Quote: Originally Posted by
duglas
sorry, I was typing on my MDA...
I have rrconfig running the umpc exec file under rr in program files... it worked before I did the newer Blue Devil upgrade, now it does not..
It opens off center of the screen and if I go to Blue Devil Home and then back to the GPS it opens a new Iguid session and I have to exit out of Blue Devil to get into the original one and use it....
Make sure under GPS Window name you have: "iGuidance" (Without the quotes). Multiple instances of a program are usually related to that setting.
ajamils
Steel Denim looks AMAZING !! Can't wait to try it out
Well I have been working on a new clock for the skin. One of the MAIN things I am working on with this skin is to easily customize the skin as much as possible. With that in mind:
- - The "Tick marks" around the clock, as well as the numbers are a photoshop layer, so you can change the colors to match the color of the skin as well.
- - The logo of the clock (Vehicle logo) is simply a png image file you drop into the skin directory. (Optionally you can just not use a logo if you don't want to)
- - NONE of the text on the buttons or menu's is "Rosterized" [SP?] so it is easily changed.
- - Using transparencies the entire color of the background, text area's, buttons ect is EASILY changed by simply changing the background color.
For those that are a little more adept at using Photoshop, Using the layer properties, it is easy to change the bevel on the buttons, text area's ect, as well as their transparency, drop shod amount ect globally quite easily.
There will also be a version that will just have the Vehicle Logo in the center, for those that are experiencing flash problems, or if their systems are older and just can't handle it.
I am looking to releasing the PSD's (WHen I ever get done with them all!) and leave it to others to see what they can come up with. Using different colors, bevel's, textures ect ect.
Here is a peek at the Main Menu with the clock. By altering the clock tick marks and numbers layer properties, I used sliders to match the rest of the skin.
