View Poll Results: What GPS Program do you use?
iGuidance
607 |
57.00% |
MapPoint
56 |
5.26% |
Destinator
185 |
17.37% |
Streets & Trips
90 |
8.45% |
Other
127 |
11.92% |
05-18-2007, 03:17 PM
#1411
Quote: Originally Posted by nasa
Guys,
If I recall correctly, that feature is already there. Try left-click and hold on the location of interest to get the add favorite menu up.
Nasa
Its there with the right click of the map, it shows a pop up menu and has the option to store your current location, but it would be nice to have it embedded.
05-19-2007, 07:12 AM
#1412
Hi all...... when i start digitalfx i have this screen:
Any ideas??
05-19-2007, 07:46 AM
#1413
did you add these lines to rr.ini
Did you add the code to RR.ini that was on you desktop?
you have to add this to your RR.ini.
picspath=C:\Program Files\Road Runner\skins\DigitalFX 2.0\Backgrounds
fastmode=-1
localdatacaptureinterval=10
in the localdatacaptureinterval=10 command. you can replace 10 with any amount of Minute you want the Weather to reload. 0=Manual reloading: 1-30 mins.
05-19-2007, 08:24 AM
#1414
fastmode=-1
yES!!  i put all in my rr.ini but nothing.
05-19-2007, 08:31 AM
#1415
Raw Wave
..and you copied the RoadRunner.exe from your desktop into the roadrunner folder..right?
05-19-2007, 09:10 AM
#1416
heheh yes.. all skins work, simplistique, freedom, freedom ultimate, blue devil, my skin, but i cant start digitalfx
BLUE DEVIL IS THE MOST COMPLET SKIN THAT EVER SEE, others are beuty and nice, but blue devil is the moooost complet, i cant wait to see this new version.
05-19-2007, 09:41 AM
#1417
Raw Wave
Do one more thing before you re-download and re-install: make sure your shorcut to RR is pointing to the right roadrunner.exe.
I had renamed the old exe to roadrunnerbeforedfx.exe then copied the one from the destop to the RR folder but still got the black bar; for some reason i checked the shortcut and it was still using roadrunnerbeforedfx.exe
I moved the old file out of the rr directory and remapped the shortcut to use the new rr.exe and PUFF! all was well..
Try that and if not, reinstall..
05-19-2007, 10:51 AM
#1418
Where i can download Roadrunner last version clean, not only the roadrunner.exe..... all suite with rr.ini, and all files need to have roadrunner clean?
05-19-2007, 11:06 AM
#1419
Raw Wave
http://www.kompassist.co.uk/
05-19-2007, 03:46 PM
#1420
Any ideas??
Use the RR updater to update to the latest version of RR and you should be all set.
05-20-2007, 03:46 AM
#1421
cant start the skin
hello everybody,
I have the folowing problem installing the skin.
I get after installing the skinn only a vertical black stripe 2 cm wide with in the end a pink color.
A tried it on diferend computers but all gave the same problem.
I thought first that i have to install flash but with no succes.
already thanks for the respond
it is the same as the post above
I have tried the updater but it sad that it was unsucceded
05-20-2007, 07:22 AM
#1422
Go to Guino's site and download the latest binary there.
05-20-2007, 07:50 AM
#1423
One of the best yet - asking a question when the same question and the answer are the immediately preceding post!
05-20-2007, 11:31 AM
#1424
still can't find these files ....
Quote: Originally Posted by leatherboy
Does anyone know where to find the Destinator_OFF.png and Destinator_On.png files? There aren't in the DFX folder and I didn't find anything in this thread. I need them to start GPS (Map Monkey) from the main menu.
where can i get them ?
05-20-2007, 11:34 AM
#1425
re: black stripe 2 cm....
hello everybody,
the problem is that you dont have a flash player. d/l from adobe its free
http://www.adobe.com
| Thread Tools |
| Display Modes |
Linear Mode
