Go Back   MP3Car.com > Mp3Car Technical > Software & Software Development > Front Ends > Road Runner > RR Skins > RR Skins No Longer Supported
Closed Thread
Old 12-21-2006, 01:02 PM   #901
Super Moderator
JohnWPB's Avatar
JohnWPB is a jewel in the roughJohnWPB is a jewel in the roughJohnWPB is a jewel in the rough
Quote: Originally Posted by jmciver View Post
Thats good to hear. BTW did your beta testers ever find the Windows Explorer link error? In the settings menu, the button that you have labeled Windows Explorer takes you to the Gamma Control/Skin Loader menu.
Hehehe good catch. I caught and changed that before it went to beta. The explorer is now accesses through the applications button on the main menu screen.
Front End of Choice: Ride Runner (Is there anything else??? ) & Powered by the DigitalFX 4.0 Skin Available at www.JohnWPB.com
My Fiero Build Thread
JohnWPB is offline
Old 12-21-2006, 05:20 PM   #902
jmciver is on a distinguished road
Another question about Gas Price finder.......in order to use the Map It function do you need IG 3.0? I am currently running IG 2.X but your install directions just siad you needed IG to get it to work, not IG 3.0 specifically.
jmciver is offline
Old 12-21-2006, 05:59 PM   #903
Super Moderator
JohnWPB's Avatar
Sonic said it should work with either version of iG. check the Plugin's forum for Sonix's script, as it has more detailed instructions on setting it up ect.
JohnWPB is offline
Old 12-21-2006, 07:31 PM   #904
XPbimmer is on a distinguished road
First, sooo cool skin, really love it!
I have a problem when running freedrive, it launches very nice from RR menu.skin, but when I tap the top bar in freedrive with the bluedevil skin installed, it is supposed to go back to the main screen of RR.
What it does is that it goes back to main screen in rr since the skin command is send RR "exit", but freedrive stays on top, and if i press top bar again, RR exits since it receives "exit" from the main screen. But freedrive still stays open.
Anyone has the correct exit command or workaround for this issue?
XPbimmer is offline
Old 12-21-2006, 09:45 PM   #905
Super Moderator
JohnWPB's Avatar
I actually have not edited the skin files for Free Drive, as it is all built into the plugin. I simply left all the skin code alone, and just created the images to match the Blue Devil skin. However that the skin is responding is based on the original code of Free Drive.
JohnWPB is offline
Old 12-21-2006, 11:16 PM   #906
swwesq's Avatar
swwesq is an unknown quantity at this point
Sirius Not working Help!
I'm using and loving the blue devil skin, is there anyway you could set up a skin that uses sirius instead of xm?
Steve
swwesq is offline
Old 12-22-2006, 02:57 AM   #907
Allright, I'll have to spend some more nights with it then.
But thanks anyway!
XPbimmer is offline
Old 12-22-2006, 01:12 PM   #908
Super Moderator
JohnWPB's Avatar
Sirius Satellite Radio
Steve
There is a sirius skin in the Blue Devil folder. You just need to change the button code on the "Sat Radio" button from "XM" to "Sirius".
JohnWPB is offline
Old 12-22-2006, 06:41 PM   #909
nasa is an unknown quantity at this point
Howdy again,
I have 2 new questions:
1. the mute button doesn't mute... I think it's because my audio is via S/PDIF, is this correct?
2. I am assuming the 2 crossed arrows in the upper right hand side of the display. Is that correct, and how do I tell when I am online?
Nasa
nasa is offline
Old 12-22-2006, 07:17 PM   #910
Super Moderator
JohnWPB's Avatar
Quote: Originally Posted by nasa View Post
Howdy again,
The Mute buttons does a "Master Mute" command, it should mute everything, as far as S/PDIF... I am not sure.
Ummmm..... assuming what exactly???????
The easiest way to tell if you are online, is from the main menu. if you are online, you should see "Online" at the top of the screen
JohnWPB is offline
Old 12-22-2006, 10:12 PM   #911
swwesq's Avatar
I tried that and it does not work. Any ideas? It just pulls up my mp3 playlist.
Thanks,
Steve
swwesq is offline
Old 12-23-2006, 03:06 AM   #912
Super Moderator
JohnWPB's Avatar
Do you have the settings set in the RR Config? Thats all I can think of off hand.... Also, I made that skin, but can not test it, as I have XM and not Sirius. I did switch all the codes on the buttons out, so it SHOULD be correct, but I have no way of actually testing it.
Has anyone else tried Sirius with the Blue Devil Skin?
JohnWPB is offline
Old 12-24-2006, 01:16 AM   #913
Shanlar is an unknown quantity at this point
I've been using Sirius with the Blue Devil Skin for a few months now and it works great.
Shanlar is offline
Old 12-24-2006, 04:45 AM   #914
Super Moderator
JohnWPB's Avatar
Sirius Radio
Thank you for the update. As I mentioned, I made the skin, but this is the first confirmation that it is working correctly.
JohnWPB is offline
Old 12-24-2006, 02:45 PM   #915
meldet is on a distinguished road
Second menu: problem with the buttons
Hi, i'am a newbie at this site and also: exuses for my bad english.
I have installed this fantastic skin on mine carputer and have some problem: in the second menu (with the buttons gps stat , settings etc.) none of the buttons seems working. Even the stop-button.
How to resolve this problem??
meldet is offline
Closed Thread
Open Source Skin Editor for RR lbooker Road Runner 66 04-16-2007 02:51 AM
Can you tell I was bored today: Take a look. Sweet05 RR Skins 47 08-17-2006 04:25 AM
new skin 'Blue' CdRsKuLL RR Skins 19 09-25-2005 06:48 PM
Cool Blue skin Rireal ME Archive 11 01-31-2004 07:53 PM
Nissan Blue skin final SpeersSV ME Archive 6 01-06-2004 07:00 PM
