Go Back   MP3Car.com > Mp3Car Technical > Software & Software Development > Front Ends > Road Runner > RR Skins > RR Skins No Longer Supported
View Poll Results: What GPS Program do you use?
iGuidance 607 57.00%
MapPoint 56 5.26%
Destinator 185 17.37%
Streets & Trips 90 8.45%
Other 127 11.92%
Voters: 1065. You may not vote on this poll
Closed Thread
Old 09-24-2007, 05:11 AM   #2251
Super Moderator
JohnWPB's Avatar
JohnWPB is a jewel in the roughJohnWPB is a jewel in the roughJohnWPB is a jewel in the rough
Quote: Originally Posted by pnyboy27 View Post
i know that you probably think that i did not do what was told for me to do when installing your skin by adding the lines from the 'add rr' file. well, i did. i added the lines, and even the optional ones. now i can change my skins manually by going to the notepad file and editing it there by changing the path everytime i want to change the skinface, but it just doesnt seem to work from your skin. i dont know what i did wrong. i even reinstalled your skin to see if i can refix what i may have did wrong, but came with the same results. somehow, for the skinface listings, its redirecting it to my image viewer folder. i have been trying to find out which file i can edit the path, but i cant seem to find it. any help? thanks in advance!
I got this same exact message in a PM and answered you there. There really is no reason to have to post in the thread, and PM as well. Just a post would have worked fine
Front End of Choice: Ride Runner (Is there anything else??? ) & Powered by the DigitalFX 4.0 Skin Available at www.JohnWPB.com
My Fiero Build Thread
JohnWPB is offline
Old 09-24-2007, 06:19 AM   #2252
nasa is an unknown quantity at this point
Hi gang,
has anyone else noticed that the reported cpu usage seems a little... well wacked? I have seen it report negative cpu usage (actually quite a lot). Is this to be expected given my setup (see carpc specs in my signature)?
Nasa
nasa is offline
Old 09-24-2007, 06:49 AM   #2253
robaz is an unknown quantity at this point
Hi All, I am a total newb, just doing some reasearch into front ends.
been playing with Roadrunner for a while now then I found your skin,WOW fantastic after having a look at the utube video this is the one for me.
I downloaded the DigitalFX 2.5 to have a play with, but after running the install program I get the following error message:
"DigitalFX has not been totally installed because of the following reason:
skins\DigitalFX 2.0\Scripts\FindDriveLetters.exe: This file contains invalid data. (error 11FD)
You will have to run this utility again to completely install DigitalFX."
I did have a quick search of your forum could not find the same problem.
oh one other question does your skin support destinator GPS (Mapmonkey"?
Thanks in advance, any other pointers would be most helpful.
ROBAZ aka Baz
Wollongong (south of Sydney)
NSW AUSSIE
robaz is offline
Old 09-24-2007, 11:55 AM   #2254
RoadRunner Mastermind
guino's Avatar
guino will become famous soon enoughguino will become famous soon enough
Quote: Originally Posted by nasa View Post
Hi gang,
Nasa
It is posible that the dual-core stuff is making the CPU load calculations "wrong" .. :| I have to find something where I can test it on..
Ride Runner RR's Myspace
guino is offline
Old 09-24-2007, 02:56 PM   #2255
Super Moderator
JohnWPB's Avatar
Robaz: It may have been an error in the download, as I can not duplicate that problem here. Also it's possible that an overzealous Virus Protection problem is getting a false positive from that file, and deleting it. This has happened quite a few times with RR itself, as well as AutoIt scripts like this one.
Guino, I am running a dual core on my desktop dev machine, and have not seen a negative value for the CPU as of yet, so I am not sure if that could be causing the issue or not.
JohnWPB is offline
Old 09-24-2007, 08:31 PM   #2256
fixinstuff's Avatar
fixinstuff is on a distinguished road
John,
A minor bug in my system since I have updated to 2.5. When I exit iGuidance using the home button, the GPS menu pops up and wont let me do anything except select iGuidance again. I dont remember problems with this in the last version.
Also you have a screen in the files for SMS messenger, what plugin is this from? I cant seem to find anything for RR.
Plan for project = 100%
Part the project. = 99%
Built...................= 90%
Install ...............= 99%
Forever In Progress
Scott AFB, IL
fixinstuff is offline
Old 09-24-2007, 08:35 PM   #2257
nst6563 is an unknown quantity at this point
fwiw, I'm running a P4 with hyperthreading and I've seen the negative cpu usage. Using the latest RR and DigitalFX 2.5. I may have debugging turned on too...I'll have to double check. If there's something I can do that might help bring some light to the subject let me know. I do have some coding experience but nothing like what it takes to do what you guys have done
nst6563 is offline
Old 09-24-2007, 08:55 PM   #2258
esko's Avatar
esko is an unknown quantity at this point
I too am running a dual core and have not seen a negative CPU value.
esko is offline
Old 09-24-2007, 09:12 PM   #2259
andrewfblack is an unknown quantity at this point
I see negitive CPU usage everyonce in a while also
andrewfblack is offline
Old 09-24-2007, 09:26 PM   #2260
BREWDOG52's Avatar
BREWDOG52 is an unknown quantity at this point
Bump.
Can anyone help me with this??
Thanks all
Quote: Originally Posted by BREWDOG52 View Post
Hey all,
I'm having problems trying to get the spectrum analyzer visu working correctly. When I click on visualization under both music and the hot spot on the main page it just brings winamp and the visu to the front (it doesn't embed either in album art or on the top). the transparency doesn't seem to be working either. I followed john's steps in the help file and I'm running winamp ver. 5.13, I also added a screensavers.ini in the root of RR with these lines
AvsTransparent=true
FadeOnIdle=false
SecondsToFade=300
FadeInterval=10
DefaultOpacity=40
MaxOpacity=200
I am using bluezx3's config, and have avs selected, I also tried "other" with !Winamp Gen!AVS for the window name, still no luck, tried unchecking avs transparent also.
here's my music section of rr.ini
[Music]
musicpath=C:\music\
playlistpath=Click here to set path
useid3=3
showid3playlist=true
showid3browse=true
lazytag=true
singleclickaudio=false
noformat=false
listnumbers=true
listfollowssong=true
resumemusic=0
audiorepeat=false
audioshuffle=false
id3listformat=%title%
id3browseformat=%title%
titlesafter=-
albumart=*.txt
fadeimages=true
audiofiles=.mp3,.wav
visuname=!Winamp Gen!AVS
scrollmode=1
circularlist=false
groupnumbers=false
picspath=C:\Program Files\Road Runner\skins\DigitalFX 2.0\Backgrounds
Any help and suggestions would be awesone.
I should of never watched john's new video , before that I didn't know what I was missing.
BREWDOG52 is offline
Old 09-24-2007, 10:14 PM   #2261
esko's Avatar
Bump.
Thanks all
When I first set this up I "overlooked" WinAmp Classic Mode Skin. And yes I was beyond frustrated and felt ashamed when I realized how simple the fix was.
esko is offline
Old 09-25-2007, 02:17 AM   #2262
BREWDOG52's Avatar
Thanks man, figured it was easy as that. don't be too ashamed though, the readme says do NOT change the skin
Old 09-26-2007, 04:31 AM   #2263
Super Moderator
JohnWPB's Avatar
Ok, new feature to be coming to RR soon, and the skin is almost ready to support it
In the next DFX version, you will not have the colors to choose from in the list when changing skin colors. Instead you will have a little over 16 million colors to choose from
When you mouse over, or drag your finger, the skin preview at the top of the screen will change color. There will be buttons to save for "day color" and "night color". This is due to the fact that the skin will automatically switch between your day and night colors automatically at the exact times of sunrise and sunset based on your GPS location. When the change occurs, you will not lose any running programs like iGuidance, and you will remain on the screen that you are on when it happens.
I always turned off the auto switching, as the time was never right, and if I had a route in my GPS program, it would be lost when the skin switched.
You will just see a "Good morning" or "Good Evening" graphic pop up for a few seconds over the skin to let you know that it has changed. tapping anywhere on the pop up, you can dismiss it immediately, and not have to wait the 2 seconds for it to disappear.
It's not quite done yet, but here is a preview.
To see a kind of "Live Preview" you can look HERE
JohnWPB is offline
Old 09-26-2007, 05:41 AM   #2264
Firebird2 is an unknown quantity at this point
Modified DFX Skins
Hey dudes,
Spent alittle time modifying John fantastis skin to suit me requirements and thought you might want to see what I did.
Now all I have to do is create a skin for Destinator 6 and it will be ready to go in to the new car that I pick up on Friday.
Cheers
Firebird2 is offline
Old 09-26-2007, 06:31 AM   #2265
muldrick's Avatar
muldrick is on a distinguished road
Wow, checked out the preview, that's awesome
AtmosUSA.biz, E-Cig Mods
muldrick is offline
Closed Thread
For those who want true 5.1 Dolby Digital and DTS antimatter Car Audio 89 06-29-2007 12:54 PM
Artec T14A Mini USB 2.0 Digital HD TV Tuner LESLIEx317537 General Hardware Discussion 2 12-02-2006 01:02 AM
