Go Back   MP3Car.com > Mp3Car Technical > Software & Software Development > Front Ends > Road Runner > RR Skins > RR Skins No Longer Supported
View Poll Results: What GPS Program do you use?
iGuidance 607 57.00%
MapPoint 56 5.26%
Destinator 185 17.37%
Streets & Trips 90 8.45%
Other 127 11.92%
Voters: 1065. You may not vote on this poll
Closed Thread
Old 06-14-2007, 09:43 PM   #1501
Niob's Avatar
Niob is an unknown quantity at this point
Hi..
Again.. Greate skin and i still use it. Good luck with your new house btw.
I just looked at the "speedFan" skin on my carputer and realized that al tmp's whas shown in faren and not celcius. And everything whas missplaced. Like Core showed 12v and 5v shown 2.9v So i started looking for info. And as this scin is so wonderfull and hawe sutch a greate creator. It even comes with a help file and som programs to help. I whas able to find all information i needed to change the settings and how to get them right. But i could not find 2 things. 1 whas how to make Faren to Celcius. And 2 what info goes where, What line shows what info in the config. So i started changing one line at the time. and restarted RR to see the effekt off the change. WERRY boring jobb to do hehe.
So i figured out. if i dont like the job. There sure is lots of others thinking the same. So here i post the speedfan.skin file i changed 4 you to read. As the config is HW related. And change from HW to HW. I just typed WHAT info should be entered on the line. The config is also changed to show Celcius.
C2F = Faren and 0.0 C = Celcius (As far as i found out).
NOTE: This is not a working config. As it only wil show some tekst in your speedfan page in RR. Use the program located in "helper files" folder named "ShowSpeedFanData.exe" to get the correct data to enter in the speedfan-skin file for YOUR system.
NOTE: You can execute this config once 2 se if the information is at the right place. (should be similar as i think there is only one release of this skin at the moment). RED LINES IS THE ONE TO LOOK AT
Code:
MEDIACAR Skin MEDIACAR Games Skin SpeedFan_OFF.png,SpeedFan_OFF.png,SpeedFan_ON.png,SpeedFan_OFF.png /, B, x, y, w, h, Command;COMMANDCODES, Tooltip B,0,0,794,80,"RUN;C:\Program Files\SpeedFan\speedfan.exe", /, L, x, y, w, h, color R;RGB, G, B, font size;FONT, font name, Code;LABELCODES, Tooltip;LABELALIGNMENT L,341,321,104,32,255,255,255,20,"Arial","FREEMEM", L,333,203,100,28,255,255,255,20,"Arial","=HD1TMP","0.0 C" L,615,204,104,28,255,255,255,20,"Arial","=HD2TMP","0.0 C" L,81,202,111,28,255,255,255,20,"Arial","=CASETMP","0.0 C" L,77,83,96,32,255,255,255,20,"Arial","=CPUTMP","0.0 C"L,585,83,96,32,255,255,255,20,"Arial","CPU","RIGHT" L,206,441,96,38,255,255,255,20,"Arial","=+12V", L,581,321,96,32,255,255,255,20,"Arial","MEM", L,64,321,99,32,255,255,255,20,"Arial","ALLMEM", L,620,442,121,32,255,255,255,20,"Arial","=POWERFANSPEED", L,340,441,96,38,255,255,255,20,"Arial","=5V", L,55,441,96,38,255,255,255,20,"Arial","=VCORE", L,493,441,96,38,255,255,255,20,"Arial","=3.3V", L,305,83,92,32,255,255,255,20,"Arial","=CPUFAN", /, B, x, y, w, h, Command;COMMANDCODES, Tooltip B21,0,513,100,86,"CLOSE","Exit" B09,102,513,100,86,"EXITMENU","" B,300,513,99,86,"PLAY", B,398,513,101,86,"NEXTTRACK", B,203,513,99,86,"PREVTRACK", B11,500,513,99,86,"VOL-","" B12,596,513,99,86,"VOL+","" /, I, x, y, w, h, Code;INDICATORCODES I01,698,513,107,86,"MASTERMUTE" END
Still sorry for my bad English
Niob is offline
Old 06-15-2007, 09:24 AM   #1502
leatherboy's Avatar
leatherboy is on a distinguished road
Quote: Originally Posted by Enforcer View Post
Thanks for the reply. I found a solution to my problem guided by this thread.
Enforcer If we (I) didn't search the threads I should have post hudrends of questions. As you can see my posts are few and I spent alot of time reading. And as you could find many of my post never get an answer. Anyway. In this case I searched for acdsee, for external application, imageviewer, picture viewer, etc but in threads not in posts. And of course I didn't get the right result. It happens when you work 18 hours in front of a monitor. Sorry to bother you and thanks again.
leatherboy is offline
Old 06-15-2007, 10:39 AM   #1503
Confusion Master
Enforcer's Avatar
Enforcer has a brilliant futureEnforcer has a brilliant futureEnforcer has a brilliant futureEnforcer has a brilliant futureEnforcer has a brilliant futureEnforcer has a brilliant futureEnforcer has a brilliant futureEnforcer has a brilliant futureEnforcer has a brilliant futureEnforcer has a brilliant futureEnforcer has a brilliant future
Confusion Says:
One should look at all smilies to get full meaning before taking offence.
More of the Confusion Masters wise sayings here
Enforcer is online now
Old 06-15-2007, 01:20 PM   #1504
Capri28 is an unknown quantity at this point
are you causing trouble
Enforcer. LOL.....
just a quick question ,
i want to add labels for new ver.gatso hunter to my AutoRoute skin, now is it possiable to make the same labels as buttons as well,
i hav'nt tryed it yet its something on my to - do list.
Capri28 is offline
Old 06-15-2007, 02:10 PM   #1505
Confusion Master
Enforcer's Avatar
Its how most of the iDrive buttons are done.
The ones down the side plus the time and dates are all buttons.
Old 06-16-2007, 09:13 AM   #1506
leatherboy's Avatar
Confusion Says:
My friend, you are right for one who has time and time is money. If you dont have time, you are asking questions.
Old 06-17-2007, 05:44 PM   #1507
okarcheboy is an unknown quantity at this point
Radio Preset Question
John et al,
I have been lurking for about a year now while I have built my carputer. So far I have been able to get most everything I want functional. Of the RR skins I have tried this is no doubt the best by far.
I have one request/question. Is there a way to get the presets in the radio skin to auto update based on zip. I have created a script that uses a file from the FCC along with the zip.dat file to calculate what radio stations are within a given distance of a zip code. (I am planning a cross country trip with my son this summer and thought it would be nice not to have to search the airwaves for stations.) Initially I thought of doing it manually by adding a buttion to the radio skin that would copy the desired file, based on zip, over the radio.ini file and do a skin reload. No joy there. The list didn't update and I discovered that the radio.ini file was overwritten with its original contents when RR was exited.
Any help will be greatly appreciated.
okarcheboy is offline
Old 06-19-2007, 04:33 AM   #1508
cobase is an unknown quantity at this point
Awesome!
Ok, you've won a convert. I made my WinXP icons 40-pixels wide at 640x480 and scaled WinAMP to 250% and resisted having a Front End for oh... three or four months. But I finally tried RR and a couple of skins... yeah, this is easier. Much easier to use on the road - you guys win.
I also appreciate how customizable this stuff is. I customized the buttons on the main menu (No radio, sat-radio or DVD here...) swapped the album art for the playlist, just fixed the mixer issue and uh... 'functionally' embedded WiFi Hopper, Thunderbird, and my EasyOBD-II program. I'm using DeLorme Street Atlas USA 2007, which is also sorta-embedded now - I gotta learn SENDKEY and set the keyboard shortcuts maybe. Two actual suggestion though not so groundbreaking I'm sure: 1) Keep the buttons on the bottom of the main menu (menu, power, prev, play, next, vol-, vol+, mute) in the same place in all the screens if possible. 2) It would be nice if there were a template of empty buttons to customize. Is there? I didn't see one, and photoshoping buttons isn't fun.
Anyway, I basically just wanted to thank John for his awesome skin which I am now using. Thanks!!
Elantra GT 1.2GHz Duron, RoadRunner & LSX Void 3.2. Status: Stable...
cobase is offline
Old 06-19-2007, 11:31 AM   #1509
EL_GRECO101's Avatar
EL_GRECO101 is an unknown quantity at this point
Can you say more details for "EasyOBD-II" program cause I'm looking for a nice and "light" OBD-II program!
Virtuousness & Daring...!
EL_GRECO101 is offline
Old 06-19-2007, 01:36 PM   #1510
i'm intrested in the Wifi hopper program
any chance you can give more info on that for me please.
thanks
Capri28 is offline
Old 06-19-2007, 05:13 PM   #1511
Super Moderator
JohnWPB's Avatar
JohnWPB is a jewel in the roughJohnWPB is a jewel in the roughJohnWPB is a jewel in the rough
thanks
EasyOBD-II & Wi-Fi Hopper
Just a quick post, hope to be back to the skin here soon. The move to the new house went well, now its a matter of painting, unpacking, and setting up the Home Automation for lights, security and A/C / Heating control.
Front End of Choice: Ride Runner (Is there anything else??? ) & Powered by the DigitalFX 4.0 Skin Available at www.JohnWPB.com
My Fiero Build Thread
JohnWPB is offline
Old 06-19-2007, 10:37 PM   #1512
DeadlyAP1's Avatar
DeadlyAP1 is on a distinguished road
congrats on the home purchase John. I went through the same thing last October. Many long nights of painting and fixing stuff. It gets easier, trust me...
DeadlyAP1 is offline
Old 06-20-2007, 09:12 AM   #1513
Yeah, that's the one, EasyObdII 2.x. I say sort of embedded because the edges of the window on all four sides are cut off at 640x480. All the buttons are reachable and the info is readable, just not pretty. Anyway, that's for another thread.
Hey John, are you going to make a HousePC ?
cobase is offline
Old 06-20-2007, 09:20 AM   #1514
kbreeden
I figured it was going to take a couple of months more to settle in than it does the typical first-time homebuyer since you'll be setting up things so you can push a button in your car and have a four-course meal automatically prepared and ready for you by the time you return home.
kbreeden is offline
Old 06-20-2007, 09:42 PM   #1515
Super Moderator
JohnWPB's Avatar
Yea, I also made a "House PC". It controls lighting, A/C, security and such. It also doubled as a MediaCenter PC in the living room. I have a couple touch screens that will be placed in the walls to control everything.
I don't know about dinner prepared, but I can check the status of the house, turn lights on and off ect from my phone or from the CarPC.
JohnWPB is offline
Closed Thread
For those who want true 5.1 Dolby Digital and DTS antimatter Car Audio 89 06-29-2007 12:54 PM
Artec T14A Mini USB 2.0 Digital HD TV Tuner LESLIEx317537 General Hardware Discussion 2 12-02-2006 01:02 AM
Content Relevant URLs by vBSEO 3.3.0
"VaultWiki" powered by VaultWiki v2.5.2.
Copyright © 2008 - 2009, Cracked Egg Studios.Ad Management by RedTyger
