View Poll Results: What GPS Program do you use?
iGuidance
607 |
57.00% |
MapPoint
56 |
5.26% |
Destinator
185 |
17.37% |
Streets & Trips
90 |
8.45% |
Other
127 |
11.92% |
07-09-2007, 11:09 AM
#1591
Confusion Master
Phoco would be sufficent as in my example, then you need to set up phoco in RRConfig. There should be a FAQ or at least a thread on setting up Phoco in RRConfig.
07-10-2007, 12:02 AM
#1592
IG4 Support?
Does anyone know if Digital FX 2.0 will function properly using iGuidance version 4?
07-10-2007, 02:02 PM
#1593
I haven't tried IG4, but I'd bet since DFX2 includes a special build of IG3 that IG4 won't work so well, for now.
TruckPC, BoatPC, and CarPC I need a life!
07-10-2007, 02:13 PM
#1594
I suspected as much. Now, I wonder where I can get my hands on a copy of version 3.....
07-10-2007, 10:45 PM
#1595
What does IG4 have over IG3 that is worth the switch?
07-11-2007, 01:20 AM
#1596
I'm not familiar with either of them. However, the iNav website sells IG4 but not IG3. Not being able to purchase the GPS plugin that DFX requires is pretty significant.
07-11-2007, 03:10 AM
#1597
Super Moderator
iGuidace 4.0
Hello everyone, I have not been posting much here, with the new house and all, but have been trying to follow the thread at least.
I did some checking into IG4 and it does look like a nice improvement. There are a few new features that I like. Mainly the Text to speech of the street names. Instead of "Turn Right", you will hear "Turn Right on Maple Drive".
Some other major improvements are an improved 3D view, many more POI's that are now sorted alphabetically by distance or by city, and a full screen mode.
Another major improvement is that they did away with the map loader. The North America version will now have a seamless map of the US & Canada.
They also say that the UMPC / CarPC version has a completely new GUI.
I have yet to shell out the $79 for the new version, as I have a few other priorities right now.
The bottom line is, I can guarantee that it will not work with the DigitalFX skin, or any other skin that supports iG3.0 right now. The AUtoIt scripts running in the background to control iG are very dependant on the way the buttons are positioned on menu's and the names of the buttons.
07-11-2007, 03:29 AM
#1598
Sorry for the N00b question, but can iG4 run as a unique application within RR but without the DFX skin? That way, late adopters can still use iG while DFX is (hopefully) updated.
07-11-2007, 06:23 AM
#1599
Super Moderator
I am not sure how the native embedding by RR of iG will handle it. If all else fails though, it can be embedded as a simple external app. All features of iG would still be available, by using the "Menu" button in iG itself. It just means a lot more presses to get to something buried in the iG menu's is all.
07-11-2007, 09:00 AM
#1600
Thanks. iG3 is still available on ebay for a few dollars less than iG4...seems that iG4 is the better value. However, is it realistic to expect a new version of DFX in the near future that incorporates iG4?
07-11-2007, 09:31 AM
#1601
Terminal flasher
just an fyi....
iG4 is not igNative compatible... it'll probably be some time before that happens.
03 Acura RSX Coupe
Developer of: RRFusion, MovieTimes.NET, (new)RRMail, RRShoutcast, & RRVehicle Maintenance
Currently working on: RRVehicle Maintenance
07-11-2007, 01:15 PM
#1602
Super Moderator
Quote: Originally Posted by Sonicxtacy02
just an fyi....
I am actually supprised to hear that, they must have made some major changes. So far, iGuidance window name has not changed, until now it seems.
As for DigitalFX and iG4, yes, when I can get the money together to do the upgrade, I will definitely try to work it out, as it is something that I also want for myself
Things are calming down a bit on the new home front, and hopefully here soon I can get back to working on the skin a bit. I have a couple of new things I would like to add... I will tell a bit more about it in the coming weeks.....
07-11-2007, 02:34 PM
#1603
just an fyi....
O.K., I understand that it may be awhile before attempts to integrate iG4 into DFX begins, and then maybe alot longer before it is usable. Can you explain what "igNative compatible" means, or direct me where I can find out for myself?
07-11-2007, 03:03 PM
#1604
Terminal flasher
iGNative is a option inside of Roadrunners source that makes RR able to correctly embed and control iguidance. It allows such things as automatic switch to GPS screen upon entering guidance mode and muting the music while directions are being spoken.
03 Acura RSX Coupe
07-11-2007, 03:07 PM
#1605
Ah! Yes, thank you. I see why it is important.
| Thread Tools |
| Display Modes |
Linear Mode
