Go Back   MP3Car.com > Mp3Car Technical > Software & Software Development > Front Ends > Road Runner > RR Skins > RR Skins No Longer Supported
View Poll Results: What GPS Program do you use?
iGuidance 607 57.00%
MapPoint 56 5.26%
Destinator 185 17.37%
Streets & Trips 90 8.45%
Other 127 11.92%
Voters: 1065. You may not vote on this poll
Closed Thread
Old 04-17-2007, 08:18 PM   #871
Bump's Avatar
Bump is on a distinguished road
Quote: Originally Posted by Ramanator View Post
John, back in post#825 ("mine") I was tring to show you my "RR.ini" file, My file was named diffrently; but the pic didnt host so im tring again, also in post#819 I had mentioned that (after "EDITING") The problem was fixed on my end thanx to Bump. I had 2 Fastmode codes installed.I had to delete the "Fastmode=1" code. It even fix my "weather icon" issues i had awhile back.
Thanx guys.
that is it. You just did not set your OS to show you the " .INI " part
in side should be a list of comands. *****=*****
Bump is offline
Old 04-17-2007, 08:22 PM   #872
Ramanator's Avatar
Ramanator will become famous soon enoughRamanator will become famous soon enough
Hey Bump thanx again Bro, But how is that done (setting the OS....)
If you cant DODGE em, RAM em.
Ramanator is offline
Old 04-17-2007, 08:26 PM   #873
Bump's Avatar
Control Panel = Folder options = view (tab) = ( uncheck ) Hide extensions for known files types
apply , and check the rr file . it should read rr.ini
Bump is offline
Old 04-17-2007, 08:28 PM   #874
Ramanator's Avatar
Thank you sir, U R the man. Although i should have known that, sometimes its the smallest things that get by ya.
Old 04-17-2007, 09:20 PM   #875
mdlesk is an unknown quantity at this point
Don't feel bad, it happens to everyone. I'm having a similar problem. Everytime I boot I get an iguidance error and I just choose don't send. It's getting kind of annoying. I have alerter turned off along with tons of other services, I know there is a simple solution. I just can't seem to remember it in now though
mdlesk is offline
Old 04-17-2007, 10:09 PM   #876
Bump's Avatar
start = run = (type in )msconfig =enter = (tab) startup.
look in there. uncheck what you don't want to start up.
Bump is offline
Old 04-17-2007, 10:12 PM   #877
that won't work for several reason, one of which I don't boot into explorer and even when I try to run explorer it only opens up the explorer window, no desktop, no start, no taskbar, nothing. I use RR as the front end and it works good except that I get that iguidance error on load
mdlesk is offline
Old 04-17-2007, 10:30 PM   #878
meisner is an unknown quantity at this point
Quote: Originally Posted by meisner View Post
I tried the steps as you laid them out and the first time after the change I started RR/DFX and got the 19 sec delay. I then exited and restarted RR/DFX 5 more times and never saw the delay.
The first time I was resuming from a hibernate...don't know if that matters.
I use hibernate just about every time...no shutdowns. But when I was seeing the 19 second delay regularly it was from exiting and restarting RR/DFX.
I am going to keep the setup I have now and see how it acts.
Well, I am still seeing the delays even with Flash 8 and a non-flash setup in DFX 2.0. But...I only saw the delay when the GPS system within RR/DFX was trying to get a satellite fix (to do the speed adjusted volume). Once the speed was determined, things worked OK.
This problem is really bad up here in the northeast right now with such heavy cloud cover for both GPS and XM signals. I loose the signals very easily. Could this sort of thing help explain why some are seeing the problem and others aren't?
meisner is offline
Old 04-17-2007, 10:54 PM   #879
Bump's Avatar
I thought it was fixed with 2.0 version
in your skin Check your " ExecTBL.ini" file
see if you have :
Code:
/"ONSKINSTART","RUNQW;$SkinPath$Scripts\OnlineStatus.exe||RUNQ;$gpspath$|NOWARNING"
If so , replace it with this one:
Code:
/"ONSKINSTART","RUNQW;$SkinPath$Scripts\OnlineStatus.exe"
that was the fix for the older version.
I'll look into it a little more.
Bump is offline
Old 04-17-2007, 11:04 PM   #880
Thanks, that has to be it since it only started after I went from 2.0 to 1.0 blue. I'm going to give that a shot. If it doesn't work I'll just reinstall the first release of 2.0.
mdlesk is offline
Old 04-18-2007, 04:22 AM   #881
Super Moderator
JohnWPB's Avatar
JohnWPB is a jewel in the roughJohnWPB is a jewel in the roughJohnWPB is a jewel in the rough
Quote: Originally Posted by klundy View Post
John, or anyone else -
Any thought why these labels would work under FX Blue, but will not work under FX 2.0?
L,470,10,50,23,255,255,255,12,"Arial:B","BATTPERCE NT","LEFT"
L,295,10,70,23,255,255,255,12,"Arial:B","POWERSRC" ,"LEFT"
I have these on my main menu.skin. I also have
L,650,290,50,23,255,255,255,16,"Arial:B","GPSSAT", "CENTER" which puts the current satellite count in the middle of the GPS button. That one works. I did that because I had a problem with xport at one time and this was a quick way to see if it was working, then I liked it. No use to load IG if no satellites.
Sorry, I have made a bad habbit of putting hidden lablel's and such in that area for testing purposes here. Thats why you cant see your labels, because there is already something there. I have cleared that area out, and your labels will work when I get the next release out here soon.
Front End of Choice: Ride Runner (Is there anything else??? ) & Powered by the DigitalFX 4.0 Skin Available at www.JohnWPB.com
My Fiero Build Thread
JohnWPB is offline
Old 04-18-2007, 04:45 AM   #882
The Last Good Gremlin
GizmoQ's Avatar
GizmoQ has a spectacular aura aboutGizmoQ has a spectacular aura about
I just realized the next and previous buttons in the Radio skin don't work. As a matter of fact the next and previous don't support radio or XM - I changed them on every screen to RRNEXT and RRPREV and all is well again in my world.
Now the radio skin has two sets of buttons for next (chan+) and prev(chan-).
HARDWARE: Fujitsu Stylistic ST5031w/WiFi and dock, internal MP3Car 80G HD,, external 1TB HD, Sierra Wireless Aircard 550, DVD-RW, Silabs FM, WinTV USB, XM Commander w/Timetrax USB, Delorme GPS, Saitek X-52 joystick, BluSoleil Bluetooth, TPMS, FB, Elm327
GizmoQ is offline
Old 04-18-2007, 06:51 AM   #883
astrapc is an unknown quantity at this point
Ive got this skin working, and its really good. I especially like the media, player option which shows the gps in the window to the left. Awesome!
One question I have is, is there any way to reduce the volume of the gps voice instructions in freedrive so the instructions arent as loud as the music your playing....or indeed switch them off completely??
Any help would be great, as some of the voices are so loud when your on the motorway that it sounds like the woman is screaming at you! really off putting, especially when she says the same thing three times!!!
astrapc is offline
Old 04-18-2007, 06:55 AM   #884
klundy is an unknown quantity at this point
No, that's not it. I think I found your hidden label. I also have just text label up there ("=Power") and those are displaying fine. I also tried substituting GPSSAT on one of the top labels and it does display there.
I repeated my labels on menu2.skin and the text part displays, but not the variable.
Can someone else please try adding these lines and see if anything actually dispays?
Kevin
klundy is offline
Old 04-18-2007, 08:51 AM   #885
John, has there been any update on the GPS Speedometer? Mine is still way off. I think it was at like 110 when i was going 70. That's a little off lol. Is there any code I can change to fix the issue?
mdlesk is offline
Closed Thread
For those who want true 5.1 Dolby Digital and DTS antimatter Car Audio 89 06-29-2007 12:54 PM
Artec T14A Mini USB 2.0 Digital HD TV Tuner LESLIEx317537 General Hardware Discussion 2 12-02-2006 01:02 AM
