View Poll Results: What GPS Program do you use?
iGuidance
607 |
57.00% |
MapPoint
56 |
5.26% |
Destinator
185 |
17.37% |
Streets & Trips
90 |
8.45% |
Other
127 |
11.92% |
02-05-2008, 07:16 PM
#3601
Quote: Originally Posted by dmistry
thats the only change i have made I guess I should try and rename it and see if the CPU usage drops
I'm not sure what you're going to rename, but if you start renaming stuff things will likely stop working. Try deleting ziplocator.dll.
02-05-2008, 07:36 PM
#3602
i do not have ziplocator.dll
I was going to rename zips.dat too like zips.dat.old and see if the CPU goes back down
02-05-2008, 07:44 PM
#3603
Okay, that's a good idea. I'm afraid I have been all the help I can be on this one. I'll have to leave it to better brains.
02-05-2008, 08:30 PM
#3604
I need help with Visualization.
I read the help file and embed my Visualization on the music screen but it does not say anything on how to get it to the top of the main page please help I did a search of this thread and nothing came up. Winamp 5.13 DFX 2.5
02-05-2008, 08:37 PM
#3605
where is john is he on vaca
02-05-2008, 08:45 PM
#3606
Experience has shown that when John isn't heard from for a while good things are about to happen. Patience.
02-06-2008, 09:15 AM
#3608
it says it in the RR help file. click on the top portion of your car logo.
02-06-2008, 09:26 AM
#3609
Kbreeden, so this morning I get in the car and do a restart from the resume and can you believe the CPU issue went away and I now have GPS location working.
One final thing to solve and I should have a fully working system, I have tried a bunch of things to get the volume to lower when GPS is speaking like setting the GPS volume higher than the master volume etc. STill does not work any ideas on this one?
02-06-2008, 09:29 AM
#3610
The Curator
I have talked to john and he still has some work on the skin to do but he is only working on it here and there just like the post he made saying that he's taking it a little more easy.
02-06-2008, 09:44 AM
#3611
May be he will release his code/psds or whatever!  *wishful thinking*
02-06-2008, 09:54 AM
#3612
Super Moderator
*wishful thinking*
02-06-2008, 11:04 AM
#3613
atleast it drew you out John!
02-06-2008, 11:52 AM
#3614
Freefone problem solved
Quote: Originally Posted by mnwcsult
I have come upon the solution by rereading the in file instructions about dialing strings
Quote:
#### Answer and Hangup AT Commands, use *** to show where the dialed number should be.. ie ATD150; is ATD***; ####
Answer=ATA
Hangup=AT+CHUP
Dial=ATD**********; <<<<<<< I have too many stars
The Instructions clearly show ATD followed by (3) ***, my interpertation was a * for each number in a telephone number, as the example showed ATD150 3 digits.
Actually *** is the placeholder for the dialed telephone number. Where the entered telephone number will be substituted for the placeholder ***. And the placeholder is always three *.
02-06-2008, 12:53 PM
#3615
iG Menu off center
Quote: Originally Posted by barnyard
Ok, I've had this problem for a while, and I'm not even sure where to start... see the below screenshot, all of the iGuidance menus are shifted to the left, and cut off. I'm running at 640x480, and everything else works, just the menus are screwy. Any suggestions?
Just incase someone else has this problem, I figured out what was causing it. I had the windows taskbar on the right side of the screen because it's easier to "click" on an 8" touchscreen. The taskbar was shifting iG's menu over the width of the taskbar.
D201GLY2
512 Megs RAM
8" Lilliput
Onstar GPS mod
XM
Visteon HDZ300
| Thread Tools |
| Display Modes |
Linear Mode
