Go Back   MP3Car.com > Mp3Car Technical > Software & Software Development > Front Ends > Road Runner > RR Skins > RR Skins No Longer Supported
View Poll Results: What GPS Program do you use?
iGuidance 607 57.00%
MapPoint 56 5.26%
Destinator 185 17.37%
Streets & Trips 90 8.45%
Other 127 11.92%
Voters: 1065. You may not vote on this poll
Closed Thread
Old 04-18-2007, 06:29 PM   #901
shot598 is an unknown quantity at this point
john it works
shot598 is offline
Old 04-18-2007, 06:33 PM   #902
Bump's Avatar
Bump is on a distinguished road
Quote: Originally Posted by meisner View Post
Also, is Rip CD working yet? Cause it's not in my setup. When I click on rip cd, I just get a loooonnnnnggg pause...then nothing.
Steve
cd ripper is a plug-in you have to get and in stall in your RR folder. It is not in the skin.
get it here CD Ripper plug-in
Bump is offline
Old 04-18-2007, 07:09 PM   #903
Super Moderator
JohnWPB's Avatar
JohnWPB is a jewel in the roughJohnWPB is a jewel in the roughJohnWPB is a jewel in the rough
Quote: Originally Posted by shot598 View Post
john it works
Could you explain just a little bit? Were you having the CPU isssues, and you followed the instructions about double clicking the Photo.exe and it cleared up the problem? Or all was well for you since installing it?
As for the CDRip, there is a FAQ at the top of the main page of the forums. The skin only has, just that, a skin for it. You have to configure it to get it to work correctly.
NOTE: If the loading...... screen stays there for more than a few seconds, just click it. The entire page is a huge "Back to Menu" button.
Front End of Choice: Ride Runner (Is there anything else??? ) & Powered by the DigitalFX 4.0 Skin Available at www.JohnWPB.com
My Fiero Build Thread
JohnWPB is offline
Old 04-18-2007, 07:17 PM   #904
klundy is an unknown quantity at this point
Quote: Originally Posted by klundy View Post
No, I'm not that smart
They work just fine in Digital Blue FX - I can provide screen shots later. All from the same RR install.
Unless ... is exectbl.ini per skin?
Edit: ahh, your comment that you couldn't find the commands made me search. It is a plugin, and I need to register the plugin on your new menu.skin Nice little plugin
http://www.mp3car.com/vbulletin/rr-p...op-carpcs.html
Kevin
Boy, it sure helps when you tell a skin to use a plugin before trying to use variables from the plugin
John, since you mentiond hidden buttons you intended to clean up, I think you have one on menu2 for the valentine?
Also, this is a REAL tiny nit pick - the size you have defined for bdlogo between menu and menu2 changes, which causes the logo to change visibly. I made mine equivalent, and I think it makes the screen change more professional looking.
Now I just need a way to track my changes, so when you make your changes I can get them all back in
Keep up the good work! Might soon be time for more beer money.
klundy is offline
Old 04-18-2007, 07:27 PM   #905
when i installed 2.1 the cpu is at a 100 if I tried to touch any of the buttons nothing happen.
shot598 is offline
Old 04-18-2007, 07:35 PM   #906
Super Moderator
JohnWPB's Avatar
Ok, Now I am confused, but that doesn't take too much
Just a couple posts back you said "It Works". Now you say that is is locked at 100% CPU?
JohnWPB is offline
Old 04-18-2007, 08:23 PM   #907
mdlesk is an unknown quantity at this point
John, to clarify my situation. When I used 2.1 it was having the flash issue at 100% I downgraded it to 2.0 and it worked, obviously due to no flash logo. Sorry for not explaining I still had the old installer and I downgraded it in order to be use the PC.
mdlesk is offline
Old 04-18-2007, 09:13 PM   #908
no that was the problem i was having before u told me what to do
shot598 is offline
Old 04-18-2007, 09:25 PM   #909
Super Moderator
JohnWPB's Avatar
And doing that fixed your problem then?
JohnWPB is offline
Old 04-18-2007, 10:17 PM   #910
yes sir
shot598 is offline
Old 04-18-2007, 10:41 PM   #911
tn6478's Avatar
tn6478 is an unknown quantity at this point
Quote: Originally Posted by JohnWPB View Post
Yea, I learned my lesson! ALL future updates will default to a non flash screen! In the mean time open the DigitalFX skin folder, then the MENU folder. Double click the Photo.exe file. This will manually copy the non flash skin into the main skin folder.
On a side note, its not your MII12000 board that can't handle it, you have a Flash problem. I just built a CarPC for a friend with that same exact board and it worked fine.
flash works good on my system. I am using flash 9 should i be using 8
tn6478 is offline
Old 04-18-2007, 10:43 PM   #912
meisner is an unknown quantity at this point
Well...I just went out and upon starting the car, the CarPC resumed from a hibernate...the 19 second delay was back. UI was frozen...I couldn't click on anything...then 19 seconds later, RR resumed.
Whe I got to my destination, I shutdown the PC. When I restarted from the power down, got the 19 second delay again.
I am currently running with the goofy photo of a car (from the Photo.exe)...so no flash.
Sorry John...
meisner is offline
Old 04-18-2007, 11:28 PM   #913
lbridges is an unknown quantity at this point
JohnWPB,
Although I don't use your skin, I do need to thank you for creating it. I guess that needs a explanation (I'll try to keep it short, but no promises).
When I decided to put in a car computer a couple of months ago, I found and joined mp3car forums. Road Runner seemed to be the most active group and the open licensing/support is attractive to me.
I'm the type of guy who wants to know how things work, and I'll be the first to admit I couldn't do what guys like guino do, but I wanted to create my own skin so I could get some sort of handle on what the system was doing.
I must have downloaded about a dozen skins, many too complex for me to handle. Some simple, but lacking enough that I wasn't grasping how a lot of things came together.
Bottom line, just like in Goldilocks, your skins were "just right"...although with the new transparent stuff I think you just leapfrogged way past me again.
Anyway, thanks from a Florida neighbor (Indialantic, about 100 miles North of you).
lbridges is offline
Old 04-19-2007, 09:49 AM   #914
Super Moderator. If my typing sucks it's probably because I'm driving....
turbocad6's Avatar
turbocad6 is a splendid one to beholdturbocad6 is a splendid one to beholdturbocad6 is a splendid one to beholdturbocad6 is a splendid one to beholdturbocad6 is a splendid one to beholdturbocad6 is a splendid one to beholdturbocad6 is a splendid one to beholdturbocad6 is a splendid one to behold
ok, I've been trying to get this skin to work for me & I'm having a problem that I haven't seen mentioned here before,
after I install it & try to run rr, I only get a thin band in the center of my screen, I added the lines to the rr.ini & I upgraded flash from 8.X to 9.X, I tried this on 2 differnt tablets both with seperate downloads, both same results???
also, I noticed a few other oddities,
one is that the skin is looking to install to a default that's: ...\road runner, but my defaults are ....\roadrunner without a space, maybe it's just my installs, but both are like that by default, not a problem as I just added the space to my folder rather than specifying the different dirrectory
second thing is, your installer installs another roadrunner.exe on my desktop each time, but it is not linked to the actual roadrunner.exe in my roadrunner(road runner) file, but seems to be it's own, & this is the one that gives the error msg of ".....desktop\ALPINE does not contain a valid skin"
man, I've dreamed of a transparent skin for so long, & wanted that look so bad that I even built my own skin over a year ago that had the appearance of transparency( http://www.mp3car.com/vbulletin/cf-s...3-traffic.html ), but this is just amazing, mad props to you john, even though I have yet to actually see this work on MY system
I'll admit I haven't had a ton of time to play with trying to get this working, but I'm a little at a loss of where to start, I guess I'll start with a fresh install & see....
P.S., please excuse the messy desktop in the screenshot also, everything around this center slot display is clickable like nothings there... strange..., my other skins work no problem I think, & yeah, I did try the non flash versions both ways, by the photo.exe & even copying the contents of the folder manually & overwriting...
turbocad6 is offline
Old 04-19-2007, 09:56 AM   #915
Confusion Master
Enforcer's Avatar
Enforcer has a brilliant futureEnforcer has a brilliant futureEnforcer has a brilliant futureEnforcer has a brilliant futureEnforcer has a brilliant futureEnforcer has a brilliant futureEnforcer has a brilliant futureEnforcer has a brilliant futureEnforcer has a brilliant futureEnforcer has a brilliant futureEnforcer has a brilliant future
Quote: Originally Posted by turbocad6 View Post
second thing is, your installer installs another roadrunner.exe on my desktop each time, but it is not linked to the actual roadrunner.exe in my roadrunner(road runner) file, but seems to be it's own, & this is the one that gives the error msg of ".....desktop\ALPINE does not contain a valid skin" ...
You need to copy that exe over the one in your road runner folder (after backing up the one there)
Enforcer is offline
Closed Thread
For those who want true 5.1 Dolby Digital and DTS antimatter Car Audio 89 06-29-2007 12:54 PM
Artec T14A Mini USB 2.0 Digital HD TV Tuner LESLIEx317537 General Hardware Discussion 2 12-02-2006 01:02 AM
