12-04-2007, 10:46 AM
#31
Hi!
I found this link: http://www.kompassist.co.uk/RRSkinEditor.zip
this is the V0.3019
where can i download the new version?
Englishlessness :(
12-04-2007, 11:27 AM
#32
RoadRunner Mastermind
That is V.5!! make sure you don't have it on cache or something -- check the window title for the version.
Road Runner,RR's Myspace
12-04-2007, 12:03 PM
#33
Yes, but it drop me an error
ActiveX component can't create an object...
Englishlessness :(
12-04-2007, 02:45 PM
#34
Ok
it works, some missing Dll and OCX
THX
Englishlessness :(
Reason: non
12-06-2007, 03:34 AM
#35
hI ALL
fantastic job on RR
i had thought about building a car years ago but here in new zealand pc and parts arnt cheap, anyways i have now got one in my car for about 6 mths, nothing flash
but im making my own skin now and just downloaded this skin ed, i like the idea or a virtaul editor, loaded up my skin and hit the VE tab and get popup window with run time error '339" and RICHTX32.OCX error
any ideas?
ta
FUBAR
EDIT
got it working
http://www-1.ibm.com/support/docview...id=swg21171121
12-14-2007, 08:54 PM
#36
Help runtime error
Hello all,
I am trying to use the new skin editor but i am getting a runtime error 339
component 'ComDlg32.ocx or one of its dependencies is not correctly registered: a file is missing or invalid. can anyone help with this. I have loaded the vb runtime file but still am unable to get the skin editor to work. thank you in advance for your help.
12-14-2007, 09:13 PM
#37
Quote: Originally Posted by ccisat1rxp
Hello all,
Seen that before. Download only that file (plug it in google); copy it to c:\windows\system32 then register it manually. The problem will be fixed.
12-14-2007, 11:56 PM
#38
Hello all,
the post above yours is same error
this fixed worked and havnt had any problems
12-15-2007, 10:12 AM
#39
runtime eror
problem resolved copied OCX files to system32 directory and all is well. thanks for the help.
12-17-2007, 12:50 AM
#40
Raw Wave
I have just found another bug..
When saving the skin, it does not put a blank line under any INC lines or at least the last one. I was editing the DFX 3.0 skin and couldn't figure out why my plugin wasn't getting initialized.
Origanal skin file(top few lines):
Code:
RoadRunner Skin
RRScreen menu.
INC,DFX_Font_Color.txt
INC,Plugins.txt
L,516,4,71,25,#DFX1R#,#DFX1G#,#DFX1B#,16,"Arial","TEMP2","left"
L,408,4,101,25,#DFX1R#,#DFX1G#,#DFX1B#,16,"Arial","=Computer:","right"
To fix it I had to manually edit the skin file to add a blank line for rr to read it correctly.
Saved skin file, the one that doesn't work:
Code:
RoadRunner Skin
RRScreen menu.
INC,Plugins.txt
Manually fixed file looks like below, and now works again.
Code:
RoadRunner Skin
RRScreen menu.
INC,Plugins.txt
12-17-2007, 08:32 AM
#41
That's interesting.. the lack of the empty lines should not affect how RR parses it.. still, it should be placing those spaces.
12-17-2007, 09:39 AM
#42
Raw Wave
Thats what I thought, but rr seems to not like it, as the plugin line doesn't get read until there's at least one line below it...
01-09-2008, 06:59 PM
#43
Raw Wave
I have also found out that its not just the INC lines that have this prob, it can happen with the X,xxx plugin lines too...
Please fix or have a look at when you get a chance..
Many Thanks!!
01-16-2008, 09:42 PM
#44
Well I've been successfully using v0.5 for some time now, then I go to fire it up to do some skinning and I am greeted with an error. Re-Download the archive from the mirror site and same thing. Any ideas what this is or how it can happen? Just started throwing this error tonight. Only thing I did different to my system is update to RR 12/13/07 release which really has nothing to do with the skin editor. Anyway I'm stumped.
EDIT
Well opened up photoshop and started more art, hit the skineditor shortcut and bam it launched. Seems to be solved, come to think of it I always have photoshop open when skineditor is running and update art "on the fly" so I think the editor just doesn't feel like playing unless his partner in crime, adobe is running.
Reason: Fixed
03-02-2008, 08:44 PM
#45
I've been tryin to download the skin editor but the link seems to be dead. Anyone have a different link?
| Thread Tools |
| Display Modes |
Linear Mode
