Go Back   MP3Car.com > Mp3Car Technical > Software & Software Development > Front Ends > Road Runner > RR Skins > RR Skins No Longer Supported
View Poll Results: What GPS Program do you use?
iGuidance 607 57.00%
MapPoint 56 5.26%
Destinator 185 17.37%
Streets & Trips 90 8.45%
Other 127 11.92%
Voters: 1065. You may not vote on this poll
Closed Thread
Old 01-06-2007, 11:36 AM   #46
Super Moderator
JohnWPB's Avatar
JohnWPB is a jewel in the roughJohnWPB is a jewel in the roughJohnWPB is a jewel in the rough
Feedback?
I was hoping to get more feedback from the masses here. The skin has been downloaded around 150 times, and just like 15 different people have posted in the thread.
I DO appreciate the comments, suggestions and bug reports so far, but there are far more people using it, and I could use that input as well
I want some feedback on anything that needs fixed, improved on ect. I want to get as much done to this before I start finalizing the other colors, so I don't have to go back and edit each of those individually.
Front End of Choice: Ride Runner (Is there anything else??? ) & Powered by the DigitalFX 4.0 Skin Available at www.JohnWPB.com
My Fiero Build Thread
JohnWPB is offline
Old 01-06-2007, 12:12 PM   #47
TimmyM's Avatar
TimmyM is on a distinguished road
The installer still isn't working for me. I've installed RR at c:\road runner. I've changed the path in roadrunnerpath.ini. But when I run the installer i get the error"
Roadrunner is not installed in the default path: c:\road runner\
Please open the RRPath.ini and put the full path to Road Runner on your system. WHen you have done that, run the installer script again.
TimmyM is offline
Old 01-06-2007, 01:52 PM   #48
TimmyM's Avatar
and I'm having problems with the AVS file. I can't seem to get them to work in Winamp by it's self. I got one to work but when i right click on it to edit it nothing happens.
TimmyM is offline
Old 01-06-2007, 01:56 PM   #49
kbreeden
Quote: Originally Posted by JohnWPB View Post
I was hoping to get mre feedback from the masses here. The skin has been downloaded around 150 times, and just like 15 different people have posted in the thread.
John, maybe it's just that it's that good. Usually people post only if there's a question or problem. In this case,though, it would be equally helpful for people using the skin to post saying that they're using it and not experiencing any trouble. That way you'll know it's in pretty good shape and can feel comfortable implementing the new colors.
So those of you happily using the skin without any trouble, please help out and make a post saying so.
kbreeden is offline
Old 01-06-2007, 02:34 PM   #50
Zeeshan0581 is an unknown quantity at this point
JohnWPB,
i fixed the logo issue, needed a newer version of flash.
GPS i am using iGuidance 3.0, working like a charm. One issue though, whenever i start GPS for the first time, it doesnt start as maximized, i have to click the double window button under 'Repeat Command' button for it to fix it.
I still cant get Control Panel, wireless settings, bluetooth settings, and display settings to do anything inside settings option, probably something with my system.
Is there a way to stop the system beeping every time i use touch screen, anyone else getting the beep?
Would love to see a Silver Version of the screen..... whenever you get to it.
Zeeshan0581 is offline
Old 01-06-2007, 02:51 PM   #51
klundy is an unknown quantity at this point
Ok fine. I'll skip the good comments and only post a problem
1) The help file says that to use S&T, all you have to do is configure it in rr.ini. Well you do have to go remove the comment / in the tbl file
2) When in the music player and you select GPS, it either loads the IG screen, or does nothing. Of course, I am only running S&T.
Any plans to imbed (or create) a ODBII interface?
Oh yea, one more teeny bug in the helpfile - in the CD Rip help, it points to rrdownload which of course doesn't work any more.
I hope you know I'm only being sarcastic and really do appreciate your hard work Paypal coming soon.
Kevin
klundy is offline
Old 01-06-2007, 02:52 PM   #52
Confusion Master
Enforcer's Avatar
Enforcer has a brilliant futureEnforcer has a brilliant futureEnforcer has a brilliant futureEnforcer has a brilliant futureEnforcer has a brilliant futureEnforcer has a brilliant futureEnforcer has a brilliant futureEnforcer has a brilliant futureEnforcer has a brilliant futureEnforcer has a brilliant futureEnforcer has a brilliant future
Tell me about it. you get about 1% of downloaders giving feedback
Enforcer is offline
Old 01-06-2007, 03:26 PM   #53
The Lavender Tie Just
Made It Obvious
Rafster's Avatar
Location: Bonita, CA (Hop, Skip, and a Jump from Tijuana, Mexico)
Rafster is a name known to allRafster is a name known to allRafster is a name known to allRafster is a name known to allRafster is a name known to allRafster is a name known to all
BTW, if you're worried about bandwidth issues, send it to http://www.mobile-effects.com/
He hosts a whole bunch of skins and front-ends for people on the site... for free!
Rafster
Post # 3000
Items for Sale
PM me!! Not using new Classifieds because I don't particularly like the way it works...
http://www.speedtest.net/result/133342788.png
Rafster is offline
Old 01-06-2007, 03:27 PM   #54
Super Moderator
JohnWPB's Avatar
Road Runner Installer
Sorry! That was a mistake on my part in the script. I decided to change it half way through, and forgot to change some of the variables. I just went through and fixed it, and HOPEFULLY it will work correctly now. You can download the installer script on the same page linked in the first post instead of having to DL the entire skin again.
You will ONLY need this installer if Road Runner is not installed to the Default Location:
"C:\Program Files\ Road Runner\"
JohnWPB is offline
Old 01-06-2007, 03:46 PM   #55
Super Moderator
JohnWPB's Avatar
Digital FX Issues, ODBII and such...
The beep you are hearing is from your touch screen software. You can go into the preferences for the TS software, and change th epitch of the beep, duration, or turn it on/off
1) Forgot about that... sorry
2) You can change what GPS software gets embedded by changing the button code on the GPS button oin the audio players skin file. I put iGuidance there, as that is what I use. I cant make an individual audio screen for all the GPS programs out there.... sorry. I will see about putting the commands necessary in the help file to make it easier to do.
3) ODBII is next on my list of MAJOR items. It is going to be a little bit down the road though, as I have ye to get the hardware and such for testing. I plan on using the donations from the PayPal link for just that purpose. This way I get something, but it is something to make the skin better for everyone at the same time.
JohnWPB is offline
Old 01-06-2007, 05:03 PM   #56
DJiK's Avatar
DJiK will become famous soon enough
Jump To File Plugin by Cdjk. This is an amazing plugin. You can see on the left I entered "Meat bat pa" and it was able to instantly find: Paradise By The Dashboard Lights, by Meatloaf, on the Bat Out of Hell CD. This plugin is amazing, has quite a few features and is a nice addition to Road Runner for sure!
What a nice way to spell my nick...
I've read your notes and I'll try to take care of what you had asked for in a future release. One thing I'm not sure whether you know or not, my plug in is fully skinnable. That means you can resize/reposition/remove the buttons if you need to.
For Sale: Carputer (CarPC) & RCA Y-Adapter
Newsflash: Take a look at my unsold stuff above, thanks!
Up Next: Make an OBD to Serial cable & Redo the "MMI buttons"
DJiK is offline
Old 01-06-2007, 05:58 PM   #57
kbreeden
John,
On the music playlist screen and music browser screen when I hit GPS the GPS skin comes up but the IGuidance map doesn't load (100% of the time). The IGuidance map comes up everywhere else.
kbreeden is offline
Old 01-06-2007, 06:21 PM   #58
Super Moderator
JohnWPB's Avatar
GPS Buttons on the Audio Screens
Hehehe it wasn't a misspell, but a bad typo. Sorry, it has been corrected.
Quote: Originally Posted by kbreeden View Post
John,
That is something that slipped right through the crack with all the beta testing by everyone, and myself! Not only that, those buttons have been there starting in the Blue Devil skin, since October, when iGuidance became natively embedded in Road Runner, and iGLaunch was no longer necessary to use
It has been fixed, and will be in the next release.
In the mean time, if anyone wants to fix it them self, you can replace the button code on those to screens that call it. Find this line:
Code:
"LOAD;External_GPS.skin;iGLaunch;C:\Program Files\iNav\iGuidance\iGLaunch.exe;iGLaunch"
And simply replace it with "GPS"
JohnWPB is offline
Old 01-06-2007, 06:23 PM   #59
Super Moderator
JohnWPB's Avatar
Rafster
Sorry, I missed responding to this one somehow. I will check into that.. thanks!
JohnWPB is offline
Old 01-06-2007, 09:44 PM   #60
SangreDeThor is an unknown quantity at this point
How this for new school! i am back at school finnally, can get back into the dorms tommorow. staying at a friends tonight. Its good to be back.
CarPuter: 900Mhz P3 with 256 MB Mem, 160 Gig HD (Thanks kbreeden), Iguidance 3.0 GPS, Logitech PS2 keyboard, Bluetooth, WIFI.
Powered By Road Runner & DigitalFX Skin and Playlist Conveter
SangreDeThor is offline
Closed Thread
For those who want true 5.1 Dolby Digital and DTS antimatter Car Audio 89 06-29-2007 12:54 PM
Artec T14A Mini USB 2.0 Digital HD TV Tuner LESLIEx317537 General Hardware Discussion 2 12-02-2006 01:02 AM
