Go Back   MP3Car.com > Mp3Car Technical > Software & Software Development > Front Ends > Road Runner > RR Skins
Old 08-21-2007, 06:56 PM   #91
treetop777's Avatar
Can the black background of the selected track in the audio player be made transparent?
EDIT: Never mind - "trs" in the "S" (playlist) line needs to be "false"
treetop777 is offline   Reply With Quote
Old 08-21-2007, 07:56 PM   #92
blk02si's Avatar
Can you elaborate on this treetop, I was trying to figure that out but it didnt happen before the release, I would love to update this!! What is the "trs" line, I found it in RRskin editor and set it to false but my track selection remains opaque
My carPC - www.shocknet.us
blk02si is offline   Reply With Quote
Old 08-21-2007, 09:21 PM   #93
treetop777's Avatar
Blk, i think you also need to set the color of that background the same as the in the screencap - 255,255,200
Old 08-21-2007, 09:27 PM   #94
treetop777's Avatar
Here it is without the black line - beautiful!
Old 08-23-2007, 05:38 PM   #95
blk02si's Avatar
Excellent work Treetop!
I went through the whole skin and changed all lists to this scheme and I agree its a definite improvement. Im really glad you figured this out!!!
I also worked the Sat. code into the skin.
Machinehead i was wondering if you can post up your sirius code.
Anyway Im considering releasing a 3.1 version with the new updates to the list code and a working sat. menu.
Thanks again to everyone for the support! It helps everyone in the community
Old 08-23-2007, 05:59 PM   #96
treetop777's Avatar
I'm really glad you figured this out!
Wish i could take the credit but everything i know i learned from here. That code is from SE-2, i just happened across it, so credit goes to him/her.
Glad i could help.
Old 08-23-2007, 06:23 PM   #97
blk02si's Avatar
I really want to see you create a skin treetop. You obviously have a talent for the code. I would love to see a treetop release for RR. I'm quite curious to see what type or art/layout you would come up with. Until that day keep up the keen eye for the code and details
Old 08-24-2007, 12:23 AM   #98
blk02si's Avatar
Added more functionality into shock skin tonight. Adding slider bars on all the playlist and directory lists, they will scroll with the arrows and you can jump to position by clicking them. I also want to add a playlist_loader.skin which will have all the winamp .pls files saved in it. Here is a pic of the new slider bar in action. When you are not touching it the darker 'slider path' disappears.
I also started looking at implementing a mappoint menu. Have it really only use the core files of MP, the interface and buttons would be pure shock skin style. Doing a bit of research on this.
Old 08-26-2007, 01:27 AM   #99
blk02si's Avatar
Updates added so far:
Black bars removed from all lists, thank you treetop for the pointer!
Sliders for audio player and browser, video browser, skin select, background swap list and a track position slider in video player. They are all touch responsive and you can drag the slider, click on the slider bar for a "jump to" response, or just watch the slider move with the standard buttons you are used to. The slider additions make navigation even faster and easier to get what / where you want.
added simple blinking indicator for mute and a solid for shuffle.
I'm also working on a GPS skin to show speed, heading, sats, and a patch for iguidance 3.0 to match the visual style of shock skin.
Old 08-26-2007, 04:28 PM   #100
Machinehead's Avatar
All I did was take the XM code that was posted by fixerofallthing and change anything listed as XM to SR.
The code looks like this:
Code:
MEDIACAR Skin MEDIACAR Sirius Skin audio_off.png,audio_off.png,audio_on.png,audio_off.png /, A, x, y, w, h, color;RGB /, B, x, y, w, h, Command;COMMANDCODES, Tooltip B,703,405,102,78,"EXIT", B,601,404,100,78,"SHUFFLE", B,501,404,99,78,"NEXT", B,400,404,102,78,"PLAY", B,300,404,99,78,"PREV", B,199,404,100,78,"MUTE", B,96,404,103,78,"VOL-", B,-2,404,98,77,"VOL+", /, L, x, y, w, h, color R;RGB, G, B, font size;FONT, font name, Code;LABELCODES, Tooltip;LABELALIGNMENT /, S, x, y, w, h, x1, y1, w1, h1, O, Style, Pointer file path, h2, Code;SLIDERCODES, Tooltip L,97,80,144,26,255,255,255,18,"ISOCPEUR","SRSTATION","LEFT" L,278,80,144,26,255,255,255,18,"ISOCPEUR","SRGENRE","CENTER" /, B, x, y, w, h, Command;COMMANDCODES, Tooltip B,695,-3,106,68,"SKIN", B,579,-2,114,67,"LAUNCH", B,660,296,104,40,"LOAD;SR_gps.skin;iGuidance;C:\Program Files\iNav\iGuidance\iGuidanceUMPC.exe;iGuidance", /, S, x, y, w, h, forecolor R;RGB, G, B, backcolor R;RGB, G, B, played color R;RGB, G, B, selected color R;RGB, G, B, select color R;RGB, G, B, trs, font size;FONT, font name S,98,111,556,276,255,255,255,255,255,255,255,255,0,0,0,0,106,186,86,,18,"ISOCPEUR" S03,628,80,144,26,628,78,70,26,V,01," ",015,"SRTER","Ter Signal" S03,452,80,144,26,443,80,70,26,V,01," ",015,"SRSAT","Sat Signal" /, J, x, y, w, h J,660,110,114,53 /, B, x, y, w, h, Command;COMMANDCODES, Tooltip B,660,347,104,40,"SRFAV", /, L, x, y, w, h, color R;RGB, G, B, font size;FONT, font name, Code;LABELCODES, Tooltip;LABELALIGNMENT L,672,300,85,32,255,255,255,20,"ISOCPEUR","=Split","CENTER" L,674,353,85,32,255,255,255,20,"ISOCPEUR","=Fav List", L,660,175,108,53,255,255,255,48,"DS-Digital","VOLUME","CENTER" L,660,238,107,41,255,255,255,22,"ISOCPEUR","TIME","CENTER" /, B, x, y, w, h, Command;COMMANDCODES, Tooltip B,462,-2,116,67,"VIDEO", B,347,-3,114,68,"GPS", B,228,-4,117,69,"SIRIUS", B,110,-5,116,70,"RADIO", B,-1,239,82,65,"DOWN", B,1,170,81,66,"UP", B,2,307,81,95,"PGDOWN", B,2,66,80,102,"PGUP", B,2,1,109,65,"LIST", END
Not everything works and I don't know enough about coding skins to fix it.
Machinehead is offline   Reply With Quote
Old 08-26-2007, 08:50 PM   #101
treetop777's Avatar
Split Screen Bug?
Not sure if it's only my setup but i have to go to "NAV" first and let IG embed before it would work in the audio split screen
No big deal.
Old 08-27-2007, 01:52 AM   #102
blk02si's Avatar
Just tested that out and it must be your setup because mine will launch and embed perfect without first going to the main nav screen. Its weird because I believe the code is the exact same for either screen just a different embed area.
You will be excited to know that I am going to release some updated code very soon with your requests in place treetop! Stay Tuned
Thank you machinehead for posting your code.
Old 08-27-2007, 04:54 PM   #103
treetop777's Avatar
^^^ That's great Blk! Can't wait!
BTW, Just for sh**s & grins, try this on your test rig: exit out of shock (trough that fantastic exit menu) then fire it up again; without doing anything else hit "MP3" > "SPLIT" and see what happens..
Old 08-27-2007, 06:34 PM   #104
Area3's Avatar
I Don't understand how to get rid of the black bar?
Very Nice Skin Though!
Would Love To See weather and Ob2 Added!
Microsoft Is a Evil Empire that has corrupted a generation!
Thanks - Eric Scott
Area 3 Productions
www.myspace.com/area3
Area3 is offline   Reply With Quote
Old 08-27-2007, 09:04 PM   #105
blk02si's Avatar
Just tried it on my rig that was turned off, launched RR went to MP3 > Split and it launched and embedded.
Make sure this line is in the audio_player.skin
Code:
B,673,311,104,40,"LOAD;audio_gps.skin;iGuidance;C:\Program Files\iNav\iGuidance\iGuidanceUMPC.exe;iGuidance",
And this line is in audio_gps.skin
Code:
A,352,67,446,336,,,
If all else fails wait until the 3.1 update is released and see if this fixes your issue.
Area3 - the black bar will be removed in the updated version. Stay Tuned
Shock Skin - v1.0 & v2.0 blk02si RR Skins 74 07-28-2007 08:59 AM
IG3 Will not stay inside of the SKIN - opens in itsown Window..... dtragic GPS 4 11-29-2006 01:57 PM
Hard drive shock / vibration thoughts S11D336B General Hardware Discussion 60 09-26-2006 11:40 PM
Frigors Skin is RELEASED! nappyjim FrodoPlayer 312 03-22-2006 06:40 PM
New Skin - Spaced_Out for FrodoPlayer 1.08 WeeZyFellA FrodoPlayer 24 10-17-2004 09:50 PM
