Sorry about the weather issues, Sonixxtasy02 just released the code the day after the new RR came out, and the skin was released the very next day. There are still some issues to work out and all, and that is not quite completed / bug free as of yet.
Quote: Originally Posted by
Bump
I just checked my Weather 5th button. It works.
Go to your " GPS stats " window to see if your GPS is locked on.
it takes a little bit to get the first time. wait 1 min or so.
John - the weather locater works . But, I live in Chambersburg,PA and the weather finds me at Chambersburg,IL. ( that is on the 5th button readout.)
I alway had to put the state in on the button presets to get my location. And is the name on that button changeable ? can it be changed to "GPS Area " or anything other thing that make more sense . Or does it suppose to change with area.
Are we suppose to add " localdatacaptureinterval=* " to rr.ini ?
The button label is supposed to show the name of the city that you are currently in. I can make it so you can press and hold the button to name it whatever you want to. That will not change the function of the button, it will still be based on GPS, but it will change the label of the button if you want to.
Yes, that is one thing I overlooked, (Thanks Bump) you do need to place the following line in your RR.ini file:
localdatacaptureinterval=1
(the 1 is the interval, in minutes, that the information is updated). Meaning if it is set to 1 that it will be one minute after RR starts, before the weather is available.
I haven't had it happen here, but I did read where one person posted that RR would sometimes hang, if you accessed the local weather without a GPS device connected.
Thanks again for the screen cap's Bump, The new one you put with the moon and the weather is sick! Wow! (So what do you guys think of the new weather icons?
Now I want to see more screen captures from the rest of you guys! I spent a lot of time on this skin making it transparent, and wanna see what you have made the skin look like!
