View Poll Results: What GPS Program do you use?
iGuidance
607 |
57.00% |
MapPoint
56 |
5.26% |
Destinator
185 |
17.37% |
Streets & Trips
90 |
8.45% |
Other
127 |
11.92% |
01-16-2007, 07:04 AM
#226
Quote: Originally Posted by JohnWPB
Ok, then who were you asking?, now I am confused
For each menu change, it involves changing the the PSD files, and then saving them out in on,off,down for each of the 2 menu's and doing that again for the Digital Clock menu variation, as well as for the new digital clock / compass Variation in the next release. That makes a total of 18 images to create just for a simple menu rearrangement. I wish I could do it, but there is just no way....
I was asking you about it. That is exactly what i was asking for. I guess i will have to wait till you post the PSD files.
Thanks for the response
01-16-2007, 10:28 AM
#227
BM Installer Error Message
John, ref your #224: here is error message I get with the 01/16/07 4:16 am download:
Script: E:\RoadRunner\Run\Skins\DigitalFX BM\Install DigitalFX BM|.vbs
Line: 205
Char: 10
Error: File not found
Code: 800A0035
Source: Microsoft VBScript runtime error
[I am not certain what the character is after the BM in the file name, above]
Reason: corrected typo
01-16-2007, 10:32 AM
#228
JohnWPB,
Managing so many different variants of your beautiful work seems like it would be very time consuming.
May I inquire why you don't create a folder, defined by an environment variable, where the *default/general* files are located and only have the seperate PSD files in thier individual folders? That way only PSD files have to be managed when installing a new theme.
I am at work right now, so I can't see what files can/can't be seperate out. But I figured it might be something to look at....
Nasa
01-16-2007, 11:01 AM
#229
BM Installer Offending Lines
Commenting out the following three lines allowed the installer to run to completion (NoteTab Pro line numbers):
Line 220: objFSO.CopyFile "Road Runner\Mp3Art.dll" ,RRPath, OverWriteFiles
Line 228: objFSO.CopyFile "Road Runner\ScreenLock.dll" ,RRPath, OverWriteFiles
Line 229: objFSO.CopyFile "Road Runner\screensaver.ini" ,RRPath, OverWriteFiles
RRPath = E:\RoadRunner\Run\
Reason: added RRPath variable
01-16-2007, 11:17 AM
#230
Line: 205
Char: 10
Code: 800A0035
Yup, that is the error I was getting. I was going to install it manually but I wanted to make sure you knew about the installer issue. I will give your fix a try and see what happens.
01-16-2007, 01:35 PM
#231
I tried to install the skin and received the same "file not found" error, but a different line number. I then tried the patch that came out 2day and still received an error. I then went to my RR\Skin directory, deleted any folders that had been created from failed attempts and was then able to successfully install the skin? Hope this will help in troubleshooting, seems to have a problem only if it finds an existing directory for me.
01-16-2007, 04:51 PM
#232
Super Moderator
Installer Script
Ok, I really want to get this installer working for everyone. I just spent a couplf of hours going through the installer script and adding a bunch of code. It appears that the problem, was not really a file not found, but had to do with overwriting a file that was registered, and possibly in use. The scrip will no longer copy the .DLL's if they exist already, but will still register them just to make sure. It will also no longer change your screen resolution you have set in the general.ini file, as well as not overwriting your pin code for the screen lock utility.
Someone please give this Brushed Metal version a try and let me know. If all is will I will fix the other 3 installers, and re-upload the complete packages to the server.
EDIT: You will get a few pop-up's that I forgot in the installer script, saying either copied or not copied, those were for testing purposes, and will be removed when released officially on the site for download.
DigitalFX BM.zip
01-16-2007, 05:41 PM
#233
New installer worked for me.
Reason: im stupid
01-16-2007, 06:56 PM
#234
nope I'm still getting this error message
Script: E:\carputer\Install DigitalFX BM|.vbs
Line: 205
Char: 10
Code: 800A0035
even with the new skin file AND updating my V Basic to ver. 6
01-16-2007, 07:01 PM
#235
ok got it to work by
deleting everything in the C:Program Files/Road Runner/Skins folder first.
01-16-2007, 07:45 PM
#236
The test install worked for me, with 3 "not copied" pop ups. This is on a system that previously would not install via script.
Good work!
01-16-2007, 08:02 PM
#237
BM Installer Worked for Me
BM installer ver 1/16/07 4:06 PM worked for me. 3 "not copied" popups.
Thank you for your efforts.
01-16-2007, 08:25 PM
#238
Super Moderator
Line: 205
Char: 10
Code: 800A0035
Ok, I think you are somehow still running the old version of the installer.
"Script: E:\carputer\Install DigitalFX BM|.vbs"
The above line, from your error code still has the |(Pipe Symbol). I removed that on the version I posted above as it was a typo.
01-16-2007, 11:42 PM
#239
Whenever I reboot I get this. Then after I exit the program and restart it, it works fine. Also it's only the main screen, if I press the menu button to go to the 2nd menu everything is fine. Does anyone else get this or know how to fix it? This only happens on my install on my hp laptop. My thinkpad works fine.
Cars:
2001 Lexus es300 carpc Complete! Lexus es300 thread
CarPC: Hp laptop, Lilliput 7'' ts, ig3, bluedevil skin, hauppage tv tuner, bu-353, griffin powermate, backup camera, ps2, headrest monitors, nightvision camera.
2006 Lexus es330 next project.
01-17-2007, 02:51 AM
#240
John,
I tried using your updated installer for BM (the one you posted a few posts above). It worked, but there was a catch. The first time I ran it, I got the same "File not Found" error. However, as another poster mentioned, I deleted the other skin folders in the main skins folder, and it installed just fine. I then had to re-copy the other skins I use into the skins folder.
| Thread Tools |
| Display Modes |
Linear Mode
