View Poll Results: What GPS Program do you use?
iGuidance
607 |
57.00% |
MapPoint
56 |
5.26% |
Destinator
185 |
17.37% |
Streets & Trips
90 |
8.45% |
Other
127 |
11.92% |
06-28-2007, 09:23 AM
#1546
Confusion Master
general.ini of the skin you are using.
06-28-2007, 05:16 PM
#1547
Hi
Having trouble applying a colour to the skin..
Have changed the path for pictures, but when i have found the right picture and push "change", nothing happens.. anyone have any idea?
06-29-2007, 01:25 AM
#1548
Anyone have a PNG of the Menu and AudioPlayerFull skins without any text or labels? I want to customize the buttons but I can only manage JPGs, which loses the transparent aspect of Digital FX 2.0
Elantra GT 1.2GHz Duron, RoadRunner & LSX Void 3.2. Status: Stable...
06-29-2007, 04:44 PM
#1549
I have downloaded this skin, and I have to say it so far works flawlessly! I even made a donation to help keep this project going, every little bit should help the creator, time is money
06-29-2007, 06:23 PM
#1550
This is a fantastic skin JohnWPB,im adding a lyrics skin file for personal use.
Is it possibile to put .Mid song title, in upper bar?
06-30-2007, 04:53 AM
#1551
Spectrum Analyzer help..
OK, who has the spectrum analyzer working? Where is the folder your susposed to transfer over to winamp. Help file says it is in the spectrum analyzer folder. Not in mine.Anybody??
06-30-2007, 05:09 AM
#1552
open your skin folder
under helper files
copy the spectrum folder to the avs folder in winamp
follow help file instructions for the rest
when in winamp config to select spectrum folder make sure you de-checked the fade 10 sec's box
07-01-2007, 05:15 AM
#1553
Thank you Capri28!! This is what the help file said to do:
"First download & install Winamp Version 5.13 linked above.
Next, There open the DigitalFX SKin folder, and then go into the DigitalFX Help File folder. in ther locate the "Spectrum Analyzer" folder in there. Inside that folder, You will need to copy the DigitalFX folder inside that folder to your Winamp/plugins/AVS folder."
That was what was confusing me. I was hunting for a folder inside of the spectrum analyzer folder. Thanks again......
Reason: added color
07-01-2007, 08:25 AM
#1554
John hasn't released the PNG files and has stated on several occassions that he has no intention of doing so.
07-01-2007, 08:27 AM
#1555
Quote: Originally Posted by esko
After hours of search to no avail, I am hoping the community can help me as a whole. I am using RR with Digital FX 2.0 and iGuidance 3.0, every time I open GPS from the main screen it does not appear full screen. (see attached) Also, the buttons (zoom in/out, full screen, IG menu, ect do not work. I've installed the IG patch.
any suggestions would be great! Thanks everyone!
It looks like you're using the wrong window name. Go to RRConfig and in make sure "iGuidance" (no quotes) is shown as the window name.
07-01-2007, 08:59 AM
#1556
help file is
the help file is a little out of date on a few items, but you do get the gissed of it, i only found the 10 sec's fade by accident.
07-01-2007, 09:58 AM
#1557
I was playing around with some features I have not tried yet today and had a few issues:
1. Traffic. I could get connected, but when I switced to the city I wanted, the PC would lock up while trying to download all of the data. Is this a hardware issue (I am using a M10000 MB) or is there some software setting that I am missing that will help it run smoother?
2. Weather. The maps (Temps, Sat, etc) are not updating. Even with an active internet connection, my maps are from 1 May 07 (earier versions of DigitalFX did not have this problem with the update). Also, when I view the temp map in particular, the PC locked up (the other maps did not lock up even thogh the data was old). Again, is this a hardware issue or is there some setting I am missing?
07-01-2007, 10:06 AM
#1558
I was having lockup problems with traffic as well. I then upgraded to a Pentium P4 and a 256meg video card and have had no more issues.
#2 is a mystery. I've never had problems with weather.
07-01-2007, 12:32 PM
#1559
Confusion Master
I have been having trouble with the weather generally for the last couple of weeks. I suspect weather.com may have changed the way it works.
07-01-2007, 12:49 PM
#1560
Weather has been working perfectly for me. If weather.com were the culprit we should all be having the problem.
| Thread Tools |
| Display Modes |
Linear Mode
