The MP3car.com Store
Go Back   MP3Car.com > Mp3Car Technical > Software & Software Development > Front Ends > Road Runner > RR Skins
Closed Thread
Thread Tools Display Modes
Old 05-06-2007, 09:31 PM   #1
blk02si's CarPC Specs
blk02si's Avatar
Vehicle: '06 Triple Black Mustang
My Photos: (0)
Shock Skin - v1.0 & v2.0
This is my first skin for RR and it was built with simplicity, stability, and consistency in mind. It was loosely modeled from the OEM skins of Ford, Lincoln, Mercury, Chevy and GMC with the 'tabbed' menus on top. Graphics are much higher resolution than OEM though. Some of the newer skins for RR are really nice and have all sorts of neat effects but are hard to use while driving and need all sort of dependencies to install and make them work. This skin is 'old school' in its design as there is no flash, no crazy menu effects and NO B.S.! Its just fast, easy to use, and flexible in its design made to work 'out of the box'. To maximize its flexibility I have included the PSD files inside the skin directory. This will allow users to add menus, change menus, or change the color of the entire skin to match their interior lighting. Please keep in mind that this skin is designed to be slim for my embedded system and the way I use my carPC. It may or may not contain features you are looking for but again this is why I left it open source and included the PSD files. This skin also supports XP embedded or any XP install utilizing the EWF feature. It is the first skin I know of to support this.
PLEASE READ the _read_me_.txt file in the skin directory! It contains the release notes, instructions on how the skin works, and what needs to be done prior to launching the skin. If you refuse to read this and ask questions that are answered in the read me I will not answer them again. I have throughly tested the skin on my desktop and in the car and everything is working and very stable for me. If you notice any bugs or other unwanted behavior please let me know so I can fix them. If you have any suggestions on how this skin could be better please let me know. Skin was coded in RRskineditor and can be modified or opened in RRskineditor to see how everything is laid out.
Most Importantly - Have Fun!
DOWNLOAD Shock Skin v1.0
5.6Mb Download
__________________________________________________ ________________________________________________
DOWNLOAD Shock Skin v1.0 Burgundy
2Mb Download
Credit goes to Treetop as he did all the graphics on the burgundy color version. The PSD's are not included in this version which is why the skin is a record breaking 2 mb in size! That may be the smallest footprint for a RR skin yet.
My carPC - www.shocknet.us
blk02si is offline
Sponsored Links
Old 05-06-2007, 09:36 PM   #2
blk02si's Avatar
My Photos: (0)
UPDATE VERSION 2.0d RELEASED. This is an updated day version. The release notes contain the change log. As before, the PSD files are included in the archive. Please post if your testing and have tried it out, there is some new code in v2.0d. You DO NOT need to uninstall the first skin versions, in fact all 3 current releases can run side by side.
RELEASE NOTES
DOWNLOAD Shock Skin v2.0d
5.8Mb Download
blk02si is offline
Old 05-07-2007, 08:15 PM   #3
treetop777's CarPC Specs
treetop777's Avatar
Vehicle: 1981 Ford F-100
My Photos: (0)
Very nice, works perfect out the box. Thanks for sharing.
One thing..did you intend for this graphic to be this way?
treetop777 is offline
Old 05-07-2007, 08:32 PM   #4
blk02si's Avatar
My Photos: (0)
Yeah its supposed to be a folder. I just gave it the same glass effect as the toolbars, although it looks like a large bright spot. Im actually thinking about taking the folder icon out of the next release since you can toggle audio and browser modes just hitting the 'mp3' button. Glad to hear it is working good for you, stability is key for the carPC.
I think I am going to add an '=' key in one of the blank keys on the OSK. Was using the OSK to edit rr.ini and realized i really need the equals key!
blk02si is offline
Old 05-07-2007, 11:33 PM   #5
blk02si's Avatar
My Photos: (0)
Found the best spectrum analyzer EVER. Configurable for any color and infinate styles. Unzip vissatan.zip and drop the DLL into your winamp plugins folder. Here is a screener of it configured for my colors and running on top of my tab bar.
blk02si is offline
Old 05-09-2007, 04:41 PM   #6
treetop777's Avatar
My Photos: (0)
I'm destroying your skin!
Actually, it's one of the easiest to work with and modify, i'm learning a lot..thanks.
Old 05-09-2007, 10:59 PM   #7
blk02si's Avatar
My Photos: (0)
It is quite simple in design, Glad to hear that you are tearing into code and learning, thats how I coded this one, just looking at other skins code and tearing it up to see what works and what doesn't. I've got some plans and some new code in action for release v2. Im working on the video browsing a bit more and adding a slider to video player. I also want to finish some of the smaller menus like the shutdown screen you have pictured. Looks like its from CFX which, funny enough, is the skin I probably referred to most while learning the code structure. Also release 2 will have the code more organized in the .skin text files for those you like to edit via the trusty notepad.
Wonder how a white/bright high contrast day version graphics would look?
blk02si is offline
Old 05-10-2007, 03:41 PM   #8
treetop777's Avatar
My Photos: (0)
It sure is the exit menu from CFX Blue
Now i got to see if i can figure-out how to change the color of the skin.
Old 05-10-2007, 07:32 PM   #9
GizmoQ's CarPC Specs
GizmoQ's Avatar
Vehicle: Several
My Photos: (74)
Yea, Yea, Yea
HARDWARE: Fujitsu Stylistic 4121w/ WiFi & mini dock, Sierra Wireless Aircard 550, EXP PCMCIA Portable DVD-RW, Silabs FM, WinTV USB w/-26dB diversity antenna, XM Commander w/Timetrax USB, Delorme GPS, Saitek X-52 USB joystick, BluSoleil USB Bluetooth
GizmoQ is offline
Old 05-12-2007, 04:26 AM   #10
blk02si's Avatar
My Photos: (0)
To change colors you need to edit the PSD files, if you have photoshop you can double click on the color overlay effect. Its quite simple as my PSD files are layed out very clean. I starting toying with the day version but i still love blk and grn 4ever
blk02si is offline
Sponsored Links
Old 05-12-2007, 08:51 PM   #11
treetop777's Avatar
My Photos: (0)
Still screwing it up but getting there..
Old 05-13-2007, 03:45 PM   #12
blk02si's Avatar
My Photos: (0)
Sweet Treetop, thats looking good! Like the deep red / burgundy color. This is awesome. Take a good look at the layers in photoshop. All of the menu's are in that menu.PSD file. You just need to turn certain layers on/off then save as a jpeg. For instance on that home menu you have pictured you need to toggle this layer: side buttons
If you want to remove the volume indicator and song label around you can do this in rrskineditor.
blk02si is offline
Old 05-14-2007, 06:24 PM   #13
blk02si's Avatar
My Photos: (0)
Started playing again. Working up version 2.0 to be released with day theme and different colors. My new cingular 3125 with windows mobile 5.0 has been taking up too much of my home desktop time! Need to get back skinning. On another note my poor kingston 2.0 Gb flah drive went through the washing machine and the dryer. Was amazed to find that it still works after that. if you need any more help treetop let me know, I like that color scheme!
blk02si is offline
Old 05-14-2007, 06:57 PM   #14
treetop777's Avatar
My Photos: (0)
I think i'm getting the hang of it I'm working on the rest of them. When i'm done, i'll let you have everything so you can release it if you want.
Good to hear you thumb drive survived..is that where you keep the working copy of the skin?
Old 05-14-2007, 07:08 PM   #15
blk02si's Avatar
My Photos: (0)
I keep the skin on a new 250 GB sata drive under c:/DEVEL/RR/SKINS just use the thumb to transfer music and videos, i've been addicted to entourage while i drive. what kind of ride do you have TT?
blk02si is offline
Sponsored Links
Closed Thread
vB code is On
Trackbacks are Off
Mauri RR skin mauri RR Skins 122 12-06-2007 09:50 AM
Minimal Skin Release kpjuk RR Skins 62 03-17-2007 03:31 AM
Blue Devil Skin RELEASED JohnWPB RR Skins 1005 01-05-2007 07:54 PM
Beta Release Black Vinyl on Aluminium kpjuk RR Skins 10 07-31-2006 09:34 AM
New Skin - Spaced_Out for FrodoPlayer 1.08 WeeZyFellA FrodoPlayer 24 10-17-2004 09:50 PM
Sponsored Links
SEO by vBSEO 3.1.0
Ad Management by RedTyger
