Go Back   MP3Car.com > Mp3Car Technical > Software & Software Development > Front Ends > Road Runner > RR Skins
Old 12-23-2007, 11:44 PM   #121
THE EXPERIMENTER
carputer1's Avatar
carputer1 will become famous soon enough
strange 1
Quote: Originally Posted by Maddominican View Post
Ok... I'm using DigitalFX 2.2 for dayskin and LSXVoid for night. I just unzipped the files, placed the required files to the RR folder and that was it!. When I switched skins from DigitalFX to yours, it just changed the resolution to something like 300X200 (I'm just guessing the resolution because I've never seen that one, not even 640X480 was that big.) I like the skin, but it's too bad I can't use it (yet)
it might be because you have had or have still got lsx on the system, not saying thats the problem but i have had problems after installing lsx , had to clean it right out before trying anything else.
Links
Author of Ranger skin
Ford Ranger Truck Rebuild and system install Worklog
Current project status
Ranger Truck Rebuild 70% Current Open Project
Ranger Update:30% Total RE-WRITE
Ranger Help File:10%
Ride Runner Help File 30%
carputer1 is online now   Reply With Quote
Old 12-24-2007, 05:40 AM   #122
Valheru's Avatar
Valheru is an unknown quantity at this point
I too have run into issues after using LSX ... it is such a complete skin and it's installer does lots of stuff to your system. I had to fully uninstall it and clear out the RR install to get things to work after trying LSX ... I do use DFX on my system at the moment with TEK2 and there areno problems with them running on the same system..
Valheru is offline   Reply With Quote
Old 01-11-2008, 11:35 AM   #123
Valheru's Avatar
Bump to highlight the release of TEKNIK2 Transparent.
This version of the TEKNIK2 skin has many features, but most noticable it incorporates a new "plugin" from El-Camino.
This new software uses the winamp media library to store your songs ratings. Additionally you can search the media library for Album, Title, Artist and Genre. Many thanks to EL-Camino for the use of this new software, and to carputer1 who also played a big part in bringing this skin to release.
Enjoy.
Old 01-11-2008, 05:52 PM   #124
brandensin is an unknown quantity at this point
Valheru, looking awsome...
couple of things,
- audio player does not support unicode. music files or dir with non-english names wouldn't load up in playlist..
- I don't know if it's just me, number of times, it doesn't find my music path.. Throws you out somewhere in C drive.... I had to exit and reload RR to get to my list...
- oh one more.. ^^ I know you are all about keep things in simple, but it would be nice to incorporate VIS right on top of that album art in audio player and make it transparent... ^^
brandensin is offline   Reply With Quote
Old 01-11-2008, 06:38 PM   #125
ok... i followed ur guide in help folder.
I got autoit error in loading RR.. Line -1: Error: The requested action with this object has failed.
This probably is not a skin issue, but embedded art doesn't work... it flashes jpg file for a .2 sec and dispears.... Are you experiencing this too?
-- update..
tags work great... rate still not working...
Old 01-11-2008, 07:00 PM   #126
THE EXPERIMENTER
carputer1's Avatar
-- update..
do you have active winamp and winamp 5.13
Links
Old 01-11-2008, 07:14 PM   #127
yes... winamp 5.13 i had.. and installed active winamp.. one thing i wasn't too clear from the instruction.. was this...
Next go into Winamp and activate the Media Library, and add your music to it.
-- I don't know exactly what it means...
IMPORTANT : Make sure you disable "ONSONGSTART","" and "ONSKINSTART","" in RR's ExecTBL.ini, the one in RR's root.
-- i don't see them so, no need to disable..
Old 01-11-2008, 08:07 PM   #128
THE EXPERIMENTER
carputer1's Avatar
right ok
open Winamp on its own, right click on the top bar select media libary, if have never done this before it should give you a popup asking to search for music,select your music folder and go thats done.
Links
Old 01-11-2008, 08:09 PM   #129
EL CAMINO's Avatar
EL CAMINO is on a distinguished road
something is not letting the script Sync_Lib.exe set your music library as the default. you can do it manually do this.
open winamp, Ctrl + P>>MediaLibray>>Watch Folders>>Add Folder(add your music directory)>>Rescan now
EL CAMINO is offline   Reply With Quote
Old 01-12-2008, 01:08 AM   #130
sweet... that did the magic guys.. Thank you so much... For one more clarification.. Let's say i rate my songs 4 stars... That shoud save the songs under 4star playlist in playlist folder, right? Then i should able to play that list any time from that folder, correct?
Old 01-12-2008, 02:33 AM   #131
Valheru's Avatar
hey brandensin ...
nope . this software from El-Camino doesn't use playlists for the rated songs. The ratings are stored directly in the winamp music library ... which is why you added your songs to it at the start ...
to set the ratings for a song, click on the "Rate" menu from the main autio player and then press the "star" you want to rate it ...
to load a rated playlist click on the "Rate" menu from the main autio player and then press the "Load" for the rated playlist you want (1-5 star).
other things ....
1. support or unicode is actually in RR - I think - nothing to do with the skin ...
2. support for VIS may come in later releases ... but you could add it yourself if you like.
3. embedded art .. not sure about this, I don't use it really but I'll check it out.
4. musicpath lost - never seen that one before - on any skin ...
Old 01-13-2008, 01:39 PM   #132
Valheru's Avatar
Just checked this on my setup with TEK2 as was released and embedded art seems to be ok. I have a few MP3 with embed art in a folder with other mp3's and the album art changes with the songs from embed to non-embed ... might be something in your setup ... have you reg the MP3ART.dll file for embed art usage in RR ?
Old 01-13-2008, 03:48 PM   #133
yes i did... and added
X,Mp3Art to main.skin file... Probably I just need a fresh install of everything...
Old 01-13-2008, 03:51 PM   #134
EL CAMINO's Avatar
whats the RR version you use?
Old 01-13-2008, 05:27 PM   #135
Thanks Valheru, rating works just like the way you said... ^^
Looking at the property of binary i downloaded, Dec. 14th is the creation date. Just loaded Ultimate, and it does what it shold do with embedded art.. I got the feeling something is not set for tek2... Just don't know what it could be... It acts as if there is no embedded art in mp3 file as it shows nothing after flashing of physical jpg for a split second...
GATSO Hunter v1.0 Engram Software & Software Development 31 03-17-2008 01:31 PM
Rc2 Without Progress Bar??? coucouillu Centrafuse 35 08-11-2006 03:49 PM
moto e815.. some progress but more questions! Sonicxtacy02 PhoneControl 0 04-24-2006 04:00 PM
Progress meter not showing Meelobee Road Runner 1 07-15-2005 01:20 PM
GPSSecure V1.0 ToDo Checklist xBrady GPSSecure 3 06-03-2005 11:59 PM
