Go Back   MP3Car.com > Mp3Car Technical > Software & Software Development > Front Ends > Road Runner > RR Skins > RR Skins No Longer Supported
View Poll Results: What GPS Program do you use?
iGuidance 607 57.00%
MapPoint 56 5.26%
Destinator 185 17.37%
Streets & Trips 90 8.45%
Other 127 11.92%
Voters: 1065. You may not vote on this poll
Closed Thread
Old 07-01-2007, 01:26 PM   #1561
Confusion Master
Enforcer's Avatar
Enforcer has a brilliant futureEnforcer has a brilliant futureEnforcer has a brilliant futureEnforcer has a brilliant futureEnforcer has a brilliant futureEnforcer has a brilliant futureEnforcer has a brilliant futureEnforcer has a brilliant futureEnforcer has a brilliant futureEnforcer has a brilliant futureEnforcer has a brilliant future
HMM, coz it's the same at work and at home.
Maybe we have just lost UK support????
Enforcer is offline
Old 07-01-2007, 02:11 PM   #1562
Robterza's Avatar
Robterza is on a distinguished road
Quote: Originally Posted by Robterza View Post
This is a fantastic skin JohnWPB,im adding a lyrics skin file for personal use.
Is it possibile to put .Mid song title, in upper bar?
No help for mid title,in upper bar! Never mind, i have it in the main screen, a bit small but its ok. I tried the lyrics thing today in my car, and its works like a charm.If the Jap's see it, they will go crazy.If johnWPB interested, all zip everything and send for test
new pics.
Robterza is offline
Old 07-01-2007, 02:36 PM   #1563
kbreeden
I'm curious what's not working. Is it just not updating? What version of RR are you using? I had problems with weather a few weeks ago when I briefly switched to a slightly older version of RR. I then went back to the version supplied with the DigitalFX skin and all is well.
kbreeden is offline
Old 07-01-2007, 06:01 PM   #1564
Confusion Master
Enforcer's Avatar
Well at work I am using 12/04/2007, at home I was using one from November 2006, both were working fine till about May 4th.
Edit, Ok sorted it.
It was partly a UK thing.
I used to have <town>,UK
now just put <town> and it's fine.
Enforcer is offline
Old 07-01-2007, 06:18 PM   #1565
~*77*~ is on a distinguished road
My weather works, but the SAT and the Radar screens have been locked on May 01, 2007 according to the time stamp in the top left corner. The 1 Day, 5 Day, and Temp screen are all fine / current. Same thing? Any ideas?
Mostly Useless Info - Free Image Host
~*77*~ is offline
Old 07-01-2007, 06:18 PM   #1566
kbreeden
Okay, I think that's your problem. If you're using the latest version of DigitalFX you need to use a newer version of Roadrunner.exe. Sonic and JohnWPB were working together to show weather by current location via GPS. Sonic made a couple of changes to the RR exe. The one you want is dated April, 2007, and is over 2 megabytes. I believe JohnWPB supplies it with the DigitalFX skin. If you can't find it let me know and I'll PM it to you.
kbreeden is offline
Old 07-01-2007, 06:20 PM   #1567
Confusion Master
Enforcer's Avatar
Edited above post.
Enforcer is offline
Old 07-01-2007, 09:01 PM   #1568
kyjoe is on a distinguished road
Same problems here with the weather. But it is only the animated Sat. and Radar screens. Temp screen updates fine. I switched from the animated maps to the maps that don't move like in Digital FX Blue and they update fine. So the problem, at least for me, is only with the maps that show movement.
kyjoe is offline
Old 07-02-2007, 12:31 AM   #1569
jmciver is on a distinguished road
This is the problem I was talking about. The local weather (or any location I want) works fine. It is just the maps that won't update (1 May 2007 in the upper left corner). I am also using the latest version of RR that came with DigitalFX.
jmciver is offline
Old 07-02-2007, 07:31 AM   #1570
meisner is an unknown quantity at this point
I too am having this exact same issue.
meisner is offline
Old 07-02-2007, 10:13 AM   #1571
Robterza's Avatar
Ok , i think i found the problem of the weather maps. Must be an error or not,i tested on my pc seem to work.i takes about 2 minutes to refresh the maps.
in ExecTBL.ini of the skin.
/"LoadAllWeather","RUNQ;C:$skinpath$Weather\Weather Downloader.exe||RELOADWEATHER"<---WRONG
"LoadAllWeather","RUNQW;$skinpath$Weather\WeatherD ownloader.exe"<---OK
"ConvertMaps","RUNQ;$SkinPath$Weather\gifswfsh.exe |*.* /g /c"
in skin files:weather;weather_detail;weather_radar;weather _satellite;weather_temperature.
B,203,508,95,90,"load;weather_detail.skin",
B,104,509,97,90,"load;weather.skin",
B,299,508,99,90,"LoadAllWeather||ConvertMaps",<-----OK
/,B,299,508,99,90,"LoadAllWeather||LoadMaps",<----WRONG
B,398,508,97,90,"load;weather_Temperature.skin",
B,592,508,102,90,"load;weather_Satellite.skin",
B,2,509,102,90,"load;menu.skin","exit"
somebody test and confirm
Robterza is offline
Old 07-02-2007, 11:07 AM   #1572
Quote:
/"LoadAllWeather","RUNQ;C:$skinpath$Weather\Wea ther Downloader.exe||RELOADWEATHER"<---WRONG
"LoadAllWeather","RUNQW;$skinpath$Weather\Weat herD ownloader.exe"<---OK
Is the repositioned space from
to
Correct?
~*77*~ is offline
Old 07-02-2007, 11:50 AM   #1573
Confusion Master
Enforcer's Avatar
no. there is no space. it's a forum querk.
rob try and put skin commands in code tags
Enforcer is offline
Old 07-02-2007, 01:55 PM   #1574
Doing what Robterza says gets me an updated Radar image from July 1 which is an improvment, but the Sat is still on May 1. Temp is also on July 1, and reloading or rebooting, or anything else can't seem to force anything to July 2.
gifswfsh.exe now also crashes if I switch weather screens more than a couple times.
~*77*~ is offline
Old 07-02-2007, 06:06 PM   #1575
Robterza's Avatar
Ok, lets see if this will work for weather maps.
in EXECtbl.ini of the skin
"ConvertMaps","RUNQW;$SkinPath$Weather\gifswfsh.ex e|*.* /g /c"
In "weather" directory of skin, backup "WeatherDownloader.exe"
Download these files , and put them in "Weather" directory of skin
When you update maps, you will hear one beep for 1 map updated, second beep for second map update, two beeps update finished.
Please test and confirm.
Robterza is offline
Closed Thread
For those who want true 5.1 Dolby Digital and DTS antimatter Car Audio 89 06-29-2007 12:54 PM
Artec T14A Mini USB 2.0 Digital HD TV Tuner LESLIEx317537 General Hardware Discussion 2 12-02-2006 01:02 AM
