Go Back   MP3Car.com > Mp3Car Technical > Software & Software Development > Front Ends > Road Runner > RR Skins > RR Skins No Longer Supported
View Poll Results: What GPS Program do you use?
iGuidance 607 57.00%
MapPoint 56 5.26%
Destinator 185 17.37%
Streets & Trips 90 8.45%
Other 127 11.92%
Voters: 1065. You may not vote on this poll
Closed Thread
Old 05-20-2007, 11:45 AM   #1426
EL_GRECO101's Avatar
EL_GRECO101 is an unknown quantity at this point
Question VB Problem???
The fact that no VB command correspond aright (like "Sendkey…."), it would be VB problem runs on my PC?
No command "Sendkey" correspond in my RR.
How I know that the VB does work properly, only from the fact that RR does play?
Does anybody has similar problems and how encounter them??
Virtuousness & Daring...!
EL_GRECO101 is offline
Advertisement Sponsored links
Old 05-20-2007, 06:48 PM   #1427
kbreeden
John, I've just started using Lostreception's igqwerty plugin with your igqwerty skins. I'm having the same problem addressed in the following post from the igqwerty thread:
Quote:
sorry bro. i just went to my car and tested it. works fine. i did address/city first and put in my city and this time it didn't jump back to the first city in the list for my state. i think before too it had said "enter city" when i was putting in the street, on the buggy ig-q. didnt notice if it was correct this time. i was using the blue devil or whatever that skin version of ig-q was called and of course with this beta it is regular colors which is fine.
thanks lostreception
that enter city part was becuase of the original skin that JohnWPB had made it covered the iguidance text and he had static text up there that said enter city
so whenever the OSK popped up it would always say the same thing
I'm wondering if you have addressed this issue in any way. No big deal to go back to the default screens if you haven't, but I thought I'd ask because it does look cleaner with your skins.
kbreeden is offline
Old 05-20-2007, 10:57 PM   #1428
shot598 is an unknown quantity at this point
am trying to get winamp to mute when iguidence speak. i work for alittle then it just stop..i did everything in the DigitalFX Help.still cant get it to work again
shot598 is offline
Old 05-21-2007, 04:02 AM   #1429
ArikDpc is an unknown quantity at this point
where are "Destinator_OFF.png and Destinator_On.png "?
I use this skin with mapmonkey , and these files are listed in the skin.
does anyone has them in his digitalfx 2 skin library ?
thanks
ArikDpc is offline
Old 05-21-2007, 11:01 AM   #1430
Super Moderator
JohnWPB's Avatar
JohnWPB is a jewel in the roughJohnWPB is a jewel in the roughJohnWPB is a jewel in the rough
Guys, I am sorry for not posting here for the past couple weeks!
I am in the process of buying my first home, and it has been crazy here. I haven't touched RR, the skin or anything related to it in the past couple weeks. I have been working with lending companies, home inspectors, trips to the bank and an endless amount of other related paperwork and stuff. If all goes well, it unfortunately will be a bit longer before I get back to working on the skin, as I will be moving and it will just be crazy for the next month or so. Time and money are just very tight right now (Need $15,000 Cash for the down payment at closing!).
Please bare with me, and I am so thankful for many of you that have stepped up to answer a lot of the questions posted in this thread! It is much appreciated!
On another note, thanks to all of you, this skin has become pretty popular! it is both the thread that has the most posts in the skin forums, as well as the most views, wow! Thats crazy, as many skins have been around for a year or two, and this thread was just started in January!
Front End of Choice: Ride Runner (Is there anything else??? ) & Powered by the DigitalFX 4.0 Skin Available at www.JohnWPB.com
My Fiero Build Thread
JohnWPB is offline
Old 05-21-2007, 11:23 AM   #1431
Capri28 is an unknown quantity at this point
re 2 cm black strip
i just got the same as the others back 1 page, when i installed on the carputer.
tryed everything then i reinstalled the skin files again and all was well,
the only thing i can think of is that some reg files did'nt get reged the first time round.
quick q. of my own . dose sonixs locate pluging work with the zips.dat file,
if so i'm assuming this that it has zip codes to match gps .so the zips will be USA only, this could be why its not working for me.
good luck on the house john not an easy buy, over here they are making it more difficult to by all the time, thats the Goverment for ya.
Capri28 is offline
Old 05-21-2007, 12:40 PM   #1432
nasa is an unknown quantity at this point
JohnWPB,
Good luck with the home buying... I've been through it quite a few times, and everytime has it's own challenges. Hope it goes well. If you need any hints don't hesitate to pm me.
Nasa
nasa is offline
Old 05-21-2007, 03:10 PM   #1433
nammertat's Avatar
nammertat is an unknown quantity at this point
Problem with iGuidance / Internal volume
Hello!
I'm having a couple problems with this skin, both of which are probably my fault. First off, when I access iGuidance through roadrunner, it pops up in another window rather than within the skin itself. I checked the help file and couldn’t find the answer. Secondly, when I increase or decrease the volume within the skin, my system volume is immediately brought to zero, and I have to go into control panel to turn it back up.
Any input would be HUGELY appreciated!
nammertat is offline
Old 05-21-2007, 04:57 PM   #1434
Raw Wave
treetop777's Avatar
treetop777 is an unknown quantity at this point
Quote: Originally Posted by nammertat View Post
Hello!
Check to make sure the GPS window name is correct in RRConfig; should be exactly as you spelled it above. Also look for this line in rr.ini: ignative=true.
Also in RRconfig under "music" there is a setting to map the master volume; set it to "master volume". Once you do that, set the computer volume to zero then set the volume to zero in the skin. From then-on, adjust the volume from within the skin.
treetop777 is offline
Old 05-21-2007, 05:30 PM   #1435
mdlesk is an unknown quantity at this point
Okay, I am having a problem that I know at least a few people know a solution to. I am looking to embed a few things on the launch (External Apps) screen. I looked at the Programs and Launch skins and i just can' seem to figure out where to add the lines or even find the lines for the default options (calc, explorer, etc.) I did a search and read the post about the person that embedded Outlook so I know it's possible. I've been trying to figure out this for the longest time and the only thing I can do now is just ask.
mdlesk is offline
Old 05-21-2007, 07:25 PM   #1436
Volsfan's Avatar
Volsfan is on a distinguished road
John, the first house is the toughest. Once you get some history on paying mortages, it seems to get a little easier when you purchase again.
Besides, when this skin is purchased by Microsoft for tens of millions, you can buy the bank and fire the folks that made you jump through all the hoops in the first place.
Just close and move before the boards are shipped...LOL
Tennessee Vols Fan
Volsfan is offline
Old 05-21-2007, 07:29 PM   #1437
SangreDeThor is an unknown quantity at this point
HAHAA. maybe mp3car will buy your skin
CarPuter: 900Mhz P3 with 256 MB Mem, 160 Gig HD (Thanks kbreeden), Iguidance 3.0 GPS, Logitech PS2 keyboard, Bluetooth, WIFI.
Powered By Road Runner & DigitalFX Skin and Playlist Conveter
SangreDeThor is offline
Old 05-21-2007, 07:41 PM   #1438
I found the Launch directory where everything is. I can't believe I missed it. I guess I didn't even think to look in the RR directory. The problem I am having now is I can't figure out the ini. I tried a ton of things but nothing seems to work. I got the first 2 lines correct, i believe but I'm not sure about the last 2 lines. Does anyone have an example INI, the ones in the Launch directory aren't really helping.
Good luck with everything John.
mdlesk is offline
Old 05-21-2007, 10:40 PM   #1439
does any1 have this problem am trying to get winamp to mute when iguidence speak. i work for alittle then it just stop..i did everything in the DigitalFX Help.still cant get it to work again
shot598 is offline
Old 05-22-2007, 08:38 AM   #1440
kbreeden
Hello!
It sounds like you're using the wrong window name in RRConfig. Go into RRConfig under the GS tab and make sure the GPS window name is "iGuidance" (no quotes).
kbreeden is offline
Closed Thread
For those who want true 5.1 Dolby Digital and DTS antimatter Car Audio 89 06-29-2007 12:54 PM
Artec T14A Mini USB 2.0 Digital HD TV Tuner LESLIEx317537 General Hardware Discussion 2 12-02-2006 01:02 AM
