Go Back   MP3Car.com > Mp3Car Technical > Software & Software Development > Front Ends > Road Runner > RR Skins
Old 10-30-2008, 09:30 AM   #61
RonS is an unknown quantity at this point
I really like this skin. But one request/question. Are you going to add RRGAS to this?
RonS is offline   Reply With Quote
Old 10-31-2008, 06:26 AM   #62
Valheru's Avatar
Valheru is an unknown quantity at this point
Quote: Originally Posted by GF-ler View Post
Last Version of Black_Apple_Mix.
I make some cosmetic changes in part of graphics and Audio_Player (valheru style).
a small change in part of saving RadioStation comes later as single file.
See Post 1 for new Link.
Wow ... it seems that I have created a "style" now - yipee ... GF-ler, excellent graphics, and I like the way you incorporated the TEK style audio player too ...
The TEKNIK Family ... Teknik 1 & Teknik 2, Teknik T-3, Teknik v4.0
Valheru is offline   Reply With Quote
Old 10-31-2008, 01:37 PM   #63
GF-ler's Avatar
GF-ler is on a distinguished road
normaly not, but if you can work with photoshop i can give you the files for making it by yourself.
Last edited by GF-ler; 10-31-2008 at 04:29 PM. Reason: horrible english. sorry, it was a bad day
GF-ler is offline   Reply With Quote
Old 10-31-2008, 01:51 PM   #64
GF-ler's Avatar
Are you not proud about your work ?
To say the Name of the Designer never was a problem for me.
Next Days i give a Link for a DAY-Version.
Old 10-31-2008, 02:02 PM   #65
You have a PM
Old 10-31-2008, 03:39 PM   #66
Valheru's Avatar
I am indeed proud of my work ... and thank you for the "nod" of recognition !
Looking forward to the seeing the DAY version too.
Old 11-07-2008, 03:41 AM   #67
GF-ler's Avatar
in post 1 is now the link for the DAY version.
different is, the PLAY button and the VOLUME are now without flash.
from the STATUS screen you jump into the GASPRICE screen.
some small graphic faults would be changed against the first WHITE version i give.
have a nice day and suck it if you like it.
Old 11-09-2008, 05:35 AM   #68
Kosti is on a distinguished road
Awesome, always look forward to you're updates!
DANKE!
Kosti is offline   Reply With Quote
Old 11-10-2008, 05:30 PM   #69
Jdi
Jdi is an unknown quantity at this point
Arrow
very nice skin! I like it!
But I have a problem to integrate Sigic Drive (gps soft)... With the tradicional Iphone Skin no problem, but with this I cannot!
Another problem is with the coverbrowser, when I select an Album I cannot listen it... What's the problem? coverbrowser it's ok with the Albums pictures but when I select it no songs appears...
Help me please!
byeeee
Jdi is offline   Reply With Quote
Old 11-11-2008, 05:02 AM   #70
GF-ler's Avatar
Help me please!
byeeee
hi,
did you read this posts ?
http://www.mp3car.com/vbulletin/rr-s...p-exectbl.html
in two positions you must select the gps software, first the rr.ini and in the exectbl.ini
if you have the right commandline for starting sygic drive ...from the original iphone skin... you can copy it into all 3 lines of starting the gps software.
the old one....for iguidance using...is
"IG212","LOAD;IG_FullScreen.skin;RUN;C:\Programme\ iNav\iGuidance Europe\iGuidance.exe;!IntellinavWCls!iGuidance"
"IG_Half","LOAD;GPS_Half.skin;RUN;C:\Programme\iNa v\iGuidance Europe\iGuidance.exe;!IntellinavWCls!iGuidance"
"IG_AUDIO","LOAD;AUDIO_GPS.skin;RUN;C:\Programme\i Nav\iGuidance Europe\iGuidance.exe;!IntellinavWCls!iGuidance"
all behind RUN;... you must change to your install.
albumcover,
you are right...and i dont the reason for the moment.
its because i work on another skin and use the same commands inside the exectbl.ini, have the same screens and .skin files....and it works.
so i have to compare every line of code between both applications.
give me a chance to find the fault.
editing:
see post1 for changing two .skin files
Old 11-11-2008, 05:03 AM   #71
GF-ler's Avatar
xyz
Old 11-12-2008, 05:44 PM   #72
osman is an unknown quantity at this point
how install this skin in my RR??
osman is offline   Reply With Quote
Old 11-13-2008, 03:08 AM   #73
Valheru's Avatar
GF-ler ... on your weather screen you need to make a change ...
you have the variable "w_0day_ppcp" used twice - for both humidity and precipitation. this is the same for day's 0, 1 and 2 ...
Old 11-13-2008, 03:46 AM   #74
GF-ler's Avatar
thanks,
i found a lot more faults in the .skin files.
and its not funny, because every line between a running skin (CAVE) and the apple ones is the same, only the coordinates are different.
all around the RRMedia and the SAL.R albumcover i insert by copy and past from BlueZX3 and SAL.R application, the fine tuning i make with the editor 0.71.
some functions didnt work correct, so i compare all lines with the CAVE one.
yeah i use glases, but to see that theres no different between NON running and RUNNING i see without them.
so i wrote all commands new by editor 0.5...and now the most things are working the right way.
only Blues RRMedia didnt save me the rated song inside the database file.
its a long time ago i had a near fault in the Simplistique skin. this time i swear never ever work with copy and paste. i think i forgot it.
the .skin files of the dark_apple i changed, if the white apple are changed too, i put them in post 1.
$osman
did you read the notes.txt file ?
is their anything you didnt understand ? if yes, lets change to PM.
Old 11-13-2008, 08:08 AM   #75
ok GF-ler
thank you..
**NEW BETA Software release for XP & Vista** 2k1Toaster FB Software 28 11-07-2007 04:35 PM
Cinergy 600 users wanted (enhanced RDS support available) Robby BMW Road Runner 70 10-15-2007 06:21 PM
iGMod Beta 1 release PURDooM Other Cool Stuff 175 12-28-2005 11:17 PM
Release CENTRAFUSE BETA 2 (1.3) veetid Centrafuse 128 08-01-2005 04:13 AM
RELEASE - FreeDrive 0.51 Beta CdRsKuLL FreeDrive 39 04-20-2005 05:03 AM
