Go Back   MP3Car.com > Mp3Car Technical > Software & Software Development > Front Ends > Road Runner > RR Skins > RR Skins No Longer Supported
View Poll Results: What GPS Program do you use?
iGuidance 607 57.00%
MapPoint 56 5.26%
Destinator 185 17.37%
Streets & Trips 90 8.45%
Other 127 11.92%
Voters: 1065. You may not vote on this poll
Closed Thread
Old 05-22-2007, 08:45 AM   #1441
kbreeden
Quote: Originally Posted by mdlesk View Post
The problem I am having now is I can't figure out the ini. I tried a ton of things but nothing seems to work. I got the first 2 lines correct, i believe but I'm not sure about the last 2 lines. Does anyone have an example INI, the ones in the Launch directory aren't really helping.
Check here:
http://www.mp3car.com/vbulletin/rr-f...cation-rr.html
It's really quite easy. If you do everything right and the program still doesn't embed properly, it's most likely a faulty window name. Sometimes finding the correct window name can be elusive even with Winspector, especially if the application spawns other windows.
kbreeden is offline
Old 05-22-2007, 08:49 AM   #1442
leatherboy's Avatar
leatherboy is on a distinguished road
Quote: Originally Posted by ArikDpc View Post
I use this skin with mapmonkey , and these files are listed in the skin.
does anyone has them in his digitalfx 2 skin library ?
thanks
Forget it, you will never get an answer for this. I did the first steps and I embended mapmonkey in RR. An easy way is to copy the menu_on and menu_off images and paste them with the names you want. Destinator_On and Destinator_Off. If you want to see mapmonkey in the region where the menus are (music, radio, dvd, gps etc), open menu.ini and add to the end of the file the line.
A, 007, 114, 786, 398
x y width high
I am not in frond of my pc so I think the cordinates are correct, but you can change them depending the exactly possition you want MM to be. By this you will have the bottom line of the menu accessible and the header. Of course you can delete all the lines in the menu.ini that refers to the buttons in the middle an the flash square.
This is a simple and quick way to use MM. Then you can "play" with MM bars to remove useless buttons.
It's just an idea. Hoping that I helped a little. If I will finish it I could post it, but it is easy this way i describe it.
leatherboy is offline
Old 05-22-2007, 08:52 AM   #1443
kbreeden
Quote: Originally Posted by shot598 View Post
am trying to get winamp to mute when iguidence speak. i work for alittle then it just stop..i did everything in the DigitalFX Help.still cant get it to work again
Assuming that the feature is still turned on in the settings portion of the DigitalFX skin, if it was working before and is no longer working it's probably because you have changed the volume of iGuidance or your mixer to levels that won't allow the muting to work. From the DigitalFX help file:
For Winamp to automatically pause when iGuidance speaks, you must adjust your system volume settings. For Road Runner to know when iGuidance is speaking, it relies on sensing a volume change. You should set your wave volume to at least 5% difference than the iGuidance volume level. In my case I have iGuidance set to 100% volume, and the Wave volume set to around 60%.
kbreeden is offline
Old 05-22-2007, 08:59 AM   #1444
kbreeden
Congratulations on the new house, John! (And here I thought you were using all those Paypal donations for beer. )
kbreeden is offline
Old 05-22-2007, 11:07 AM   #1445
kbreeden
RREarth
Quote: Originally Posted by morris_the_cat View Post
Hi John,
Loving the updates from yesterday, but I sure found a really interesting bug this morning. Well, it is kinda a bug, because I know you aren't officially supporting RREarth, but anyway here goes. I don't have satellite radio so I use the skin editor to remap the satellite radio to RREarth (ie: change command "XM">"GE_start"). Anyway, when I leave RREarth and go back to the main menue, lo & behold, the entire upper part of the main screen where you recently placed the transparent spectrum analyser is a really wide and short google earth window! No song information or anything else is visible in that window. While you don't support RREarth, you may be interested in knowing this for future skin changes in case u do end up implementing it later. I think I probably have to either revert back to the previous main menu skin or else figure out a way to change that myself (for me, a nearly impossible task!). I wish I could get a screen capture of this for you, but I don't have a keyboard hooked up to my carpc & thus no prtscn button.
I know this is an old post, but I just started using RREarth and I have the same issue. Here's the screenie. Any way to fix this?
kbreeden is offline
Old 05-23-2007, 04:49 AM   #1446
skuller is an unknown quantity at this point
anybody know why the master volume in "eq" always show 0% after restart n hibernate?
I need to jack up the volume everytime I boot the pc.
"pause music" on iguidance was set to off.
Also how to set the GPS skin default to the one with song/gps location info?
I don't want to keep pressing the down right corner button once everytime I start GPS.
Thanks!
skuller is offline
Old 05-23-2007, 11:17 AM   #1447
SangreDeThor is an unknown quantity at this point
anyone else having the issue on the newest version when i click cancel route it doesnt cancel the route at all?
CarPuter: 900Mhz P3 with 256 MB Mem, 160 Gig HD (Thanks kbreeden), Iguidance 3.0 GPS, Logitech PS2 keyboard, Bluetooth, WIFI.
Powered By Road Runner & DigitalFX Skin and Playlist Conveter
SangreDeThor is offline
Old 05-24-2007, 06:18 PM   #1448
reromero is an unknown quantity at this point
John:
I've been using DigitalFx2.0 about a week, I think I found a bug, when in the GPS status screen, the "E" on the compass has a mind of it's own, when you are traveling east, you can't tell if the "E" is an "E" or a "W", it doesn't stay
upright like the other letters when you change direction. I think it's a problem with the "GPSCompass.swf" file.
by the way, good luck with the home purchase experience.
reromero is offline
Old 05-24-2007, 06:49 PM   #1449
Raw Wave
treetop777's Avatar
treetop777 is an unknown quantity at this point
The command under that (lower right hand) button is "LOAD;EXTERNAL_Music_GPS.skin;iGuidance;C:\Pro gram Files\iNav\iGuidance\iGuidanceUMPC.exe;iGuidance",
if you replace the command under the GPS button in the main menu with the one above, it should work the way you want.
Not sure but it make sence. Try it and let us know.
treetop777 is offline
Old 05-24-2007, 06:54 PM   #1450
Raw Wave
treetop777's Avatar
Quote: Originally Posted by reromero View Post
John:
It was mentioned earlier in the this thread, you're right, the sfw file is screwed-up but i don't think anybody has fixed it yet..
Can you?
Old 05-26-2007, 08:06 AM   #1451
afterdigital's Avatar
afterdigital is an unknown quantity at this point
thanks John!!! Digital FX looks awsome... been using for a couple of weeks and love it.... made a small contribution....Javier
CTS 05, Mobile Information Center...
Atom - 1.8ghz
2GB Ram
32GB SSD
8" TouchScreen
5.6" Screen (overhead) w/reverse capability
Finished Project
Car Hacking
WorkBlog
Video
afterdigital is offline
Old 05-26-2007, 10:05 PM   #1452
Where is the command for right hand corner?
I search all over the road runner folder, nothing looks like it.
skuller is offline
Old 05-26-2007, 10:27 PM   #1453
I found
"LOAD;EXTERNAL_GPS.skin;iGuidance;C:\Program Files\iNav\iGuidance\iGuidanceUMPC.exe;iGuidance"
in gps_menu.skin
changed it to:
Nothing happen. I still need to press those right hand corner button.
Any idea?
skuller is offline
Old 05-26-2007, 10:30 PM   #1454
Bump's Avatar
Bump is on a distinguished road
Just rename the file
" EXTERNAL_Music_GPS.skin " to " EXTERNAL_GPS.skin "
Bump is offline
Old 05-26-2007, 10:40 PM   #1455
thanks a lot man. It works!!!
skuller is offline
Closed Thread
For those who want true 5.1 Dolby Digital and DTS antimatter Car Audio 89 06-29-2007 12:54 PM
Artec T14A Mini USB 2.0 Digital HD TV Tuner LESLIEx317537 General Hardware Discussion 2 12-02-2006 01:02 AM
