07-23-2007, 02:57 PM
#61
I love you
07-23-2007, 08:10 PM
#62
High Voltage
::blushes::
Here is the screen caps of the audio player, and a new split screen GPS mode.
Its def. worth a little more RAM usage to have the skin be this fast!
07-23-2007, 08:27 PM
#63
High Voltage
New settings menu
07-23-2007, 10:20 PM
#64
High Voltage
All Menu art and basic code is complete. Just finishing up the OSK's and tweaking the code a bit more. Need to figure out the 'J' image code and how come my slider will not "slide" into a track position now/
osk screener
07-23-2007, 11:12 PM
#65
High Voltage
Exit menu implemented, this one's for you treetop!
07-24-2007, 04:56 PM
#66
Raw Wave
Much Obliged. Please, Please include that background too!
07-24-2007, 05:53 PM
#67
High Voltage
All backgrounds you see in this preview will be included
07-24-2007, 07:25 PM
#68
High Voltage
Mixer Menu.
Well Skin is for the most part done. I need to set up a couple things and do the documentation now. There are going to be a couple dependencies with v3.0. Roadrunner.exe 4-2007 or higher is a must. GDI wrapper must be registered (Im writing a simple script to install this) A line or 2 needs to be added to rr.ini before first run. It will all be explained in the READ_ME. I gotta say now that I know how to skin with transparencies it opens up a new world of ideas for me.
07-26-2007, 09:30 PM
#69
High Voltage
Documentation nearing completion. I also added a 'hidden' development menu for the pros. It contains the framework for the next version of shock skin which will use custom labels for buttons so the button names can be changed and the overall layout can be reordered. Using this template a version with icons on top would also be feasible. I will be starting a new thread for v3.0 and current version 1.0 and 2.0 will remain hosted although development has stopped on both versions and they can be considered legacy at this point.
I will include a link to the new version when it is up
PS im going to see the simpsons movie at 12:01am MI time so I need to leave soon
07-26-2007, 09:50 PM
#70
High Voltage
And just in case anyone is wondering where my blk02si name came from i've included a wallpaper from my sinister Si
07-27-2007, 07:25 PM
#71
Quote: Originally Posted by blk02si
To change colors you need to edit the PSD files, if you have photoshop you can double click on the color overlay effect. Its quite simple as my PSD files are layed out very clean. I starting toying with the day version but i still love blk and grn 4ever
Pardon the dumb question. But, after I change the colors in the psd file. How do I get the new colors to show up when I launch RR.
thanks
07-27-2007, 08:37 PM
#72
High Voltage
Hello hvaughn,
Changing the PSD's requires saving new menus in jpeg format. Its somewhat of a repetitive process as you have to save a on/off jpeg for each menu.
If I were you I would wait for the release of v3.0. It will be very soon. This allows any wallpaper to be used and the bars are transparent. You will be able to change colors on the fly.
What version are you using right now?
On another note I installed v3.0 on my via m10000 today in the car and it works awesome! It is faster on the via than v 1 or 2 and those were pretty fast. Since everything went good on my transfer to another PC I do believe v3 is ready for public consumption.
07-28-2007, 12:05 AM
#73
Raw Wave
Release! Release!
07-28-2007, 01:20 AM
#74
High Voltage
Version 3.0 released
You can find it here
07-28-2007, 09:59 AM
#75
Hello hvaughn,
I was using v1.0. But since v3.0 is available, I will switch to it now :-)
Man, you are a GENIUS! Thanks for the awesome skin.
| Thread Tools |
| Display Modes |
Linear Mode
