Wow, thats a tough one, I am no historical scholar, but heres a brief explanation:
It started when the first Pilgrims from England had settled in the new land in the early 1600's. They had a successful harvest in the new country (Now known as the United States), and it was a celebration, and giving of thanks, for a prosperous harvest. It became known as "Thanks Giving" and a tradition that was celebrated every year, and continues here to this day. It's a day to be thankful for your country, family, prosperity and anything else that is positive in one's life.
11-23-2006, 09:01 PM
#614
Hey John,
I tried the new version today and even though I really like it...its almost unusable for me  . I don't know if its my computer(its 1.5 Jetway with 1GB ram) or something else but it CRAWLS specially at the main screen.
When I click(touch) on GPS button, after 5 seconds or so the screen changes and gas finder screen comes and that stays for few seconds and then finally the GPS screen shows up.
And if I go to main screen from there again....same thing happens. Most of the time the main screen stops responding.
I think I should go back to the older version  cuz it was much more stable and I had ZERO problems with it and specially since I'm on a road trip GPS is my life line
Where can I download, older version ?
11-24-2006, 12:34 AM
#615
Super Moderator
Possible flash issue
This sounds like a flash issue. ajamils IM'd me and he is going to try a couple things to try to fix the problem.
| Thread Tools |
| Display Modes |
Linear Mode
